Question about Microwave Ovens
The fuse blows when i plug the microwave in with the door closed
My emerson microwave mw8992rd recently blew its fuse. I purchased a new fuse. The problem is when i plug the microwave in with the door closed it blows the fuse. If I leave the door open and plug it in it comes right on with no problems until I close the door and then it blows the fuse
    Problem Solver:
  • 7 Answers
First you gotta detach the button plate ( the thing with all the buttons) using a flathead screwdriver .Keep pushing it is stuburn. It will pop back in when you are done. the fuse is behind that. just take it out and put the new one in.
Posted on Jun 28, 2009
Microwave keeps blowing fuse as soon as plug into wall receptacle.
Just to clarify: With the door closed, the fuse will blow as soon as you plug the unit in? Have you checked all three microswitches? One acts as a crowbar.
Dec 27, 2017 | Microwave Ovens
About my Emerson microwave oven; What can cause the fuse to blow in my microwave oven?
That would be a problem with a door switch, door switch mount, or hinge.
See my help file on door switches here:
http://www.microwavecontrol.com/doorsw.txt
Oct 01, 2016 | Emerson Microwave Ovens
Microwave blows fuses
A short likely in the wiring for the light or at the safety switch embedded on the side where the door closes----be careful as a 20 amp fuse takes something major to take out.
(for it to blow)
This might be best left to a qualified service person.
Dec 22, 2012 | Microwave Ovens
My microwave lights blinked off right after i closed the door after checking meal and re-entering time. i unplugged it and tried a different socket nothing happens no sound lights for time or inside the...
I suspect the interlock monitor switch in your microwave oven is the culprit. This is one of several switches operated by the door latches. It's designed to blow the fuse if you try to run the microwave with the door open. The switch is probably stuck, or is out of adjustment (which can happen if the oven door gets closed hard), and when you restarted the oven it blew the fuse. It is possible to adjust or replace the switch as necessary, but it might not be worth it. You should have a professional do the repair as there's a chance of microwave leakage if repairs involving the door aren't done properly. Between labor and parts, the repair cost might come close to (or even exceed) the replacement cost for a small oven.
Hope this helps, and thanks for using Fixya!
Nov 09, 2010 | Emerson MW8778 Microwave Oven
I have an Emerson MW8992RD model and just opening the door blows the fuse! any idea ,could it be a bad door switch? if so where can i purchase a new 1?
Definitely sounds like a defect or misadjusted door switch. This site has venders of M/W parts. FYI,Federal law requires a leakage test after door repair, magnetron replacement or interlock repair.
Jun 20, 2010 | Emerson MW8987B/W Microwave Oven
Need to replace the glass tray for Emerson Microwave Oven model #MW8992RD
Glass tray replacement for the Emerson Microwave MW8992RD has been discontinued.
Oct 06, 2009 | Emerson Microwave Ovens
Emerson Microwave (mw8992rd) not heating up
I have replaced the main fuse on this model. Though blown main fuses are common in this model, it will not even turn on when they blow, so your problem is most likely NOT a blown fuse. I had heard of your problem so, when replacing the main fuse inside one, I looked for additional fuses and saw none. The store was wrong. Even if it were a fuse, the security Torx screws mean that you couldn't replace the fuse anyway.
This microwave seems to have been haphazarly been recommended by Consumer Reports, but it is terribly unreliable. The turntables break when popping popcorn, the main fuse repeatedly blows, and they also stop heating.
Oct 19, 2008 | Emerson MW8985W Microwave Oven
Emerson MW8119SB microwave wont stop running with door closed
It should have a one-year warranty on parts and labor.
I'd call Emerson at 1-800-695-0098 to find your nearest authorized service center to have it fixed free.
It's probably a bad door switch or door switch mount.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 22, 2008 | Emerson MW8778 Microwave Oven
Blown Fuse
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
Apr 01, 2008 | Emerson MW8775W Microwave Oven
Microwave Oven
Yes , i got this very microwave from a neighbor down the street who threw it away.When i plugged it in nothing happened or lit up.I removed the cover and sure enough it was the fuse blown.I replaced with your average buss type 20 amp fuse and it has worked ever since..I was going to write them a note thanking them for throwing it away:) i really like it.
Sep 08, 2007 | Microwave Ovens
Microwave Ovens Logo
287 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
