Question about Arris DSR922
Can't tune any channels above # 5 on sat. GB
GB shows up on guide,no matter what channel is selected it reverts back to channel 5.
GB appears to be programmed ,     did a soft reset
  • 3 Answers
Did you try to clear memory and reprogram receiver. should solve the problem.
Posted on Jan 22, 2009
How do i tune the channels on a toshiba rc3910
Hi
Before tuning the set to auto tune mode, make sure the antenna or cable, whatever may, connected to its appropriate sockets at the back of the set firmly. To make it autotune:
As new services are broadcast, it will be necessary to
re-tune the television in order to view them.
Auto Tuning will completely re-tune the television
and can be used to update the channel list. It is
recommended that Auto Tuning is run periodically to
ensure that all new services are added. All current
channels and settings, i.e. locked channels, will be
lost.
[1] Select the SETUP from the main menu by using
Up or Down buttons. Press OK and Setup menu
will be displayed.
[2] Select the Installation from the Setup menu
by using Up or Down buttons. Press OK and
Installation menu will be displayed.
]3] Select Automatic Channel Scan from the Installation
menu by using Up or Down buttons and press OK.
A screen will appear warning that previous digital
programmes and settings will be deleted. Select Yes
and press OK to continue with the Auto tuning.
The television will start to search for all available
stations.You must allow the television to complete
the search. When the search is complete the Auto
tuning screen will display the total number of
services found.
* After search is completed for digital channels, a
message asking whether to search for analogue
channels appears on the screen
** Press the OK button to search for analogue
channels. The following menu appears on the screen
for analogue channel search
OK.
Jul 10, 2011 | Toshiba Televison & Video
Sony KDL-32S2010-Chicago area..channel 50.1 (WPWR) is now showing up on 51.3.(found it by accident). 50.1 showing spanish shows. Reinitiated auto tune erased all channels without antenna, then auto tune...
Do a factory reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Mar 27, 2017 | Sony BRAVIA KDL-32S2010 32 in. LCD...
Hi I have just retuned my tv but have found that the identity number(ie BBC1 is D.001, ITV is D.003) for channel 5 is D.800 which Guide plus uses but the TV recognises channel 5 as 005! therefore I cannot...
The retuning process is as follows:
  1. Press the [i+] or MENU button on the remote control to display the DIGITAL INFO menu.
  2. Press the BLUE button to display the MAIN MENU.
  3. Press the UP or DOWN buttons to highlight AUTO TUNING then press the OK button to display the AUTO TUNING MENU.
  4. Press the RED button to start the auto tuning process for all available digital channels.
  5. Wait for the process to complete.
If you wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time.
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Oct 03, 2009 | Sony KDL-26S2010 26 in. LCD Television
Does not receive 110 side
Hi a_mizrahi! I will be more than glad to assist you in thhis concern. If your model 510 dvr receiver dont get the sat 110. Lets check 1st the cable connection on the back of the receiver, make sure that the cable connected on sat in is connected hand tight and check as well if the cable is going to the wall with a connector as well. Then press the menu button on the upper left of the remote, it will pop up the main menu, once you got it, press number 6-system setup, 1 installation, 3 system info, It will show the system info one. check on the field letter g, you will see sat number, ex only 119, bcoz you cant get 110, check if sat 119 is green on the buttom box, if its green then select cancel on the screen, then select 1 pointdish, select on check switch then once you are on the install summary, select test on the buttom portionof the screen. It will run a test it could be 1 of 2 or depends on the situation of your sat dish.. wait till it finish. once its finish, it will show the install summary, check if you have, input1-119-all- device name, input2-110-all-device name, or it could show this way, input1-119-odd-even, input2-110-odd-even, if you got 110 on the input after the test it means that we are almost there to fix the problem.. select cancel on the screen, cancel all the way out of the menu until it will pop up attention 015, it should show a progress up to 5 of 5 then it will download the programming guide, wait until it finish the download and it will pop up a picture right away on the tv. let check if the 110 is ok, most of the channels broadcast under 110 is your local channels and some upper channels from the sat.. press menu and then main menu willshow, press 6, 1, 3, back to system info one, check on the field g if sat 119-green, 110-green, if there is no 110 showed on the field g, cancel alll the way out of the menu, then press the power button on the front panel of the receiver for 10secs to reset the system, it should show on the front panel of the box that the power light will turn off and turn back on by itself, then it will acquire the sat signal again, it will go to the process of finishing the progress and download the program guide again, just incase the front panel reset didnt work, do the hard reset by unplugging the power of the receiver to the wall outlet for 1minute. then plug it back in, it will go to the progress again and download the programming guide.. check again the sat on the system info one, by pressing the menu button on the remote, press 6,1,3, check sat 110 is there and 119, it should be green on the button. granting still no 110 sat, select cancel, then select on the screen updates - option 4 I think, once your there, check if without my permission is selected or check, then save , cancel all the way out of the menu, once you got a picture, press the power button on the remote to turn off the receiver, leave the tv on, wait for a few secs and it will pop up attention 061, downloading vital program information, this msg will appear if your software version is outdated.. wait until it finish and once its finish the tv screen will turn black or snowy screen and no lights on the front panel of the box. push the power button on the front panel of the receiver for 10secs to reset the box and wait till it acquire the sat signal and download the programming guide, this should fix the problem, if there is no changes, please call dish network tech support @ 1-800-333-DISH, to check your sat system, there is a possibility that there is a problem on the alignment of the dish, switch or lnbf..
Sep 02, 2009 | DISH Network DVR 510 DTV Receiver /...
I need an owners manual for the receiver
What channels on what satellite? You should always start with sat G1 channel 3 and rehit. This will map in all the channels the receiver is authorized to get from Motorola.Options 6 5 and the trip counter should go up by 5 and show ~ 4600 channels
After that you need to make sure you are good on the arc. Start with G-1 5 (analog) then go east about 20 counts to C3 channel 7 On both G1-5 and C3-7 you may need to adjust the skew to get the picture.
The same is true for digital channels like those on G3C like TNT, CNN, SPIKE etc.
Once you know you are on the satellite then adjust the skew.
Feb 22, 2009 | Arris DSR922
Mitsubishi CS-31505 TV - UN-memorize QV (Quick View) Channel?
I've learned from a Mitsu tech that there is indeed NO easy (nor logical & user-friendly) way to UN-memorize a QV channel.
However there IS a work-around to accomplish that so that the QV will revert back to its Factory Setting of "Last Channel Recall."
Using the Mitsu remote control:
1. Poke the Menu button.
2. On the Menu, select the "Add/Delete Channels."
3. Select the Antenna (A or B or whichever) and select the channel which was memorized in QV.
4. When that memorized channel number appears, select "Delete."
5. Poke the Menu button again to exit.
The QV memorized channel number is now gone, restoring the QV function to "Last Channel Recall."
NOTE: If that particular deleted memorized channel was also included among the SQV (Super Quick View) channels, it can then be added back into SQV using the Menu and SQV option.
Hope the above helps those who have encountered the same issue.
DWL
Jan 17, 2009 | Mitsubishi CS-31505* TV
How do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Dec 12, 2008 | Philips DVDR3380/05 DVD Recorder
Setting up Wii with TV
I'm 60 plus years old. Do I connect the AV cables to my TV or to my SAT receiver.
Jun 18, 2008 | Nintendo Wii Console
Televison & Video Logo
69 people viewed this question
Top Arris Televison & Video Experts
Electro Med Services...
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
