dear tech gods, Here is my prayer to you, in detail status button first told me battery on one sensor off. after stuffing it w/ pillows for too long. I finally got batteries,when I got to it, the alarm goes off when I insert the batteries. the system status now says sensor failure...as well as phone communication failure....I know, call the company. I did. they want me to renue a contract and pay a tech $250 to fix it .. I don't care if it isn't linked in phone, but I would like the beeping to stop and alarm to work in house. in my dreams?? amen, Joyce ps. it has been unplugged and the beeping hasn't stopped.
-   I have a similar problem I do not want the system to connect to outside alarm monitoring, I want to just have the stupid alarm sound in the house when doors/window are opened. I have disconnected from phone line and am in process of cancelling monitoring but every morning at about 2;00 am the alarm beeps telling me I have no phone communications...which I already know!!! I have been told to just unplug it, thanks but no thanks...I want to use it for door alarms still, can this be done?
Help.
S.J.-   sjuser
Two separate problems: Sensor failure and phone communication failure. Most likely, you've not been hooked up to a phone for a while but the system didn't know until it tried to transmit to the monitoring center that you removed a cover on a sensor.
I can tell you how to turn off the panel beeps, "beeps" not only includes the trouble beeps that are driving you crazy, but also the beeps letting you know it's counting down, either when you've just armed it or when you come home right before the alarm sounds.
Open the cover and enter your code using the red numbered buttons inside there. It doesn't beep when you press buttons, so press them well. When you've done it right, it will tell you to choose from the Start Menu. Choose "DELETE". Then, from the Main Menu, choose "OPTION #". Then press DONE. You have now turned off beeps. You haven't fixed anything and that sensor still isn't working but it's not beeping to get your attention now. Press SYSTEM STATUS two times to hear it tell you what's going on.
To turn beeps on again, open cover, enter code and choose ADD > OPTION # > DONE.
YOu might want to check the voltage rating on the battery. Radio Shack can meter the battery for you to let you know if the battery you purchased is actually up to specs. It's rare, but some batteries are not fresh and it's possible you have tried a non fresh battery as the replacement. THe sensor generally has a safety feature that puts it into a beeping mode once the supply battery drops below a specific voltage. It doesn't take much of a drop and that's really a good thing.
BIll Aggie
Was this helpful?
Yes
No
Popular Solutions for GE Security Simon 3 Wireless
I set the new Simon 3 system with a 4 digit master code...but then when I try to add an access code...
(More)
I set the new Simon 3 system with a 4 digit master code...but then when I try to add an access code for the mother, it says invalid or cannot be used. Does it matter if I duplicate digits??? example code: 2311
we have had a gemini security system but have not installed it. Then, the baby in the house pressed...
(More)
we have had a gemini security system but have not installed it. Then, the baby in the house pressed on, but no one had a code. it has been going on repedely.
Hi, The system battery is low, but I can't figure out how to replace it; it's not in the manual. I...
(More)
Hi, The system battery is low, but I can't figure out how to replace it; it's not in the manual. I can't figure out how to open the control panel. Thanks a lot for the answer, Mike
