Question about Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Gas Dryer
Cabrio Dryer runs for 5-10 Seconds and then the drum stops.
We have a new cabrio Dryer and when I turn it on The drum will turn for about 5-10 seconds and then the drum will stop turning. After 5-10 minutes the drum will come back on.
    Problem Solver:
  • 19 Answers
Go to:
to troubleshoot your appliance.
You'll need the make & model #.
Posted on Nov 16, 2008
Sensor and computer have been replaced on cabrio dryer yet check vent light still comes on
Did you clean the exhaust duct from end to end?
Some of these have a two-belt system where the second belt turns a fan blade that resides in a plastic housing beneath the drum... the pulley will come loose and fall off sometimes which can cause this error... Help Me Find My Model Number RepairClinic com
Oct 07, 2016 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Just dies after about 5-10 seconds
this may be due to the fault in the pump check that
May 27, 2008 | 2002 Volkswagen Cabrio
We need to take apart our Cabrio Platinum Dryer to get it down our stairs.
Whirlpool cabrio dryer repair - YouTube
? 5:22
Sep 22, 2012 - Uploaded by Michael Steiger
Whirlpool kenmore safety fuse dryer not lighting GE Maytag. ...Dryer Troubleshooting - Not Drying or Taking ...
How to disassemble a Whirlpool Cabrio dryer > Dryers > Whirlpool > Whirlpool Cabrio
Jun 9, 2012 - How to disassemble a Whirlpool Cabrio dryer. Dryers ... If you need to take the drum out, there's a panel that holds it into place similar to the Maytag Neptune design. ... we respect your privacy and take protecting it seriously ...
How To Take Apart a Whirlpool Dryer ' Appliance Aid
Dec 21, 2015 | Whirlpool Dryers
Squeaking Cabrio dryer when running
The squeaking is due to the drum glides or as some people call them slides, being worn or broken. Easy fix and very inexpensive part
Mar 25, 2014 | Whirlpool WGD8800YW Cabrio Platinum High...
Cabrio Dryer making whirring sounds
That could be something in the blower. In the past I have found garment support wires. That could very well be it. The dryer is built quite well with 4 wheels instead of 2 wheels. You can drop the service panel in front and remove the filter housing very easily to inspect the blower and clean the filter chute. Here is my home movie on repairing one of these
Nov 13, 2013 | Whirlpool Dryers
I moved my Cabrio electric dryer to another room. A new outlet was installed in the new room. When first plugged in, the dryer runs and tumbles but will not generate heat. Suggestions?
Your electric dryer uses110vac to run the motor which makes the drum turn. It uses 220vac to run the heating elements. I'll assume you had a qualified electrician add the new outlet. If not, I'm betting whoever did the install used the same electrical phase for both 110 sides of the plug. You can't use an electrical tester to test this as both sides will read the same. Manually trip the breaker (should be a double breaker) and then check the outlet. The wiring to the hot leads should be black on one phase and red on the other. Let me know what you find out
Oct 18, 2013 | Whirlpool Cabrio WED6400SB Electric Dryer
My cabrio stopped providing heat....the fan is working and the drum is tumbling
The heater element is located on the back of this unit. You need to pull the dryer forward and test the element. If you need more help let me know.
Mar 07, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer will not restart after tennis shoe getting stuck in it
Make sure door is closed firmly. Try to Press and hold the START Button for 4-5 Seconds.
Good Luck and have a nice day.
Jun 29, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Gas Dryer Logo
394 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
