Question about Hitachi 60FX32B 60" Rear Projection Television
1997 60in. Hitachi 60FX32B rear projection television
I can turn television on and then it will cut off after about 5mins. then you here 3 clicks after another 5 mins. then it will come back on for awhile.I go through that about 2times then it stay on.
  • 16 Answers
SOURCE: hitachi 60fx32b rear projection
When you turn on the TV do you hear 3 clicking noises then the TV turns off?
Posted on Jan 12, 2008
  • 18 Answers
SOURCE: Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Posted on Jan 05, 2008
SOURCE: Hitachi 51F59A Color/Dark problem
Could be the blue CRT shorting out. I had the same problem but with red. Eventually it shorted out completely. If it is only 2.5 month old it should still be under warranty and they will fix it.
Posted on Feb 27, 2008
  • 4234 Answers
SOURCE: Hitachi 43VWX10B Rear Projection Television - color adjustment problem
Either the pins on the convergence ICs need to be resoldered or the ICs need to be replaced. These are large black ICs attached to a heat sink and should be marked STKxxx. Resolder first. If that does not resolve it, replace the ICs.
Dan
Posted on Mar 17, 2008
mrlobsterbob
  • 22 Answers
SOURCE: Color Problems with Hitachi projection screen television
check the bulbs
Posted on Oct 20, 2008
Focus hitachi 60fx32b was watching this tv and it suddenly turned off and wont power back on
Try to plug it into a different electrical socket and try it without any extension cords or power strips (sometimes the socket or extension cord is to blame)
Oct 19, 2013 | Samsung PCJ522R 52" Rear Projection...
Need new bulbs and the price
model listed uses picture tubes and has no bulbs..what is problem and confirm model number please
Apr 07, 2012 | Hitachi 60FX32B 60" Rear Projection...
Hitachi 60fx32b out of focus how can i fix it
If not a convergence issue: each tube (back of set) has a large black lens with a wing nut on side----loosen nut and rotate lens slowly until red is in focus.
Feb 19, 2012 | Hitachi 60FX32B 60" Rear Projection...
BLOWN RESISTORS
you can download your schematic that will tell you resistor values and the rest of the circuits and IC indentifications as well as test procedures and more , this is a ten part zip that can be opened with winzip and read with adobe just click here http://www.eserviceinfo.com/downloadsm/12926/Hitachi_50FX30B.html
then to order resistors you can get them here http://www.nteinc.com/
or look for an electronic parts supply store around you , but alot of the time they too have to order the parts, ecspecially certain valued resistors or other special valued parts
if you need more help just ask !
Dec 11, 2008 | Hitachi 60FX32B 60" Rear Projection...
Tune up for Hitachi 60FX32B
Remove rear cardboard cover....can you see tops of red / green /
blue tubes ? Clean lens' with soft , dry cloth......Do you smoke ?
If not , replace back. Picture should now be clearer but not
necessarily brighter.......Next, remove front speaker grill and find
the RGB focus / screen adjust block....turn RGB screen controls
SLIGHTLY clockwise to achieve more brightness....not too much
or you will have retrace lines in background of picture.......Let me know after these steps are done........T.
Mar 02, 2008 | Hitachi 60FX32B 60" Rear Projection...
Hitachi 60fx32b rear projection
Jan 12, 2008 | Hitachi 60FX32B 60" Rear Projection...
No picture
Replace vertical output IC and check soldered in pico fuses...T.
Hotachi 60 model 60fx32b
I hope thats a typo and you meant 2 (two) inches on the left side. Have you opened the small door on the front and hit the "magic focus" button yet? NOTE: be sure to turn on the set and let it run constantly for 20 minutes before pushing the magic focus button, once it starts do not push any buttons it will go through all 3 colors and stop on it`s own when it`s completed, if you don`t have bad IC`s this will fix your problem, good luck
Nov 26, 2007 | Hitachi 60FX32B 60" Rear Projection...
Hitachi 60FX32B picture
Replace vertical output IC with first quality part,check caps
in vertical power supply......If you don't have access to parts,
then solder pins of IC,should hold for awhile.
If you need further assistance, let me know.....T.
Oct 26, 2007 | Hitachi 60FX32B 60" Rear Projection...
Televison & Video Logo
53 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
