Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Leaking Solution Tank/Seal Install - Hoover Steam Vac
Hi, I have a Hoover Steam Vac Deluxe F5860-900. Lent it out and it came back leaking from cleaning solution tank. I noticed the rubber seal from the tank bottom came off inverted and was sitting on the machine where it connects. It was a little mis-shapen so I bought a new one just in case the old one won't seal tightly. My problem lies in figuring out how to properly install the seal. It seems obvious but the process is not as easy as it seems. Don't want to damage the new one so I've been trying with the old one. Can't get it to fit inside the hole. (I think the small end of the seal goes inside the lip of the tank but getting it in there without destroying the seal is my problem) Any suggestions??
Thanks in advance
Jorge
  • 2 more comments
  • Anonymous Apr 19, 2009
    where can i get the new seal?
    I have the same problem trying to figure out how my new replacement parts get installed.
    MsKitti
  • Robert Thirlaway May 10, 2013
    http://www.vacpartswarehouse.com/ has all the parts for hoover
    http://www.vacpartswarehouse.com/ they have all the hoover parts
Not sure this will help, but we have a Hoover Steamvac F5843 and our valve seal seemed to have shrunk so the tank was leaking. Bought a new seal and had the same problem. How to install? There weren't any instructions or pictures of the part(s) involved in the manual. Online there were a few pics but nothing helpful. After careful examination of the existing part and where it was supposed to be, I removed the original off the valve stem, placed the new one on it and carefully pressed the valve stem with the seal into place. It didn't look quite right and we were thinking "now what?". My wife and I got the idea at the same time...install the clean water tank (with the stem & seal in the bottom) back onto the steam cleaner. I took it back off to see what the stem & seal looked like afterwords and voila...the seal was perfectly inserted where it should be and the tank no longer leaks! The 'peg' that presses up on the valve stem pushed the seal perfectly in place.
Posted on Mar 26, 2011
I have a Hoover V Steam Vac model F7412. The tank for the clean water and cleaner fluid leaked out the bottom. I purchased a new tank but something in that area is still leaking. I know it is not the...
My clean solution tank is leaking from the bottom, too. It is not a hose or a valve. The clean solution tank is leaking in-between the clear plastic walls of the solution tank & the grey plastic bottom that are connected, together. I was thinking of caulking it all around the bottom where the clear plastic sides join the grey bottom plastic. I can't get into ordering a new one (spending $) unless Hoover will send me a new one for free. Purchased at Kohl's in Massapequa, NY in June 2008. There's a one year warrantee AND the directions say to EMPTY the solution tank after each use. Which I normally do because the tank runs dry.
Aug 08, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover max extract V clean water leaking
get a new clean water tank or a seal to put on it from hoover.com/vacuumparts
Mar 16, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
I just bought a hoover steam vac model F5914900 and the clean water tank is leaking. I tried pressing the clean surge button and the trigger button that was suggested by someone else but it won't
Go to Hoover.com and find a local Service Station. They will replace it at no charge. MUST be a warranty location to get it free. Take your sales slip with you.
Jul 28, 2012 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac leak from the bottom when tank has water in it when not running but tank is not leaking
The tank is not sealing to the black rubber ring seal on the lower handle. make sure this seal is not displaced.
Nov 19, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Water tank leaks
If the tank is leaking, when removed from the cleaner, it is not user serviceable.
Oct 01, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover Steam Vac V2 Deep Cleaner leaking clean water
Fill the tank and determine if the plastic is leaking, or if the valves are leaking. if the tank is cracked, it would need replaced. There is an improved design now available.
You may cycle the valves on the bottom with the eraser end of a pencil.
Sep 24, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steam Vac V2 Leaks from Bottom
That is not the solution. I have purchased several tanks and the issue is not the tank it is leaking from the bottom of the unit. can you please let me know if you found a real fix? thx for your time
Jul 20, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover steam vac clean water reservoir leaking.
take the clean water tank out and look on the bottom for a fitting that screws on make sure its tight.also inside of that fitting trhere should be a washer or an oring to keep it from leaking.if thats not the problem then your pump mightbe leaking.for that i would take it to a vacuum repairman.i hope i have been of some help.please leave feedback
Apr 07, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac spin scrub leaking cleaning solution
The hose leading from the tank to the sprayer head on the bottom of the unit, or the tank is not seated properly or the tank has a hole or crack
Feb 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac clean water tank valve leaks
a) make sure that there is not a place for a stair attachment. If
there is make sure air is not leaking through where the attachment goes
on because of damaged or misplaced fitting.
b) some steam vacs leave water behind them and **** up in front of
them. If you just walked forwad with the steam vac nothing would be
sucked into the tank.
c) try taking your finger off the trigger and using the steam vac. If
the tank still empties the trigger is stuck open.
d) try putting clean water in the dirty water tank only and using it on
a dry rug. If water goes somewhere from the dirty water tank you have
a leak.
e) take apart what you can and look at the parts. A good visual
inspection can solve many of these types of problem if you are careful
not to miss anything.
Nov 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
3,363 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
