Question about Sony KP-48V90 TV
Green shadow or bleed off around white or light colors
I have tried the Flash Focus on my TV and it gets the converge close but the green is still off to the right alittle bit. Is there a service mode that i can go into to manually adjust this. Thanks for the help.
  • rudy goberdhan Sep 13, 2008
    leftside of tv convergence is bad
    President:
  • 3,130 Answers
You can check out this great site,http://myweb.accessus.net/~090/sonyadj.html If the service mode does not correct your problems, you will need to replace or if your not experienced with solid state electronics, have a tech replace the STK convergence IC's. Good Luck Please do not forget to rate this thread.
Posted on Dec 13, 2006
I think that it is the green because i did what you said and it is still there. there is a feature on my tv called magic focus it brings up the colors and the blue and the red are very focused but the...
This tv is a DLP projection tv right?Magic focus button push don't solved the focus picture problems,have colors shadows or 3D pictures problems?The tv have a problems known as a convergence problems,it dead.The tv convergence board.Must have it 2 STK convergence ICS and some or all it resistors to be replaced to solved the tv picture convergence problems.The shop,will cost u $300-$350 for parts and labors.
Oct 02, 2010 | Televison & Video
Magic focus blue is fine, green and red are really blurry, tv picture is almost black and white. all bulbs are on.
Tv have a problems known as a convergence problems,it dead.Any colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures.The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the convergence board,to solved the convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 13, 2010 | Hitachi 53UDX10B 53" Rear Projection...
My tv has lots of red and green. Faces are shadowed by a red outline. It occurs on all channels and dvd.
If problem does not fix by flash focus/ convergence adjustment in Menu then replace convergence output ICs on D board of tv that sounds defective and causing problem.
Comvergence output ICs replacement requires soldering work with proper tools and electronics knowledge/ experience, call local tech if you have no experience.
Jul 16, 2010 | Sony KP-51WS510 51" Rear Projection...
My tv seems out of focus and has green shadows as well....do you have any idea what could be wrong?
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 15, 2010 | Sony KP-53V80 53" Rear Projection...
On left half of the screen [ KP51WS510 ], a redish shadow showing
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 07, 2010 | Sony KP-51WS500 51" Rear Projection...
The colors aren't matching up I have green semi
Yoy have convergence issue with tv,try the magic focus/touch focus or manual adjustment in the menu under convergence, if can't be adjusted then your convergence ckt is the problem,you will need a tv tech to repair it.
Mar 19, 2010 | Mitsubishi VS-50605 50" Rear Projection...
Sony KP-61XBR200 Convergence problem, when i press auto focus on the front of tv it runs its process then at the end reads (E 14G) the green color makes a bad shadow on the screen. when i cover up the...
one of the covergance chips has died
i replace both when i service a covergance
problem, they cost around 20.00 to 40.00 etch
and there easy to locate inside the tv to
get a part #
Jun 24, 2009 | Sony KP-61XBR300 61" Rear Projection...
Green shadowing
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 06, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Green shadows surrounding bright whites
finally a consumer that gives us plenty of info :)
sounds like an overdriven green tube, the only thing you can try is to find the G2/Focus block assembly, either behind front speaker grill or remove back of set and look for a black box approximately 5"X5" , this box will have 6 philips type adjustment screws(plastic) 3 are for focus, do NOT adjust these,
the other 3 are marked "screen" the center screen adjustment screw is for green, turn it VERY slowly counterclockwise while the set is running and pray that your problem dis-appears, be advised that this is a HIGH VOLTAGE device so one hand in your back pocket the other hand turns the screwdriver, if the problem does not go away you have a poor green tube, good luck, sorry I can`t give you the exact location of the G2/Focus block, manufacturers move them to different places every year.
Nov 29, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Green Shadowing Around Images On Akai PT4398HD
your convergence amp's are defective this can usually be repaired for a few bills. easy fix for a qualified repair person...john
Aug 31, 2007 | Akai PT4298HD Rear Projection Television
Sony KP-48V90 TV Logo
250 people viewed this question
Top Sony Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
