Question about Robitussin Cool Moisture 1 Gal. Humidifier
Robitussin 1 galon humidifier doesn't use any water don't know it is working or just fan stays on.
My humidifire doesn't use any water. In the morning I see tank full after all night use. How Iknow It is humidifie My room. If anything wrong, what it could be?
  • 5 more comments
  • bkndhrtd Nov 08, 2007
    I have used my unit one year and this year when I turn it on the next morning there is the same ammount of water in the resivoir as there was yesterday. I figure its broke and I need to jiust buy another one. I am very disappointed with the unit as I am on disability for a lung condition. I cannot afford to buy another unit every year. Next time I will make sure I don't buy a Robitussin 1 gal.
  • turtlejd Nov 16, 2007
    Same problem, and looking to see if anyone knows what to do.
  • Anonymous Mar 11, 2008
    humidifier does not use any water running for 7 hours still has the same amount of water
  • Anonymous Aug 19, 2008
    same
  • Anonymous Nov 27, 2008
    Does not use water///////
  • Anonymous Jan 24, 2009
    My unit does not use water although it is clean and seems to be functioning correctly.
  • katipea May 11, 2010
    Needs salt. Add about 1 tsp. BTW, what is the model number?
Can you give Motrin and robitussin together?
Your best bet is to ask your physician or pharmacist. If Robitussin contains the same active ingredient as Motrin, the answer is most likely NO, because it will be too easy to overdose. Otherwise, I don't know if there will be any interaction between the two drugs. Sometimes a combination will cause problems for certain individuals but not others. Again, ask a professional.
Dec 18, 2014 | Robitussin Humidifiers
Cant find filter
Maybe this picture can tell you the location of fuel filter ,hope help.
Feb 04, 2014 | Robitussin Cool Moisture 1 Gal. Humidifier
Model RCM-832. On/off switch works, blows air but no moisture seems to come out. I left it on for at least one day and the water level in the tank remained the same.
First check humid-stat setting make sure that the room is not above setting. Second check that float(water level) switch is being made. Hope that helps
Feb 08, 2011 | Robitussin Cool Moisture 1 Gal. Humidifier
Model 800 Aprilaire steam humidifire I have
Follow manufacturer instalation instructions. Why risk your equipment and you family's health to save a few bucks and a lil trouble on the proper parts. Your family is worth it, now go do the right thing. :)
Jan 24, 2011 | Aprilaire 550 Humidifier
It blows air, but no moisture comes out or is used from cannister. where could the problem be?
You need to add salt. I'm not sure if table salt or some other salt is best, but it requires that addition to create noticeable mist. I use probably 1 tsp.
Maybe you can answer my question. What is the model number? I've been searching for and have found replacement filters, but I'm not sure which ones to buy. Please let me know at kati.pea@gmail.com
Jan 10, 2010 | Robitussin Cool Moisture 1 Gal. Humidifier
HOW TO REPLACE FILTER #wf813
It's easy to find a replacement if you know what the model number is of the humidifier. If you do, let me know.
Dec 08, 2009 | Robitussin Cool Moisture 1 Gal. Humidifier
Aprilaire 600 Humidifier
J-
I had this problem several years ago. In order for the water to flow, the outside temperature sending unit must indicate to the controller that it is less than 60F. If not, the unit will not operate outside of test mode. Check the temp outside where your sending unit is (could the sun be heating that side of the house?) and ensure that the circuit to the sending unit is working. I had a bad wire splice inside a wire nut stopping the circuit. Took me a long while to figure it out.
If the outside temp and your sending unit circuit is ok, I wish you luck on your troubleshooting.
adx_98
Nov 10, 2008 | Aprilaire 600 Humidifier
Noisy ultrasonic humidifire
The grey circle (diaphram) needs replacing. Try Maplin electronics.
Mar 31, 2007 | Swiss Air-O- 7135 Warm Mist Antimicrobial...
Doesn't run
When a humidifier doesn't run, it generally means it isn't receiving electrical power or the controls have automatically shut it off. 1) Be sure it's plugged in to an outlet that works and that it's turned on. Check the electrical receptacle for power, using a working lamp, appliance, or voltage tester. 2) If the receptacle seems to be dead, check the circuit breaker or fuse that serves the humidifier's circuit. 3) Check the setting on the humidistat. If it's set lower than the room's relative humidity, the humidifier won't go on; in fact, it may take several hours for the humdistat to respond to the room's changing humidity. 4) Be sure the humidifier's reservoir is full of water. 5) Unplug the humidifier unit. 6) Check the power cord. If necessary, repair the cord. 7) Remove the humidifier's cover panel. 8) Remove the humidistat and check it (as shown below). Replace it if necessary. 9) If it still doesn't work, call an appliance repairperson, take the unit into an appliance repair shop, or replace the unit. To check the humidistat, you?ll need a volt-ohm meter. A humidifier?s fan vaporizes the water in the reservoir and blows the water vapor into the house or room. If you need to check the fan, unplug the humidifier, remove the control panel, and lift the lid. Tighten the fan hub with pliers if it is loose; this should take care of rattles. If the fan doesn?t spin easily when you try to move the blades by hand or if it is still noisy, lubricate the motor bearings with oil. To establish whether power is reaching the humidistat when you know there are no problems with the plug or switches, unplug the humidifier, remove the control panel, and lift the lid. Test it with a volt-ohm meter set to the RX1 scale (or to K[omega symbol] or [omega symbol] resistance on a digital meter). Clip the meter to the humidistat terminals. The meter should jump if you turn the humidistat from high to low. If it doesn?t, you?ll need to replace the humidistat or return it to the manufacturer.
Jan 18, 2006 | Honeywell HCM530 Humidifier
Robitussin Cool Moisture 1 Gal. Humidifier Logo
281 people viewed this question
Top Robitussin Humidifiers Experts
Paul Carew
Dennis
Marvin
Marvin
Are you a Robitussin Humidifier Expert? Answer questions, earn points and help others
