Question about Ricoh KR-5 SUPER II 35mm SLR Camera
Lens are not coming out
I put in the 28mm lens and its not coming out no matter what i do i pressed the little button and twisted it the right way but it wonr come out
    Scholar:
  • 185 Answers
Did you put the lens on up-side down? Don't laugh, it happens. If so, hold the lens lock button in (on camera body)and give the lens a quick counter clock wise twist. It should snap out.
If on correctly, turn lens clock wise while pushing in lock button,then with button still pushed in turn the lens counter clock-wise.
Posted on Dec 07, 2008
Film release button is stuck
Hi,try putting a bit more tension on the film using the winding crank & it may enable the button to depress,regards,dave
Apr 16, 2014 | Vivitar Konica Autoreflex T W/hexanon F1.8...
I have a canon eos 20d that has become permanently attached to a canon 75-300 zoom lens. I cannot detach the lens and fear if I force it it will break the camera and/or lens. The lens is more than 5...
Hello!!
Firstly switch off the camera
press and hold the ok button and turn the camera on and off for few times
whilst keeping this button depressed. if it dint work let me know
Regards
Smilemaker.
Jul 08, 2008 | Canon Cameras
Dear sirs; What type of uv filter fits a quantarary tech 10 28mm - 200mm zoom lens. I have several 62mm filters and the zoom lens does not accept the normal threaded screw on format common to lenses
First, make sure that the lens diameter is 62mm. It should say on the front or on the body of the lens. If this is correct, it could be a unique mount that would require a specific brand. If it's quantaray, it might require quantaray filters. If it's an old lens, it might require an attachment to the front of the lens that would act as a filter holder for the square filter tiles.
Jun 04, 2012 | Cameras
We installed a lens onto a N2020 that snapped right in and now it won't come off, any suggestions?
There is a lens release button to the right of the lens mount - make sure it is pressed fully before trying to rotate the lens to remove it. When you press the release button, there is a little pin in the lens mount that is retracted to let the lens turn. If you do that and the lens still does not rotate to be removed (and you are rotating it the opposite direction that you mounted it) then the release button assembly is probably broken and the camera will need servicing.
Nov 07, 2010 | Nikon N2020 35mm SLR Camera
I seem to be unable to change the aperture, the marker points to A on the aperture scale , is this normal the ser no is :228700 Ken
Press down the small button to the right on the green A and twist the f stop ring. This button locks the lens on A
Jul 20, 2010 | Canon 28mm f/2.8 FD Lens
How do you remove the lense? Bought new lense but didn't come with instructions on how to remove the old one.
Switch off your camera before changing or removing lenses to avoid dust being attracted to the sensor
If you camera is a Canon Eos Digital Single Lens Reflex, the lens fits onto the body by being inserted into the 'hole' in the front of the body. To disengage the lens, press the button found at 4 o'clock on the body looking at it from the front and right way up. At the same time twist the lens anticlockwise and the body and lens will separate.
To mount a lens, line up either the red dots on the lens and body or the white rectangle, insert the lens into the recess and twist clockwise until you feel and hear it click home I hope this helps
Feb 24, 2010 | Canon Cameras
My daughter has a Coolpix S210 and when we try to take a picture it is blurry/out of focus. I did a factory reset of settings but it didn't help. Any ideas if this can be fixed or what could have caused...
Take a few pictures with the camera on a tripod or a firm surface. Are they still blurry? Are you pressing the shutter button halfway to allow the camera to lock in the focus before pressing the rest of the way? Have someone watch while you take a picture...do you move when pressing the shutter?
Sep 08, 2009 | Nikon Coolpix S210 Digital Camera
How do i fold a graco duoglider double stroller
do you see the red little button/switch thing on the handle bar? OK, put your right hand on the handle with your thumb resting on the little red button. Now with your thumb, slide the little red button thing in towards your hand (slide the red thing to the right). Still holding the button in, twist the grip of the handle bar (where your hand should already be sitting) away from you. if you can imagine giving a motorcycle gas, you would twist the handle back, right. Twist the opposite way for this. So, on the stroller just press the button in, twist the handlebar grip FOREWARD, give it a little push (think up & over) and the whole thing should just collapse down neatly. it should colllapse sown until you hear a click. this is the lock latching together to hold it closed. next time you need to open it the lock is located on one of the sides. all you have to do is release the latch which is also a bright red. should be easy to locate. hope this helped you out. if you need further assistance i'm mushroombunny@yahoo,com good luck.
Aug 10, 2008 | Graco DuoGlider 7924 Twin Seat Stroller
Ricoh KR-5 SUPER II 35mm SLR Camera Logo
52 people viewed this question
Top Ricoh Photography Experts
Lyle Siemens
Lyle Siemens
Are you a Ricoh Photography Expert? Answer questions, earn points and help others
