Question about Jenn-Air JCD2389G Side by Side Refrigerator
Jenn air side by side refrigerator ice maker not working
Ice maker not working.
On mine the water inlet feed tube would freeze solid. Removing the ice tray and using a hair dryer to completely thaw the tube would get it working for another month or so. My frig had a solid rubber inlet tube. I noticed at the appliance store that newer models had an inlet tube that was split on top. I got one of these from a local appliance parts store, and it fixed the problem. The tube replacement it easy. Get to the back of the frig. Turn off the water supply. Carefully pry the white plastic piece out ( located on the upper right side when facing the back of the frig. ) of the frig. When you have the new one in hand it will be clear what you are going to do. Pull out the old remove the water line. Attach the line to the new tube and insert it. Turn on water, check for leaks, and you should be ok. This repair is only effective if you have an inlet tube that freezes up. There can be many other malfunctions that stop ice makers from working. This was my problem. Replaced the tube 3 years ago and ice maker has worked fine since the replacement.
Posted on Nov 24, 2008
SOURCE: My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Posted on Feb 13, 2010
docjohn174
  • 943 Answers
SOURCE: JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Posted on Sep 17, 2008
  • 864 Answers
SOURCE: Jenn-Air refrigerator is not making ice but it's dispensing water
It can take up to 24 hours for a new ice maker to make ice.  Check it tomorrow.
Posted on May 31, 2009
  • 40 Answers
SOURCE: I have a Jenn Air JSD2789GES side by side
Check if the water is on.
check if the water filter connected correctly or the bypass.If the filter is new and the appliance is new you should press the water handle or button till the water comes as the selenoid are open during you push.
Posted on Jul 01, 2009
SOURCE: Jenn-Air JCD2389GE side-by-side refrigerator ice
Getting to the more serious water leak problem, it will be likely caused by one of two problems. the first, more common problem, is the solenoid for the icemaker valve is likely stuck open. sometimes particles in the water will literally prevent the solenoid from closing, like jamming a stone between a piston inside an engine cylinder, causing your water to overfill your icemaker, fill up the bucket, and pour through the flapping door that you also have problems with. the second possible problem, is your icemaker itself has stopped, or to be more precise, the motor has ceased up, and it happened to stop at the point in the icemaker cycle when it calls for water. You can check to see if the valve is the problem, by removing the icemaker entirely from the freezer, its held on by 3 screws, or possibly one screw and two metal or plastic clips, also unplug the icemaker from where it connects electrically. Assuming you have the water to fridge turned off presently, turn the water back on, and see if water comes through the fill tube. If it does, the valve is your problem, I suggest replacing both the primary and secondary valves. 12001892, 61005626 are the two part numbers.
If water is not coming out of the fill tube, take a look at your icemaker. Look at the icemaker as it was when mounted, and inspect the center ejector shaft, it runs down the middle top of the icemaker, and has 11 fingers on it, it is what rotates around to eject cubes. Is it in the "home" position, i .e. the position it sits while water freezes. The home position, when looking at the ice maker in its normal orientation, is when the ejector shaft teeth are pointing at 2:00. If the teeth are in any other position, either the ice maker was disconnected during its cycle, or the motor has stopped. To be certain, with the water remaining off, reconnect the ice maker, pour about 8 oz of water in the ice maker, if after 24 hours there is no ice ejected, then you have a bad ice maker. part # D7824706Q
In regards to your flapper door problem. since the path of water went through the door dispenser,its possible you may need to replace electric panel for dispenser. An inconvenient fix is to unplug the connection for the dispenser, located either at the top, under hinge cover, or at the bottom, after removing toe plate.
I fix refrigerators
my website: www.FixMyFridge.net
Posted on Mar 08, 2010
Jenn-Air Side-by-side Refrigeration not making ice and leaks water underneath when ice maker arm is up
With the arm up in the ice tray, the water solenoid valve should be closed. When the arm drops, that tells the ice maker to open the water solenoid valve to fill the ice maker tray. It sound like the leak is at the inlet side of the water solenoid valve. On some models its not easy to get to, but follow the water line to it. Hope this is it for you. Good luck.
Dec 30, 2013 | Refrigerators
Ice maker doesn't work. changed filter. light on ice maker door still on.
You need probably to change the dispenser solenoids which swith water on dispenser
Apr 05, 2008 | Jenn-Air JCD2389G Side by Side...
Ice maker quit working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
fgs65
Sep 22, 2010 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Ice maker will not make ice
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 10, 2010 | Jenn-Air JCD2389G Side by Side...
Ice maker not working red flashing light
heatman101
erty68
Jun 06, 2010 | Jenn-Air JCD2389G Side by Side...
JCD2295HES Side by Side Refrigerator: ice maker not working...
heatman101
utiit
May 17, 2010 | Jenn-Air JCD2295HES Side by Side...
Ice maker not working, just stopped all of the sudden
heatman101
aragag
Jan 15, 2010 | Jenn-Air JSD2789GES Side by Side...
The ice maker in my Jenn Air refrigerator stopped working.
Check that there wasn't a clog in the line after replacing the filter. Make sure you get water going to the solenoid, if so, it may either be a clog in the solenoid or a fluke that it's no longer working.
Sep 10, 2009 | Jenn-Air JCD2389G Side by Side...
May 31, 2009 | Jenn-Air JCD2295HES Side by Side...
ice maker?
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
325 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Jose Pino
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
