Question about GE WSXH208A Front Load Washer
I have a GE Front Load WSXH208 and it doesn't work.
It doesn't do the final spin, and the water doesn't drain, and also the soap is still left over. I'm trying to see where the screws are so I can take it apart and see what's wrong. I really don't know what is wrong, so if you know the answer, and can provide vivid pictures and details where the screws and procedures how to fix this on my own, please tell me.
Thank you.
  • unknown12 Nov 16, 2008
    "Remove hoses from pump. Remove two screws holding pump to bottom of
    washer. Look for obstructions in pump, and also clean out the area of
    the hose just before the pump."
    When you say that, do you mean to remove the whole pump out, because there are clamps and other obstructions in the way. Or to remove the screws and take out as much stuff inside as possible?
  • 1,543 Answers
Sorry I don't have any pictures of this handy, but here's what you should do:
Unplug machine. Take the front lower panel off by removing the two 1/4 inch hex head screws at the very bottom of the lower panel, right by the floor. Next pull the bottom of that panel out and down to release it from the two pegs at the top of the panel. Now, after you have removed as much water from the machine as possible with a scoop or cup, pull the machine forward about two feet and lean it back against the wall. (this will keep the rest of the water in the machine when you disconnect the hoses to the pump) Remove hoses from pump. Remove two screws holding pump to bottom of washer. Look for obstructions in pump, and also clean out the area of the hose just before the pump.
Reassemble and test.
Note: The washer will not spin if there is still water in it.
Posted on Nov 16, 2008
  • Carl Schulzetenberg
    Carl Schulzetenberg Nov 17, 2008
    Yes, remove entire pump. There may be obstuctions in the pump. (a nickel is a perfect size to block the pump outlet for example) Make sure the impeller (the part you will be able to see when you look inside the hole where the hoses where) is free to turn.
GE frontload washer doesn't spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 12, 2011 | GE WSXH208A Front Load Washer
My kenmore 3.5 front load does not drain during the final rinse and spin cycle. It does clear all of the soap and water during wash.
Check for foreign objects in drain pump or if not defective pump. Accessible from bottom front panel, two screws holding it in place
Jun 05, 2011 | Kenmore 44102 Front Load Washer
The washer will not stop filling up with water and spilling water on the floor unless manually stoped. Sometimes it spins and rings the clothes out and sometimes it doesn't . With either problem it...
Remove front of machine with putty knife/slide knife in at top of front on left and right u will see the tabs.. there is a pressure tube that attachs to tub on the left side remove tube. DONT BREAK OF THE *** it is most likly pluged use small wire to clean tube and the little *** that it gos on to// put tube back on (SPIN AND DRAIN MACHINE) test on all load sizes.. good luck thank you for voting.............................
May 21, 2011 | GE Washing Machines
Will not spin fast enough on final spin cycle to
ITS POSSABLE ITS NOT PUMPING FAST ENOUGH. CHECK THE DRAIN HOSE AND MAKE SURE IT HAS NO KINK. IF THATS OK IT MAY HAVE A BUILDUP OF SOAP. RUN A EMPTY CYCLE WITH NO SOAP. IF THAT DONT WORK YOU NEED A REPIARMAN TO CLEAN OR REPLACE THE PUMP.
May 15, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a wsxh208 washer that pounds awfully when in spin mode washer is level?????
check the shocks to see if broken.Is this item new?did you remove shipping restraints?Also check the top springs to see if there ok.Hope this helps happy thanksgiving.
Nov 25, 2009 | GE WSXH208A Front Load Washer
Does not advance from wash to rinse to spin
The washer is new and under warranty so I have asked for warranty service.
May 23, 2009 | General Electric WSXH208H Front Load...
GE Model WSXH208-How do you know if PUMP motor is not working?
Found out the motor usually don't burn out that easy...therefore, I put it all back....let it run and felt the motor warming up....then it works....guess I was just a little antsy... ;=))
Dec 31, 2008 | GE WSXH208A Front Load Washer
GE FRONT LOAD WASHER
Plugged drain hose (which you can easily remove and clean) or slow running household drains.
The drain hose is the approx.2' diameter black hose on the back of the washer that is clamped to the washer and the other end goes into a standpipe or a wall drain. Be sure to turn off your washer and unplug it and have some old towels handy and maybe a bucket!
If there is nothing in the drain pipe, then I would suspect a plug somewhere else in your house that is preventing draining.
Thank you for using Fix Ya and for rating this solution.
May 21, 2008 | GE WPXH214A Front Load Washer
GE Front Loading Washing Machine seems to be holding water....
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
Mar 08, 2008 | GE WSXH208A Front Load Washer
GE WSXH208A Front Load Washer Logo
210 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
