Question about Sony PlayStation 2 Slimline Console
My Play station Slim won't read the disc
When i start up my play station it wont read the disc and the lens don't move
  • 1 more comment
  • rishishah749 Nov 19, 2008
    Yep i've got the same problem!!
    my slim will ONLY read the disk if i put pressure on the lid! :|
    someone help!!
  • Anonymous Nov 21, 2008
    i have a similer problem, my slim ps2 doesnt play over half the games i have for it and on the ones that dont work it will either show just a black screen if i put the disc in before turning it on and if i put it in when its on it forever stays on reading disk
  • Anonymous Dec 26, 2008
    my playstation 2 slim wont read any discs,all it says is no data.
    Scholar:
  • 70 Answers
Clean the lens with a Q tip and alcohol,if you have to push down on the top of the playstation then you may need a new spindle motor. If the laser doesn't work after cleaning,then replace it either professionally or with someone who already has done it before.
If the laser doesn't move at all,or even pulsate a beam then it is surely defective,or the data ribbon to it has been disconnected.
A digital camera will be your best friend if you are a DIY'er
Positive feedback is a good return if this helps you.
Posted on Jul 08, 2009
My play station will not read the disc
depending on the play station you might have a defective laser for example if you hear a clicking it cant be fixed but if you don't you should by a laser cleaner disk id suggest something like this http://shop.digitalinnovations.com/CleanDr-Playstation-Laser-Lens-Cleaner/dp/B00419ZT4I?ie=UTF8&id=CleanDr%20Playstation%20Laser%20Lens%20Cleaner&field_product_site_launch_date_utc=-1y&field_availability=-1&field_browse=3219
Dec 28, 2011 | Sony PlayStation Video Game Consoles &...
Wont play game disc
What disc are you putting in?
Mar 19, 2008 | Microsoft Xbox 360 Console
Wont play and we had tied everything
Hello, welcome to Fixya!
Was this player playing previously? And how long have you been using this player? I suspect the lens of the player. Once the lens of the player becomes weak, it won't play discs any longer.
The first thing my mind goes to, is the lens. The lens id responsible for reading/loading data on discs. So if the lens is unable to read the disc, there is no way the player is going to play the disc.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or probably, a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Nov 03, 2011 | RCA DRC627N Portable DVD Player
My PS2 Slim wont spin and read disc.
There are two main problems to be listed for this issue.
There might be a problem with the lens or the disc might be dirty try with some other disc. Still you face the same problem you should change your lens.
Any local Play Station repair guy can fix the lens.
Dec 20, 2010 | Sony PlayStation 2 Slimline Console
My PS2 is not loading Grand Turirsmo 4!
If your PS2 works fine with most of the games and won’t play a few..Then you should try this trick to play them too on your PS2:
  1. Turn on your PS2 without inserting any disc.
  2. Menu screen will appear like:6e4cb56.jpg
  3. Press the (triangle) Button to enter Version Information Menu that looks like9d90dc8.jpg
  4. Highlight the Play Station Driver as above and again press (triangle).
  6. Highlight the Disc Speed as above and press X button,to enter Disc Speed Menu
  7. And set it from Standard to "Fast".
  8. After you set Disc Speed to Fast, Press and Hold Reset Button to turn off your console.
  9. Then again Press and Hold Reset Button till the Blue Light turns on.
  10. Remove the Reset Button and Press it again.
Be patient and wait till the game loads itself. If your lens is in good condition then it will play game in first go else try again till it PLAY your game. If still your Grand Turismo 4 DVD wont work then you must clean your PS2 lens.Watch following video to learn about cleaning lens:
Thank you and Good Luck!
Dec 16, 2009 | Sony PlayStation 2 (PS2) Console
Play atation 2 slim
I Had To Take Apart My PS2 nd Clean The Disc Lens With A Q-Tip that Had Rubbing Alcohal On It
Dec 25, 2008 | Sony PlayStation 2 (PS2) Console
MY PS2 READS GAME DISC BUT DOES NOT PLAY
Which version of the ps2 do you have big or slim? what model?
Dec 12, 2008 | Sony PlayStation 2 (PS2) Console
Sony PS2 station wont play
moisten a microfiber cloth with isopropranol alcohol and clean the lens and black rubber ring on the top surface of drive motor
and also clean the surface the disc you are tring to play then retry dvd.
you can clean lens with canned air also
Jan 02, 2008 | Sony PlayStation 2 Slimline Console
Disk wont spin
First of all the new laser lens will not allow your Slim to read NTSC UC games if you have a PAL european Console.
There is no reason the New laser should have not read the disc unless it Came to you damaged. It sounds like you know how to replace a laser.
Sep 13, 2007 | Sony PlayStation 2 Slimline Console
Read Error (With FFX game)
Hi Raven, Its sounds like you have a PS2 Slim with a melted Laser. What you will find is that the Slim will only read CD's, CDR's, PS1 Games, Blue back PS2 games and DVD's. I can repair this for $35 plus shipping to and from The Playstation Clinic in Fountain Inn, SC. The webpage is www.playstationclinic.com If you do not have a Slim, you either have dirty disc, or Lens. You may have left some fibers from the Q-tip across or around the lens.
Sep 10, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 Slimline Console Logo
253 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
