Question about Panasonic PV-D4743 DVD/VCR
Player doesn't recognize any disc
I have used the DVD part of this VCR-DVD player only a few times and suddenly it won't accept any disc (including the cleaning disc). I saw the posted solution of cleaning the lens on the inside of the player. But if I open the unit I don't know which part is the lens. Where can I see a diagram of the inside of this unit with the parts marked? Also, if you know any other things to try, I would be glad to know. Thank you for any help you can give me.
  • George Kilmarx Jan 06, 2007
    I appreciate your time in giving me this tip. Unfortunately, it did not solve the problem. I guess I will need to buy a new DVD player, as the cost of taking it to a repair shop is as much as a new player.
    President:
  • 3,130 Answers
The lens is located right next to the spindle motor, or where the disc sits on a small round turntable looking disc. Be very carefull with this, as you can very easly damage it. Just take a slightly damped cotton swab and litely , in a swirling motion, clean the lens. With the dry end, do the same and try it. If it does not work, these players are common for the spindle motor, laser assembly, or the focus or tracking servos to go bad, and most likly will exceed the cost of a new one to have repaired. Good Luck PS Please do not forget to rate this thread.
Posted on Dec 11, 2006
Dvd player will play store bought DVD's but will reject other dvd's saying unknown disc when inserted
some older models wont recognize burnt DVD's
maybe Netflix discs have a macro on that doesn't allow your player to play them.
Sep 06, 2012 | Zenith XBV243 DVD Player/VCR
My VHS-to-DVD Burned Disc used to work and now it doesn't
Richard,
It could be your disc is scratched or DVD+R can't be read in the DVD player. Check for any scratches. Then pop in the disc in to your PC DVD, to see if it's readable.
May 31, 2012 | Daewoo DV-6T834 DVD Player/VCR
Why doesn't a -dvd recorded on sansui not playback on another dvd player
Sounds like the disc needs to be finalised to close the session...put the disc in and look for this in the disc option menu's
Feb 11, 2012 | Sansui VRDVD4005 DVD Player/VCR
I can't get my DVD disc to eject. It will play but won't eject? Any suggestions
You should try unplugging the DVD player from its power source then plugging it back in. Now try to open it and if that doesn't work than you'll probraly have to take it apart to get the disk out but sometimes the DVD players can get worn out or if you have a cheaper DVD player it might just be freezing up on you. I have had these problems before. I just took the DVD player apart to get my disk and then trashed it.
Jan 23, 2012 | GoVideo DV2150 DVD Player/VCR
My dvd won't play. every dvd i put in, it says bad disc. the vcr works fine. is it time for a new system. i tried a head cleaner and it says bad disc
Not necessarily time for a new one. I would give the DVD player a good cleaning before you consider a new unit. A good cleaning disk with some little bristles on it. Run it through three full times. DVD players are far more sensitive than VCRs and have to be cleaned even two weeks or so. When they get real dirty it can take some fooling with to get the DVD player to even accept the cleaning disk. But if it just won't accept the cleaning disk and you can't watch a DVD in it then it's time for a new one. I had a DVD player one time that took an hour of fooling around with before it got cleaned good enough to play DVDs. Worked for a couple years afterward.
Regards, Tony
Apr 19, 2011 | GoVideo Go Video DVD/VCR Combo
Won't accept any dvd disc
It sounds like the Laser went out. Buy a new dvd player
Jan 13, 2009 | Samsung DVD-VR330 VCR and DVD Recorder
Zenith XBV243 CD player keeps ejecting disk
You may need to try a cleaning disc to remove dust from the laser heads, as dust may be impeding the player from recognizing the disc type.  Also, double check the manual to see what disc formats your player can handle.  All players have a variety of formats they accept or reject.  If the owner's manual verifies that it does accept that CD format, try the cleaning.  If that doesn't work, it may an issue that will require an authorized service center to look at, which may not be work the cost as replacement DVD players are very inexpensive.  Avoid combo players such as the DVD/VCR combo, as when one quits performing, you either have to replace the entire unit or add a new single component for the bad one.  Hope this helps!
Dec 06, 2008 | Zenith XBV243 DVD Player/VCR
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
DVD appears to not be reading or recognizing discs
Unfortunately your DVD drive mechanism looks to have bit the big one.
You can try taking it apart, removing the top of the drive and cleaning the lense. Work it up and down. Use a q-tip with a little squirt of windex on it.
Reassemble and try it again. If you get the same results, it's time for a new DVD player.
Dec 27, 2007 | Toshiba SD-V392 DVD Player/VCR
DVD Player/recorder
yes ,you can try to buy at radioshack a cd cleaner if that does'nt fix the problem you'll need a new optic,let me know
Jun 10, 2007 | GoVideo VR4940 DVD Player/VCR
Panasonic PV-D4743 DVD/VCR Logo
96 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
