Question about LG (GSA5163D) DVD±RW Dual Layer Burner
Existing CD recorder drive now not working after installed DVD RW
I recently installed a LG DVD rewriter on my pc which already had a CD recording drive & i didn't realize it. This dvd rw had software from nero, light scribe, securdisc, etc. Well the night i installed this new drive i figured out i already had a cd recorder- i thought it was read only! Well i burned a CD in the existing drive that night. I hadn't restarted the computer to install the new software, well the next day i restarted the comp. & wasn't able to burn a cd due to "Sonic UDF software preventing InCD from being able to load". So i removed the new software from the dvd rw & tried to burn again on existing cd recorder & it says " attemp to burn disc failed- unkown error ocurred (1001). Any ideas?
  • LG Master
  • 2,045 Answers
You are to clean registry manually now. Nero still has leftovers in there.
Posted on Mar 26, 2017
SOURCE: dvd/rw
one possible way of solve this problem is remove ur nero and install latest version of nero........... if this option is not fix the problem means defenetly that is lense problem.. so give one service to ur drive u will get the solution........ okeeeeeeee........... bye......!!!!!!!!!!!!!
Posted on Jul 06, 2008
NitrusInc
  • 326 Answers
SOURCE: HELP!!!!! : "Not found CD/DVD Writer driver"
This could be due to a common issue. I would suggest you try this method first.
The following is a link to the Microsoft documented solution for issues with DVD/CD drives, explaining a step-by-step procedure. In the event that the first process, which is automated labeled "Fix It" does not solve your problem, please continue to the end of the document.
http://support.microsoft.com/kb/314060
After completing this procedure, please let us know if you are still experiencing any issues by posting a comment. If this information was helpful, please take a moment to rate the solution. Thank you
Posted on May 17, 2009
Testimonial: "thanx"
SOURCE: Nero cannot burn DVD inserted in my LG GSA-H55N DVD-RAM rewriter
I have the same problem, my drive doesnt want to write anything for that matter...possible faulty hardware?
To Amnonk: Are you f*$&ing stupid? Your answer is retarded
Posted on Aug 24, 2009
npconline
  • 91 Answers
SOURCE: my LG Black 22X DVD+R 8X DVD+RW 16X DVD+R DL 22X
Pls run lense cleaner CD ,, & check ..even it do nots works then its lense is no more producing laser rays strong enough to read medias
Posted on Jan 26, 2011
bronk50
  • 27725 Answers
SOURCE: My DVD did not always
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Posted on Jun 12, 2011
How to erase a dvd dics
dvd are read only.
dvd-r; dvd+r and dvd-rw are the re-writeable discs. mostly once only.
DVD Media Formats Explained
There are many different types of writable and rewritable DVD media on the market today. These formats include:
There are also "General Purpose" and "Authoring" discs. DO NOT confuse the "Authoring" media with the term for content development (making / editing what eventually goes on the DVD). The most common type of DVDR is the General Purpose type - if you do not know that you have an actual authoring recorder drive then you most likely have the general purpose type.
DVD-R is a write-once recordable format which allows excellent compatibility with both standalone DVD-video players and DVD-ROM drives. There are two main types of 4.7GB DVD-R discs: DVD-R for General Use and DVD-R for Authoring. Most consumer drives use the former cheaper General Use discs, while many higher end professional drives use Authoring discs. The correct media type appropriate for the drive must be used when burning. However, once burned, the discs should be able to be read in either drive type. (General Use DVD-Rs are designed to prevent backup of encrypted commercial DVDs).
DVD-RW uses rewritable discs which are rated at more than 1000 rewrites in ideal situations. Unfortunately, DVD-RW does not enjoy the same excellent compatibility with DVD-ROM drives and standalone DVD-Video players that DVD-R enjoys. Another drawback is that unlike DVD-RAM, one must generally erase a DVD-RW disc before reuse.
Most DVD-RW drives should also be able to record to DVD-R. However, the reverse is not true. Many older and some current DVD-R drives are not capable of writing to DVD-RW discs (but may be able to read burned DVD-RW discs). Some drives can also record to CD-R and CD-RW.
Currently DVD-RW and DVD-R are most popular in the multimedia market as well as the general consumer market. For instance the Apple SuperDrive, found in higher end Mac computers used in multimedia creation, is simply a DVD-R/DVD-RW (and CD-R/CD-RW) capable drive.
DVD+RW, like DVD-RW, is a rewritable 4.7GB DVD format. DVD+RW, however, in some ways offers some technical advantages, which for example include: lossless linking (which in turn more readily allows editing of a disc's contents after an initial write while maintaining integrity of the remaining data), currently slightly faster recording speeds, and optional future Mount Rainier drag-and-drop file access support (also known as DVD+MRW). However, DVD+RW does not have the very high compatibility with standalone DVD-video players and DVD-ROM drives that the DVD-R format enjoys. The level of compatibility of DVD+RW is said to be similar to that of DVD-RW. Also, DVD+RW does not currently have the same level of market acceptance as DVD-R.
DVD+R is a format that only was introduced to the public very recently (early 2002). DVD+R is a write-once 4.7GB format which promises to dramatically increase the compatibility with standalone DVD-Video players and DVD-ROM drives. Whether that claim is fulfilled remains to be seen, but initial reports have been very positive. It must be noted, however, that 1st generation DVD+RW drives do not support DVD+R burning, and it is likely that most cannot be upgraded to do so either. If one wishes to have DVD+R burning functionality, one must purchase a newer drive specifically designed to do so. DVD+R discs currently are somewhat more expensive than DVD-R discs, but prices will likely drop with time. Burners that write to these discs is the HPDVD100i and the DVD-Writer DVD200i drive
Thanks to www.AnandTech.com for this helpful information AnandTech Home
Mar 07, 2016 | Televison & Video
How to erase sony dvd-r
You can't erase a CD/DVD+R as they are write once - CD/DVD + RW can be erased
DVD formatsShort for Short for DVD-Recordable, a recordable DVD format similar to CD-R. A DVD-R can only record data once and then the data becomes permanent on the disc
hope it helps
Apr 14, 2012 | Sony Mini DVD-RW 1.4GB 30 minute ( 8cm - 3...
I conect external super multi DVD rewriter GSA-E60n, but i can not install in my pc.my pc is ASUS Eee pc 900, I want install one recovery cd in my pc,problem is this not working with my pc,I have to...
click start control panel administrive tools scroll to cd/dvd drives connect this dvd rw then see if your drive there if not check the leads that attach from the dvd drive to the computer make sure they have secure connections and are seated properly or you might have to activate add new device wizard click start control panel you will see add a new device this may vary depending on your operating system
hope this helps
Mar 28, 2011 | LG SecurDisc 20x External Double-Layer DVD...
Can these disk be re write or erased? Please send me an email via affordableshutters@yahoo.com Corrington Maycock
Welcome to Fixya. The CD is not a Rewritable disk you can only burn once. If you need a DVD or CD that can be rewrite or erase look for DVD-RW or CD-RW.
Thanks for using Fixya
Mar 14, 2011 | Philips (DVDR1S02/771) (100 Pack)...
Can this model of my Dvd reader : "LG GSA-H42N" burn dual layered dvds ?
Review: LG GSA-H42N
Reviewed by: MegaDETH
Provided by: LG - USA
Firmware: RL00 and RL02
Manufactured: December 2006
The LG GSA-H42N internal IDE drive. LG's newest DVD burner incorporates DVD-RAM recording, creating a true DVD Multi drive. Single layer 4.7GB DVD burning is supported at 18X max. Double Layer and Dual Layer Recording speed is 10X max. DVD Rewriteable speeds are 8X max for DVD+RW and 6X max for DVD-RW respectively. DVD-RAM recording is supported at 12X max. Very fast 48X max CD-R burning and 32X max CD-RW.
Hope this answers your question.
Have a great day!
Feb 15, 2011 | LG GSA-H42N 18xDVD+-R, 12xDVD-RAM,...
When recorded that show its record but after some time its not paly in any player even my Sony DVD cam also
try to find a rewritable media that is compatible with your player, like it can read recorded dvd disc . some dvd plyer dont have capable of reading photo cd, recorded disc, burned disc etc. maybe your player is the one like that.
Feb 02, 2011 | Sony Mini DVD-RW 1.4GB 30 minute ( 8cm - 3...
Won't record record to CD-RW
First make sure your cdrw disc is blank. If it is blank try another good known cdrw brand disc and burn it in 12x speed for a good burn.
If it still fail check the software side of your cd rewriter first and lastly the cd rewriter unit.
Mar 28, 2009 | Crosley 4-in-1 Entertainer CD Shelf System
No read no write
One possible source of difficulty is there are different blanks for "slow" recorders (1x - 4x), "high speed" recorders (4x-10x), "ultra speed" recorders (12x-24x), and "ultra speed +" recorders. The disc manufacturers had to change the way the discs were made to accommodate each successive improvement, so older recorders don't work with the newer disks.
It is possible for some 4x-capable "slow" drives to use the "fast" blanks with a firmware upgrade, but there is no advantage to doing so since you're still limited to 4x recording (unless, of course, you're unable to find "slow" CD-RW blanks).
CD-RW discs for the faster drives are labeled with a "High Speed", "Ultra Speed", or "Ultra Speed +" logos. Make sure you buy the right blanks for your drive.
Jan 15, 2009 | LG (GCE-8527B) CD-RW Burner
Won`t play or record
take it back and get a new one. Make sure you scan for a virus i use the free AVG
Oct 14, 2007 | LG GSA-2166D DVD RW Dual Layer Burner
LG (GSA5163D) DVD±RW Dual Layer Burner Logo
69 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
