Sony screen discoloration
Monitor has blotches of gray-green and gray-purple. Is my monitor fried?
Thank you!
  • cavecreative Nov 17, 2008
    Thank you, both! Most appreciated.
    Sergeant:
    Champion:
  • 274 Answers
Assuming this is a CRT monitor.
Try using the Degauss setting on the monitor buttons. You may have to do it a couple of times.
This could be also due to a fluorescent lamp or other monitor too close.
RDO
Posted on Nov 17, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Champion:
  • 214 Answers
Try degaussing your screen using a magnet , wipe it side ways (3mm clearance from the crt) until bloches are removed, some monitor has built in degausing device, try doing that on your monitors menu.
Vertical Lines Dell Ultrasharp 2001fp
Sorry to say that it is a permanent damage of your monitor screen. Usually you can do nothing. But if you want to change the monitor screen, you have to visit a monitor & television specialist.
Cost will be 1/4 of a new monitor.
Sep 22, 2017 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Screen particially blacking out with vertical lines at bottom of my DELL laptop. at the bottom of laptop screen there are vertical lines @ 2" they are blue, dark gray,white, purple, light green lines....
Tryconnecting an external monitor to the laptop. You may have to select the videooutput to display on the external monitor by holding down the blue key and pressing the blue CRT/LCD (located on one of the keys, likeF8,F9, etc..). If the problem occurs on the external monitor with the batteryor AC power, then you have a problem with either the video card or motherboardin the laptop. If the problem does not happen using the external monitor thenyou laptop's LCD display is going bad.
Jul 31, 2011 | Dell Inspiron 1525 Laptop
HI, I have a NEC monitor 1760nx, dark blotches on the screen
Listen, for what it is going to cost you to fix the unit, you are better off replacing it and having a new warranty to boot. Simply not cost effective to repair given the cost of a new monitor these days.
Mar 12, 2017 | NEC 1760NX-1 (White) 17 in. Flat Panel LCD...
I have yellow and purple blotches on screen
I had this same problem on my Mitsubishi rear projection WD52527 model television. The optic engine was changed twice, and the blotches were still there. It turned out that it was the mirror inside the television that was causing the purple blotches. It was filthy and once the repairman took it out and cleaned it the discolorations were gone. Hope this helps
emmilinna
Oct 16, 2009 | Mitsubishi WD-62525 62" Rear Projection...
LCD Dell Monitor displaying purple and green rather then picture.
sounds like your monitor is starting to go out. if there are any speakers near your monitor, it is likely magnetic interference. try moving your monitor to a different area and see if it still does this. if it does, i would replace the monitor. if it doesn't, just simply reorganize the area around your monitor and it should go away after degaussing the screen.
Jul 11, 2009 | Dell E177FP LCD Monitor
Sony SDM-HS53 Monitor Goes Blank
I used to have the same problem until I discovered that the cables in the back of the monitor weren't securely connected. I have a very similar model monitor to the one being displayed here
Apr 03, 2007 | Sony SDM-HS53 (Black) (Gray) 15" LCD...
Severe gradient issues / problems with darker grays
So your sure when you go into the monitor settings, and color, it is set to like 9300k or something? It probably isn't the monitor, because the video games you said display just fine.
Dec 19, 2006 | Dell M992 19" CRT Monitor
Monitor colours are only fluro purple & green!
use a 10 ins, speaker magnet to front of picture tube degussing color
Nov 29, 2006 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Computers & Internet Logo
527 people viewed this question
Alun Cox
David Payne
David Payne
