Question about Dell UltraSharp 1900FP 19" Flat Panel LCD Monitor
Extreme ghosting Hello! I'm trying to decide whether to buy a second hand Dell 1900FP 19" TFT monitor (manufactured 2/2002) which according to the seller has been trough some difficulties: For some reason there started to be "extreme ghosting" in the screen, meaning that in the end even the mouse cursor started to create a trail. The outcome of the ghosting resulted in a virtually unreadable screen full off color mush (slightly non-technical term). After trying to repair it and not finding any problems he reassembled the unit and found out that it didn't power-on anymore. Dear gurus of computer technology, what do you think? Should I buy the unit (for a very cheap price) or is it beyond repair already...? Thank you very much in advance. I hope I would be able to give you more information.
  • Kimmo Virtanen Nov 26, 2006
    I'd like to add that by ghosting I mean that the screen leaves a residual image of all that it displays (to the power of 1000). It's like a graphical memory effect. Maybe something to do with refresh rates...?? I've seen maybe similar with my PDA when it crashes ( :) ), the screen starts to fade to white. Though In this problem the seller only said that thing about the ghosting.
  • NickHill Dec 13, 2008
    I got one of these monitors and it seems to have the same problem discussed here. It powers on, and will find the signal going to it and even show a picture, but the picture is extremely slow. It displays as if the pixels aren't being energized/deenergized quick enough which results in extreme trails. Is there any solution to this? Is it most likely a problem with the boards that provide the signal/power to the LCD itself or a problem with the LCD panel? I have disassembled the monitor once and didn't notice any burnt out capacitors, but that was just a visual inspection.
    Thanks,
    Nick
  • 472 Answers
From where I sit, understanding LCD's and all thier quirks I would buy it.
From where you are with your technical terms you can go 2 ways.. both good.
If you can get this cheap and have no expectation of getting it to work, it could be a valuable learning tool for you in future screens.
Secondly, you could open it up and find a few dead capacitors that have been messing with the power supply to the panel and causing the issue, correct it for a few dollars and get it running again.
Like I said, it's really a win win as long as you accept before you do it that it may just end up being something to help you later on.
Posted on Apr 08, 2008
Dell 1900FP flat panel color monitor the on screen display wont go off
try to remove power lead for a minute or two and put it back in. Should be better.
Apr 07, 2014 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Lock keeps flashing on monitior
Eve,
To get the lock to go off the screen you can press and hold the monitor Menu button for about 10-15 seconds.
Thank You,
Dell-Jesse L
Dell Social Media and Communites
Apr 06, 2014 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Dell 1900 fp monitor driver
Go to GOOGLE and type DRIVERS for your exact product and model of monitor, which will hopefully give you the correct drivers to download. Softonic would be one place to look. CNET would be another.
Sep 19, 2012 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
MY DELL 1900FP WILL NOT POWER ON
Open and look at the tops of the capacitors. I bet there are at least 2-3 "bulging" tops. Replace them and the problem WILL be solved;.
Apr 07, 2011 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
My dell went off after few seconds, the power light is still on. I checked inside and saw the transformer EPC-19 sparking. on the side of epc-19 there is another number : 0101NH25G. Please tell me where or...
Only place I can find them is to go to ebay and type epc-19 in the search bar. They have some in stock for $20
Also many dell monitors have a 3 year warranty standard...it's worth calling 866-876-3355 and ask them if the monitor is indeed under warranty or not.
Jul 15, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
Monitor not working after adding drivers
1. turn off your computer
2. turn off your monitor
3. Unhook the power and video cable from both
4. Reseat them both on both ends.
5. Turn on your monitor
6. Turn on your computer
If its still doesnt work after all 6 steps, your monitor is bad, sorry.
Apr 02, 2009 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Dell 1900FP
you can push every lamp from 19inch monitor who have same jack for conector{i work that, i have dell1900fp}!!!sorry for eng.good luck
Sep 28, 2008 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
No power dell 1900fp silver blank screen power ??? help!!
try swapping the computer power cable and don't connect the vga cable with the system. if you get a power on self test displayed it makes sure that the monitor is fine. if nothing is displayed you can take it for repairs or else call 1-800-624-9896 its Dell technical support number or log on to support.dell.com
Jun 03, 2008 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Dell 1900fp 19" moniter Ultrasharp
Button on the bottom back base raises and lowers, if not low enough then you can remove the base. removal button is back and center of monitor.
of course you will have to deal with a way to mount it then.
Dec 12, 2007 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Dell UltraSharp 1900FP 19" Flat Panel LCD Monitor Logo
140 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
