Question about Boston Acoustics GT22 Car Audio Amplifier
Safe light i was drivin hit a pump my amp cut out and now the safe light is on do i need a new amp or is there something i can do i unhooked all the wires and re-hooked it up and still the red light comes on help please
  • sholatehootu Nov 16, 2008
    i was driving hit a pump my amp cut out and the safe light came on how do i fix this i allready tried running new wires didnt work help please
  • 959 Answers
Push the reset button
Posted on Nov 16, 2008
Had my tired rotated, since then my Service ESC light comes on along with the brake "brake fluid" light comes on. I'm not sure if it something serious or i just need to unhook my battery and reset it.
check brake fluid level and make sure no leaks if low fill to proper level and check brakes it low change them as to esc when tires were changed workers may have hit sensor or damaged wiring by front end or a bad sensor sometimes rarely some hhr owners state a hiccup and reset the computer and it was fine but before you do that check and make sure brake system is correct and safe usually brake resets itself when repair or fluid is corrected
Aug 17, 2015 | 2008 Chevrolet Chevrolet HHR LT
How to get amp out of safe mode
first check all connections, fuses and speaker wiring. Check to make sure that the amp is getting enough power to keep it running, meaning a piece of 4 to 8 gauge minimum wre from your battery to the amp. Make sure no wires are touching ground on the speaker outputs all the way to where they connect to the speakers. You can check this with a Ohm Meter to see if their is a direct short to ground. Or unhook all speakers and 1 by 1 touch them onto the amp to see if it cuts out. If the amp is going iinto protect mode without any speakers hooked up to iit (I have a bad keyboard sorry for the extra or missiing I's) and all other things I mentioned are OK then your amps bad and needs to be serviced. Hopefully It's just be a shorted speaker or wire.
Aug 07, 2013 | Jensen XA4100 Car Audio Amplifier
I have a kicker dx 500.1 amp and a kicker cvr12 sub. When I first hooked up worked perfect for a few minuted. Adjusted settings ont the side and it went out. Now When I power on it the protection light...
check the fuse on the power wire (+) not the ground wire .. i had a kicker 1500.1 on 2 l7 15\'s and when the bass would hit hard the fuse would vibrate and cause the amp to go into safe mode.. after re wireing the whole truck i then found out it was the 150amp fuse holder
Aug 07, 2011 | Kicker Car Audio & Video
My subwoofer doesn't receive power, all amp fuses are fine, amp powers on, remote wire and rca wires are connected and intact. Before it stopped working all together the woofer would cut out and after...
If you are getting power to the amp, try this....Find a small speaker, unhook your sub and wire speaker to amp. Turn on your system at a low volume....If the other speaker is playing through amp, then your sub is shot.....If the small speaker doesnt work, then its either your channel is gone on the amp or the rcas have quit off off your head unit.
Oct 07, 2010 | Kenwood eXcelon X1200M Car Amp
1999 chevrolet LS malibu V6, ABS light comes on
yes it is safe -your brakes will work normally only difference u will see is if u hit[stomp] on the brake hard will cause wheels to lock up[skid] check the sensors wiring ,connections and connection to clips the sensor is incorporated into the wheel hub but the wiring and clips connections are exposed which can get damaged or hit by road debris -if u remove the wheel will see wire running into back of rotor --to replace will have to replace the whole hub[wheel bearing] average price about $80 for part if diy
Jun 01, 2010 | 1999 Chevrolet Malibu
Truck looses power and shuts down while driving
did you check fuel filter ?? and or fuel pressure
Jan 31, 2010 | 1999 Ford F150 Regular Cab
Hum when turntable connected to phono sockets on amp
this turntable absolutely came with a ground wire that must connect to the gnd connection on the amp. maybe it got torn off or something but there should be clues on the back of the turntable as to what happened to it.
once the lead is found it must be connected to the amp gnd connect to get rid of the hum. this might require someone with soldering skilz or what have you in order rig up a new wire.
a tech might have to remove the bottom and solder in a new wire if it is cut or ripped off at the housing. This is common as people forget to unhook the gnd wire from the amp when moving things around.
Jan 05, 2009 | Sony PS-LX350H Turntable
SUBS
Hi , you need to replace with thick wire , if possible attache fuse or circuit trip overload protection you may ask to thew radio store .
May 07, 2008 | Polk Audio EX12 Car Speaker
1200 watt legacy amp not working right
your amp its protect by releas of [powerout]one this releys is dead you mast chenche
Apr 14, 2007 | Pyle Dryver PLAD213 Car Audio Amplifier
Boston Acoustics GT22 Car Audio Amplifier Logo
259 people viewed this question
Top Boston Acoustics Car Audio & Video Experts
xxxxxx xxx
Are you a Boston Acoustics Car Audio and Video Expert? Answer questions, earn points and help others
