Question about Fisher PC-32S90 TV
Thin white line across center of screen Fisher PC-32S90
There is a thin white line across center of my TV screen. It is a Fisher PC-32S90. It appears to be a connection issue with the video input or a least something in that area on the back of the TV. Maybe something is loose. In past if I wiggled the cable input, the TV would go back to normal, but this easy solution no longer works. I have tried different ways to input a signal, and the same thing happens with all input methods. The sound works fine. Thanks in advance for any help on this.
    Champion:
  • 252 Answers
Yes there's a lose connection of your tv. It needs to re solder.if you know how to solder .,solder the vertical section specially the vertical I but be careful of short circuite coz it may damage your tv set.
Posted on Nov 16, 2008
White line across screen
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sony 46 KDL46EX523 LCD TV
White thin line running across horizontal on my hp laptop
You got a bad LCD screen. no immediate resolution aside from getting the LCD replaced. if your system still has warranty call Dell for replacement.
Hope it helps!
Feb 18, 2010 | Dell Inspiron 9100 Notebook
No audio and have a thin white verticle line across tv
Always suspect a bad EEprom...very common on this TV! See a tech, he will have to select one of six eeproms to fix this!
Jan 10, 2010 | Philips Magnavox 27MS343S 27" TV
Thin white line
I think you have a power supply problem and that one of the supply lines is down it will need a technician to solve this problem.
SUPER8
Jan 02, 2009 | Philips Magnavox 27MS343S 27" TV
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Thin horizonal line in middle on dark screen
The several thin white lines at the top of the screen is the warning that the vertical output IC is not getting the boost voltage it needs to run correctly. The IC cannot operate for long like that and shorts out inside, which is when the vertical collapses altogether and you get the thin white line through the center of the screen. The good news for your son is that he had nothing to do with that, and it has nothing to do with the cable F connector. The set needs to be serviced by an experienced tech who will restore the boost supply and replace the vertical output IC, and when I do that I charge $75 but techs in your area will vary, so be sure to ask around.
Jul 26, 2007 | GE 24GP653 24" TV
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
White Lines in picture
your problem is common for sanyo and fisher tv's the B+ feed capacitor is defective and maybe the waveshaper in the cuircuit right next to the IC. Your probably gonna need a service manual to find these caps as if you get one from sams photo facts post the vertical here and I will show you the capacitors to change. Done it a hundred times but I dont remeber the #s. Old age I guess. Good Luck
Apr 24, 2006 | Sanyo AVM-2759S 27" TV
Fisher PC-32S90 TV Logo
301 people viewed this question
Top Fisher Televison & Video Experts
matt martin
matt martin
Mike
romy sibug
romy sibug
Are you a Fisher Televison and Video Expert? Answer questions, earn points and help others
