TWO LOCAL DRIVES INTO ONE
MY INSTALL DISK MADE TWO LOCAL DRIVES. DRIVE C AND D. I WOULD LIKE TO KNOW IF I CAN MAKE DRIVES C AND D JUST ONE DRIVE C WITHOUT REINSTALLING WINDOWS XP. IF I CAN NOT, HOW CAN I USE DRIVE D OR WILL IT BEGIN USING IT WHEN DRIVE C HAS NO MORE ROOM. THANK YOU
  • Anonymous Nov 21, 2008
    whats is the steps of making two local drives into one?
  • angel rodriguez Feb 27, 2009
    "whats is the steps of making two local drives into one?" from guest. THATS MY PROBLEM. UNDER "MY COMPUTER" HARD DISK DRIVE, IT SHOWS 2 HARD DRIVES, I ONLY HAVE ONE IN THE TOWER, AND IT SAYS LOCAL DISK (C:) AND (D:). HOW DO I MAKE THAT ONE LOCAL DISK.
  • 4,806 Answers
Drive "D" should be your optical drive (DVD/CD) you can check this by double clicking on my computer, if the size of the disk (c:) corresponds to what you installed then you have done nothing wrong
Posted on Nov 16, 2008
  • Lee Hodgson
    Lee Hodgson Feb 27, 2009
    Ok, that explains it a little more, you have 1 hard drive partitioned up into 2 drives, "C" drive and "D" drive the optical will be "E" .
    The reason the drive has been partitioned like this is so you can use drive "D" as your storage drive for things like movies, music etc and that drive "C" which holds all the boot information for the operating system, a few years ago drives were not partitioned like this and when the operating system degraded or went down they would loose all their data and it would cost a fortune for data recovery, so the partitioned up drives where if the OS went down no data would be lost if the OS had to be recovered.
    If you want to delete the partition, right click on computer, select manage and then disk management, from in there you can delete "D" section, you may have to download a special partitioning tool to add the free space to "C" drive.
    Its not really recommended that you delete the partition while the OS is in use as certain "registry" entries could cause havoc with the OS.
    The best way to do this is start from scratch with the install or recovery disk to delete both partitions and create just one.
    Good luck and thanks using Fixya!!!
I can't access my local disk (D), it says drive need to be formatted.
D drive is usually the CD/DVD on most computers. C drive is your hard drive.
Jul 04, 2013 | Samsung HDD 250GB SATA 3,5" HD252HJ SATA...
I can't open my buffalo drive
Hello fradymg,
If you are speaking about a hard disk drive built within the last 20 years, then the hard drive is not meant to be opened.
(Way back in 1975 I worked on hard disk drives that could be repaired or adjusted by a qualified technician).
I have three suggestions:
(1) I presume the drive is already out of the computer.
  • Buy a new hard disk from a local computer shop.
  • Install the new one.
  • Connect the data cable.
  • Connect the power cable.
  • Switch on the PC;
  • Insert your Operating system CD and re-install the OP system.
(2) If the data on the drive is *very, very* important:
Take your drive to a good computer shop and they will attempt to recover the data.
Note: this is generally VERY expensive.
(3) Take your computer to the computer shop and have the technician install the new hard disk and also the operating system.
This option will give you a working computer in the shortest delay, at only medium cost.
Hope this helps.
Dec 13, 2011 | Computers & Internet
I have got a big problem for my wdc wd6400aaks hard disk. Few months ago i separated hard disk into 4 partition (named as DATA, Install, Slave and Local disk). But XP2 had auto numbered my partitions and...
Hi, Thanks for using fixya.
Right click on My Computer/Computer choose manage. On the left side make sure storage is expanded double click disk management, on the lower part find your Drive you want to change right click on it choose change drive letter and paths. Click on change, You will see a drop down arrow click that choose the first available letter, Now click on change. Do this to all of the drives you want to change Open My Computer/Computer see if it is now listed the way rou want it.
Ps you can't change the c drive if it is used as the operating system storage.
Terry
Feb 13, 2011 | Gateway (M520HD80G) Hard Drive
HI,I'm Loren and I want to ask you a question.My dad bought me a 2TB G-Drive and I don't know how to install it on windows OS.I turned on the G-Drive and after 10 seconds I turned on the computer.I opend...
Shutdown the computer.
DIsconnect the G-Drive.
Restart your computer.
After Windows is fully running, reconnect the G-Drive to a USB port.
Windows should "beep" when it recognizes the new USB device.
Now, open "My Computer" and right-click to select "Manage" and open "Disk Management (local)".
You should see an image showing the drive as being "unpartitioned".
Click on that image to initialize the disk-drive, and to assign a drive-letter.
Nov 10, 2010 | G-Technology G-DRIVE (90801201) 250 GB...
In fifa 10 when i click standard installation there is local disk C and D.and when i click to local disk D it can't start to install.
You need to install from your CD/DVD drive. These drives can be any letter in the alphabet after "C". Perhaps your drive is "E" or another letter. It should be listed as a "Removable Drive" in My Computer.
Aug 12, 2010 | Computers & Internet
Server XSeries 220
Yes, that is the total amount of hard drive space.
This server was built for speed not for storage.
The xSeries 220 server supports four SCSI hard disk drives. The server does not support IDE hard disk drives. Some models support hot-swap hard disk drives and other models support only non-hot-swap hard disk
drives.
Your server supports four 1-inch (26 mm) slim, 3.5-inch SCSI hard disk drives in the hard disk drive bays. You can install four non-hot-swap hard
disk drives in the models that have the standard non-hot-swap drive cage. You can install three hot-swap hard disk drives and one on-hot-swap hard disk drive in the models that come with the hot-swap drive cage. Both the non-hot-swap and hot-swap drive cages hold a maximum of three hard disk drives.
The calculation at that time was 4 drives with 36.7GB storage.
Even if you find the drives somewhere, they will be very pricy.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Oct 28, 2009 | IBM xSeries 220 (86451SF) Server
I WANT TO INSTALL LOCAL DISK D ON MY COMPUTOR?
i lose my local disc d in my komputer,my dvd rom can read a disc.how can i instal
Sep 16, 2009 | Dell Dimension 4600 PC Desktop
CD drive does not recognise my discs(Sims 3)
Sims 3 comes on a DVD-ROM, therefore you need a DVD drive on your computer rather than a CD drive. As a test, take a disk that you know is a DVD (like a store bought or rented movie) and see if you can read that on your computer. If you cannot, then you probably have only a CD drive in your computer. DVD drives are inexpensive and easy to replace. You can purchase one at a local computer store.
Jun 05, 2009 | Evesham Computers & Internet
Installing the external drive
In XP and Vista no need to install.
They will detect automatically.
To know, goto Windows explorer.
Find drive letter other than your local drive.
Usually called "removable disk".
Dec 26, 2008 | Maxtor OneTouch II external hard drive...
Windows
I've just installed the same type of hard drive in my PC running win XP and have no problems.. do u know that you need to format the disk before it will show up with the other accessible drives?
what to do is - click start, right click on my computer and go to manage.. then double click on storage, disk management local.. and it should show up here, once you format it your all set..
No need for drivers, windows has them already, it's all generic one's the windows is familiar with..
Hope this helps!
Dec 16, 2007 | Seagate Barracuda 7200.9 ST3400833AS 400GB...
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
