Question about Aqua Flo Aquaflo Tub - Master Tmcp with Air Switch 3/4 Hp 115v Pmp Aqf 017070101010
Diaphram defective and microswitch not being activated
I need help in finding a Air switch for my 3/4 " tubmaster motor
  • aqutubmaster Nov 26, 2008
    looking for replacement or way to fix
    Scholar:
  • 111 Answers
There are three main manufactures of air switches for pool and spa components.
Len Gordon
Tecmark (Tridelta)
Presair (Herga)
Air switches are inexpensive so it would be advisable to replace them when they fail.
When choosing an air switch be sure to match the your part careful with regards to SPDT, DPDT... also pay attention to momentary or latching switch mechanisms activation style.
To learn more about air switch types click here.
Posted on Jan 11, 2012
  • 22 Answers
You should be able to go to any search and type LEN GORDON air switch for a source.
Posted on Dec 22, 2008
I need to know how the upright microswitch is installed on a dyson dc17
It fits into a little slot in the motor compartment, when the handler is reclined it activates the switch to supply power to the brush roll motor.
Sep 21, 2017 | Dyson Vacuums
Kenmore 62922 electric dryer
follow this steps and fix it. God bless you
Thermal Fuse
The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Enter your model number to see parts for your dryer.
Help me find my model number
Start Switch
The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Door Switch
The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Most door switches will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Drive Motor
On most dryers the drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Drive Belt
On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Thermal Cut Out Fuse Kit
Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Incoming Power Problem
If the dryer won't start, check to make certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Belt Switch
If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Main Control Board
The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Timer
The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Oct 01, 2013 | Dryers
Not working
Thermal Fuse
Start Switch
Door Switch
Drive Motor
Drive Belt
Belt Switch
Main Control Board
Timer
Jul 09, 2013 | Kenmore Elite Oasis 7808 Gas Dryer
When you hit any button it turns on and the next button shuts it off
Thermal Fuse
Start Switch
Door Switch
Drive Motor
Drive Belt
Belt Switch
Main Control Board
Timer
Wont shut off
Hi ethang...
Try to adjust the pressure shut off switch...sometimes they can also get a hole in the diaphram and leak enough air to cause a problem, if you cannot adjust your pressure switch to shut off then you will need to replace your pressure shut off switch it is defective.
Please take time to rate me
Sep 08, 2011 | Ingersoll Rand - Rand Type - 30...
The outside door water does not work
Can I assume the ice and water are activated by two different switches? The ice switch activates the motor that dispenses ice. The water switch activates a solenoid that opens to dispense water. If you can, find the solenoid and make sure it's not stuck closed (tapping it with a screwdriver handles usually help persuade it a bit). I would tap the solenoid while pushing the water button. Listen for the solenoid to activate. If you can't activate the solenoid, find the switch and depress it with a small screwdriver. Usually, these switches are just simple little microswitches that need a little cleaning and coaxing
Feb 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
4wheel drive will not engage
There are three main things that could cause this. #1: in the passenger side kick panel is a module that controls the 4x4 and it should be clicking as you try to put it in 4x4.#2:There is a vacume activator switch on the transfer case located on the top on the drivers side.(If the module is clicking and trying to put it in 4x4 then I would just go to this activator switch).#3 If you replace the switch and it still dosn't go in to 4x4 there is a vacum diaphram under the battery tray that pulls the front end into 4x4.Check and make sure that there is vacum getting to the diaphram which is controled by the activator on the transfer case.If no vacume at the activator or diaphram check all the vacume hoses going into and out of the activator.If no vacume while vehicle is running suspect bad vacume line.You will need to remove the battery to test the diaphram under the battery tray.You will need to hook up some kind of battery to the cables with the battery out of the car to get it started in order to check for vacume at the diaphram.
Feb 06, 2010 | 2000 Chevrolet Blazer
Flashing 8 on display
A flashing 8 on the display indicates that the Selection and Credit Computer hasn't detected the gripper arm has returned to it's normal rest position over the CD carrier (where the CDs are stored). It can be caused by several factors:
1. Gripper motor switch has been turned off
2. K7 microswitch or actuator is defective
3. Blown fuse in amplifier
4. Defective gripper motor
5. Open latch solenoid coil
6. Defective Selection and Credit Computer
I am the authorized Wurlitzer Jukebox repair center for the US and would be happy to help you over the phone. I can supply parts and repair defective amplifiers and computers, etc. Please email me tech@wurlitzer-ohio.com.
Jan 18, 2010 | Wurlitzer Jukebox 1015 One More Time...
95 tahoe four wheel drive stopped working/shift light not working
I have a 1996 tahoe that did the same thing to me.
There is no vacuum lines, it is all electric. The motor on the front differental is controled by the actuator switch on the top of the trans case. The motor is controled by 3 wires. 1 is a ground and the other 2 are signal wires. When the truck is in 2wd, the motor will get 12volts to ground on 1 wire all the time to turn the motor out. When you put it in 4wd, the motor will get 12 volts to ground on both signal wire to turn the motor in.
Here is the point!! Check to make sure that none of those wires from the t-case switch to the motor are shorting out on something metal. In my case those wires came out of the wire loom(black tube) and rubed the insulation off. shorting on the t-case.
If your truck ever gets stuck in 4wd, were you have to keep it in 4wd or the front end makes a hell of a noise, the actuator switch on the t-case is none to go out. cheap fix. If that ever happens and you are in a pinch. Unscrew the motor out of the front end and manualy give the motor the signals that it needs with jumper wires and the trucks battery to turn the motor out, screw the motor back in. Don't put the wires back on till you can fix it right.
Feb 07, 2009 | 1996 Chevrolet Tahoe
Achiever ccs 5000 no power at all
hi check these before enything: 1) check with another device that the socket has power 2) check cable is good all the way (NOT torn, twiched, squashed) 3) the device is hooked up good (in place,NO trash) 4) there is a micro switch on the door which wont let the device work without no good connection 5) check good fuse should work good luck
Apr 05, 2006 | Achiever CCS5000 Shredder
Aqua Flo Aquaflo Tub - Master Tmcp with Air Switch 3/4 Hp 115v Pmp Aqf 017070101010 Logo
235 people viewed this question
Top Aqua Flo Pool & Spa Experts
Ian Kime
Ian Kime
Bill Jordan
David Spradling
David Spradling
Are you an Aqua Flo Pool and Spa Expert? Answer questions, earn points and help others
