Question about Canon imageCLASS MF6530 Monochrome Laser Copier/Printer
Canon ImageClass 6530 LCD Text shifts off window
I have a problem with my CANON Imageclass 6530 LCD screen. About 1/2 the text has shifted off the left side of teh screen. I followed the instructions from the Canon website (Turn if off/unplug for several minutes) to no avail. Anyone have any ideas?
5 Suggested Answers
SOURCE: IMAGECLASS CANON 6530 -
there is a shutter on the laser scanner that is opened when you insert the cartridge.(not the one on the cartridge). There is a mechanism that breaks or bends when the cartridge is inserted to hard or quick. it is a design flaw. I am a technician and have repaired this problem several times. I dont recommend trying to remove this shutter if you are not mechanical inclined!
Posted on May 06, 2009
callonafo
  • 172 Answers
SOURCE: broken paper drawer for Canon imageclass 6530
You can easily get that from any computer accessories dealer or shop and you can get it in a computer warehouse too. If you can't then you can go to canon online to see if you can get the product from them.
Posted on Sep 28, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: ImageClass 6530 copies and prints
This is either your toner cartridge or more likely the plastic arm that opens the laser shutter is broken. When you insert a toner and close the access door, there is a plastic arm that opens the laser shutter. If this shutter does not open it blocks the laser and results in blank copies. If the arm is broken you CAN open the laser shutter manually and block it open. What you need to do it open the cartridge access door, remove the cartridge and look for a 1/2 inch wide slot running from left to right in the metal frame that is in the back upper section where the cartridge goes. The plastic arm that operates the black plastic shutter is on the right side. If broken you can manually lift up the shutter and "block" it open using something like a folded up scrap of paper. I know it sounds strange but I have used this repair on several of my customers machines and they have all worked fine since. If you can not find or effect the repair yourself at least you will know where to point the service person when they come out to look at it.
Good Luck and Thank You for using Fixya.
Posted on Mar 19, 2010
canontech
  • 1219 Answers
SOURCE: canon imageclass mf 6530 blank pages change toners
you have problem with laser shuter on laser unit. It needs to be fixed or replaced.
This is canons factory fault, and if the machine is under waranty call service.
Hope that helped!
Posted on Jul 19, 2010
SOURCE: MY IMAGECLASS 6530 DOES NOT MAKE A COPY IT SENDS
If you had just changed the cartridge it my not be making contact with the drive that turns the drum. Some people pound on the back side while running a copy to get it to engage. This may take several times before it clicks into place. Take the cartridge out and close the door part way and you will notice that a white triagular shape drive arm will come out to engage the triangular shaped black driven unit that turns the drum. These two parts must mesh before the drum will turn and then you will get a copy. Once you get these two parts in the right place you will run fine until you pull the drum/cartridge unit out again.
Posted on Nov 23, 2010
I have a disc, however, where the disc goes in will not open. How can I reinstall my canon imageclass 6530 without a disc?
What you can do is take a paper clip, un bend it and make it straight.
On the front of where you put the disk in there is a little hole, stick the paper clip into it, the tray will open. and you can use it.
Jul 04, 2011 | Canon imageCLASS MF6530 Monochrome Laser...
Canon imageclass mf 6530 blank pages change toners still blank what is the cause of this problem
Hope that helped!
Jul 19, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
My printer canon imageclass MF4122 showing LCD "SYSTEM ERROR E225" What must I do?
1- open the glass scaner
2- now clean the steel shift and the in the end shift you can see white plastic roller clean it by oil cleaner then but on it white greze let the greze be between the slote of the white roller tobe move good
3- another side of the shift you have amotor and tow plastice dishly clean it then but a greze on it noite not put mor grezs
4- now clean the glass scaner and teste your printer
if it's still in problem try whith this step
1- open glass of the scaner then you have white cable it's between the scaner lamp and logic change it and teste your brinter
if it's still in problem do it's end step and you will finish the problem
change the scaner lamp and not forget clean the stel shift in the begining when you clean the white roller and put on the steel shift a white greze
good luck
basher66 - Iraq- Ramadi -
Nov 29, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
Broken paper drawer for Canon imageclass 6530
Sep 28, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Canon ImageClass MF 6550 prints light text
I mean can you scan a text document with the "photo" option and see if you are still encountering problem. And check this out, he tells how to reset to factory and test scanner. http://www.fixya.com/support/t342579-just_started_printing_blank_pages
Apr 27, 2009 | Canon imageCLASS MF6550 All-In-One Laser...
Canon imageCLASS D320 printer driver for windows
go to: www.driverguide.com
its free to join and they will almost certainly have the drivers you need.
Mar 10, 2009 | Canon imageCLASS D320 All-In-One Laser...
Canon mf 6530 doesn't work at all
well..that's weird...can you do a test page, with the printer disconnected from the computer?
Aug 19, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Canon Image Class 6530 LCD readout is off center
To reset LCD, turn off and unplug unit for a few minutes. Then Plug it back in, turn it on, and it should be OK.
Go here to see this fix:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=268&modelid=13170
Jun 06, 2008 | Canon imageCLASS D760 All-In-One Laser...
Canon imageCLASS MF6530 Monochrome Laser Copier/Printer Logo
47 people viewed this question
old marine
old marine
