Question about Sanyo AVM-2759S 27" TV
TV Picture is tinted pink
Have a 11 yo Sanyo TV- last week, turned out TV and picture was all pinks; instead of Black/White, was a pink wash over black/white. Tried changing color/tint with controls- nothing changed on picture. Last night for a few minutes seemed like color might be back to normal (or maybe a little greenish tint to the color picture), but went back to all pinks. Is this the end for the TV? Is it worth getting someone out to the house to look at it? Thanks
snakehead
  • 1074 Answers
SOURCE: My picture is tinted green.
could be that you have speakers around the tv check to see if that is so. and remove the speakers.good luck.
Posted on May 18, 2007
  • 556 Answers
SOURCE: Sanyo Tv color problem
Hello, The TV is four years old. About two weeks ago the screen suddenly had a complete red tint. I tried adjusting the color settings but nothing really improved. the next time I turned it on, it was fine. But the time after that it turned red again. Now it more and more often has a deep red tint. Any advice? Thanks please do not adjust any thing. your problem is in red color cathode ckt it might be loose contact in red cathode. crt base might be loose. check red output supply. signal line from chroma ic to crt base. regards thanks
Posted on Sep 11, 2007
ladywinn
  • 5138 Answers
SOURCE: white screen & sound
Bad CRT board.
Posted on Dec 01, 2008
bernardlunda
  • 318 Answers
SOURCE: Sanyo 68cm. AV1 is Black and White. AV2 and normal Tv is OK
the two AV1 and AV2 have different inputs on the IC,
the first port has a disconnection,
take your tv for a check up
Posted on Apr 24, 2009
AJIN G
  • 6694 Answers
SOURCE: I have a Sanyo TV Model #DP50842 50 screen black no sound no picture/I took back off of TV fuse intact bought multimeter/How do I use it to check all components on panels
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Posted on Jan 10, 2017
Entire screen has a pink tint. Can change to blue with settings. Cannot change to natural with tint etc.
Check that all cables are intact and plugged in correctly.
Turn of the TV completely. There might be a manual button on the tv for this. As the last thing, remove the power cord from the power outlet in the wall or where it is placed. Wait 1 min. Then put it back in, swith it on and turn on the TV again.
If this doesn't help and you have tried replacing the cable that you get the picture from (VGA, DVI, Antenna etc.) then it is most likely broken.
Jul 06, 2014 | Sceptre X400BV-FHD 40 in. LCD TV
I turned on my TV and the whole screen has a pink tint
If using a box for signal disconnect it from power for a while to see if when it reboots this issue is gone or not.
Nov 28, 2012 | Samsung HLP4663W 46" Rear Projection HDTV
My hitachi 43fdx20b has a pink tint to it. I have noticed that if i move the tint slider one way or the other it will turn the screen green, but now it doesn't. Does this have something to do with my...
My 43fdx20b had a pink tint to it also. The picture was clear otherwise. I found, on mine, I needed to adjust the Red Screen control. It was located behind the front panel. I removed the two screws on either side of the front panel and was able to remove the panel. Then I adjusted the Red Screen control. I found that if I tuned in an old Black and white movie I could adjust the color fairly accurately. Good Luck.
Jan 02, 2010 | Hitachi 43FDX20B 43" Rear Projection...
16 year old, 36'', analog TV, model CX35E60, with Charter cable service. The picture has a pink tint when first turned on. The pink tint lasts several minute and then will correct and the picture will be...
Your picture tube is on its last leg. Best enjoy the old girl while you can. This would be way more expensive to repair than it is worth if you can still find a tube for this set. That has been a good set to last that long. Not too many of them left out there. Thanks for using fixya.
Nov 09, 2009 | Toshiba CX35F60 35" TV
White colors come out pink and the wth bal is auto
I replied your question about pink tint noise in picture.
Jan 06, 2009 | Sony Cyber-Shot DSC-F717 Digital Camera
depending on how much you paid for the tv , the cost of the repair may be more than the tv is worth. but if this is a large tv , then the repair would be most likely worth it
Dec 29, 2008 | Televison & Video
Canon powershot S410
a pink tint CAN be removed in Photoshop or picasa.
Check the settings in your camera. it could be set to "sepia" under effects.
Jul 23, 2008 | Canon PowerShot S410 / IXUS 430 Digital...
Samsung tv settings
it depends on what your using it for, adjust colour tones to what you think looks natural, contrast between 80-90, keep sharpness below 30. just have a play around till you find what best suits the source material.
Mar 25, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Sony FD Trinitron WEGA KV-24FS120 24" TV Color changes
Try turning down (off) the color during such an episode. If the image is tinted pink or green instead of black and white when you do this,you have either an intermittent short in your CRT (tube), which is terminal,or a gun drive problem, which may be repairable. If you're feeding it component instead of composite signal,it may just be a bad connection of the B-Y cable.
Mar 19, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Pink screen
Is your grey scale or Black and white programming pink?? Thats an indication that the green and blue grids on the picture tube are week or that the red is over driving. First thing is take off the back of the set. Find the end of the picture tube and look at the printed curcuit board there. see if you can find and red drive controls there. Put on a black and white pic and ever so slowly rock that red drive control a little at a time till the picture looks almost normal.. If you get it to be a little \less pink then stop right there but if it starts to get a bit green or blue then try rocking those controls all back and forth till you get the bese B&W picture you can BUT BE VERY CAREFULL as there is alot of voltage on this picture tube and if your not carefull it will bite ya. Now dont be too critical as the tube is a bit weak so you probably wont get a perfact grey scale so if after a while live with it or get a new set. Good Luck.
May 02, 2006 | Jensen Q2749J 27" TV
Sanyo AVM-2759S 27" TV Logo
97 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
