Question about Philips Magnavox 42MF521D/37 Television
Vertical shadow on screen
I have a Magnavox 42MF531D LCD TV, it's about 2 years old, just started noticing a vertical shadow, about 12in. long and 1/4in wide going up the screen. It's not exactly straight, it looks like a long hair on the screen. What is it and can it be fixed?
  • 2 more comments
  • pinkcar13 Nov 20, 2008
    Thanks edgardbe, but I'm not very knowledgable with this stuff, is this something I can do or should I call someone? thanks
  • ferguse Dec 18, 2008
    Have a Magnavox 42MF521D LCD TV, it's 2 years old, just started noticing a vertical shadow, from top to bottom on the right hand side of screen. It's not straight - more of a curve ")" and now a second one is starting to the right. Can this be fixed?
  • calvertsr Jan 10, 2009
    Wow!!! This must be a shortcoming of this model. I also have one about 2 years old and have the exact same issue.
  • calvertsr Jan 12, 2009
    Has anyone contacted Philips/Magnavox? I have not had good luck with this in the past, since their products seem to have issues or die after the warranty is up. Not sure why I bought another one of their products. Guess I'm not that bright. I think next time I will go out of my way to not buy one of their products.
    Problem Solver:
  • 3 Answers
Check the vertical transistor or bouton.
Posted on Nov 20, 2008
Bottom of screen purple "haze"
Check the site linked below, and see the screen shots of defective LCD TVs, Surf it with patience. This should be a panel fault I assumes. http://electronicshelponline.blogspot.com/
May 20, 2013 | LG 55LX9500 55 in. 3D HD-Ready LCD TV
3" vertical shadow on left side of screen
Either (on this plasma) a damaged/bad sustain board for left side of screen or a problem with the Display panel--set by model number is 5-6 years old so may or may not be worth fixing.
Apr 10, 2012 | Panasonic TCP50S2 50 in. TV
Samsung 46" LCD LN46B650 started showing vertical
had a very similar situation with my Phillips 42 in. LCD TV.
Here was my Problem. The Power Supply Board. I opened it up( Warranty was Expired) and found several faulty capacitors on the PSB. Its pretty common. Major Electronic companies were sold faulty capacitors that fail in 2-5 years instead of 10-20 due to a lack of preservatives. It wouldn't surprise me if you have the same problem. TV will work fine for a few years and then just fail completely or slowly deteriorate.
Here are the solutions
1. Have it Repaired
2. Check for faulty caps and if you find some(budged or leaking) you know you have located a problem
Remove the board and replace the whole thing.
3. If you have some soldering skills you can replace the faulty caps.
Caps are very inexpensive, under a dollar in most cases. I replaced 4 for about $5.00
Hope this Helps.
Good Luck
Dec 10, 2010 | Samsung LN46B650 46/49.5 in. LCD HDTV
47 inch Toshiba LCD REGZA TV - screen has what looks like water stain or "woodgrain-like" shadows/artifacts. They go sort of vertical but are not straight, (look like wood grain shadows). Not real obvious...
The only way might solved this problem,to replaced the Tuner Signal board.If the board is replaced have same problem,then ur tv have some kind of dead pixels burns in.Tries Shopjimmy.com,Ebay.com for the board part.
Feb 04, 2010 | Toshiba REGZA 47HL167 TV
Vertical line and shadowing on samsung 32"lcd tv
Clean the connectors from the main to the Tcon along with the flat cables that go to the panel, next would be repalce the tcon board,if that doesn't fix it you may have a bad panel
Dec 28, 2017 | Samsung 32 in. LCD Monitor TV
Shadows on screen
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
Jan 04, 2009 | Sylvania 6626LCT 26 in. LCD Television
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Magnavox 42MF531D black screen
Common issue I have come across when using any TV as a PC monitor. Best workaround i found is just dont change inputs or reboot the PC and the tv will pick it back up.
Sep 01, 2008 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Lcd tv screen shadow
they call that line pixels and the only way to fix is a new lcd panel. if you have under 8 pixels your warrinty won!t cover with some companys
Aug 31, 2008 | Sylvania 6427TE 27" TV
Shadow on screen
your vertical ciruit is malfunctioning
May 26, 2008 | Protron PLTV-32 Television
Philips Magnavox 42MF521D/37 Television Logo
584 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
