Question about GE WSXH208A Front Load Washer
Ge front load washer does not spin or drain - GE WSXH208A Front Load Washer
  • 4 more comments
  • Anonymous Jan 24, 2009
    my machine will not spin or drain . I tried putting it on the rinse and spin cycle and it filled with water but wouldnt come off the rinse cycle. i did remove the three screws and white cap to empty the tub but when i put it all back together the same thing happens. please help.
  • Anonymous Mar 15, 2009
    My GE frontload washer cannot finish the cycle. The "estimated time remaining" counts down to one minute, then will constantly rinse and spin for hours, all the while showing one minute remaining. I turn off the power and remove wet clothes. The drain plug and filter are clean and empty.
  • Anonymous Mar 25, 2009
    MY WASHER IS STOPPING WHEN IT HAS 19 MINS LEFT AND I HIT START BUT WHEN DONE IT LEAVES MY CLOTHES VERY WET AND THERE IS A SMELLY SMELL IN THE WASHER WHAT COULD THIS BE?
  • Anonymous Mar 30, 2009
    My GE is a WBVH6240FWW and is doing the exact same thing as the post of March 15th. It counts down to one minute and then drains forever. Most of the time the clothes are wet. I also had a torn gasket within the first few months. This is the worst choice I could have made for my new front loader washer and dryer.
  • Anonymous Apr 01, 2009
    I have the same problem. My washer is only 2 years old. It won't spin out the water but the washing cycle seems to work.
  • pjacksonk1 Apr 01, 2009
    I have the same problem as well. The spin works great but it is not draining out the water on the final rinse and the clothes are soaked. Sometimes it will stop mid cycle with 19-20 minutes left and I will walk by and have to hit start again. Anyone have theirs fixed yet to know what the problem might be??
Unscrew the botom front panel,behind that you will see a lint trap,with the power off,and unplugged,place lot of towels on floor at this trap,unscrew slowly,as water will exscape,trap will pull out with plug,clean trap,,,,,,,,,,,,,,,,,,,,,,,trap is about 1.5 inches round,it located at bottom right side of my machine,,,,,,,,,good luck
Posted on Apr 11, 2009
    Problem Solver:
  • 19 Answers
Go to: Repairclinic.com
You'll need make & model #.
Posted on Nov 16, 2008
3 Suggested Answers
SOURCE: GE front load washer (clothes)
THANK YOU. for those of you with a screw driver, here are the photos on how to.
It takes a philips screw driver and 20 minutes. The white screws may not align perfectly but don't worry, just get them to go back in the hole(no harm done).
I'm going to admit it was my wife that found this fix, so now I give the step by step photos.
[IMG]http://i26.tinypic.com/23upff6.jpg[/IMG]
Small white screws (3 in total)
[IMG]http://i30.tinypic.com/69n9eh.jpg[/IMG]
cover "falls" off
[IMG]http://i29.tinypic.com/24erogl.jpg[/IMG]
Unscrew the lint trap (turn to the left)return when clean to hand tight
[IMG]http://i32.tinypic.com/9uralw.jpg[/IMG]
Bob's your uncle and a freebee for CMKX'rs.
Hub and wife team.
Posted on Apr 15, 2008
JULIANFIX
  • 975 Answers
SOURCE: GE Washer won't drain or spin
this is something that you can fix even if your not a technical person . first you have to open the washing machine front panel or back panel , second , follow the DRAIN HOSE to where its connected to a little motor, disconnect the DRAIN HOSE , take the LITTLE MOTOR out and clean it out , it could be clogged.
it happen once and find out the person put the BATH RUG SET
to wash , the rug was so old that pieces of a rubber underneath the rugs clogged the drain , so there was no rinse and no spin.
try it , I hope it helps.
Posted on Apr 16, 2008
My GE washer #WDSR2080DEWW washer won't spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | GE WDSR2080D Top Load Washer
GE frontload washer doesn't spin
heatman101
Aug 12, 2011 | GE WSXH208A Front Load Washer
Ge washer won't let water spin out
heatman101
Aug 11, 2011 | GE 3.2 Cu. Ft. 6-Cycle Super Capacity...
GE Washer will wash but won't drain?
heatman101
Jul 24, 2011 | GE Washing Machines
GE Spacemaker Washer Tan does not spin or drain
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Apr 20, 2011 | GE Spacemaker Washer and Dryer Electric...
Ge washer won't spin and drain
heatman101
Mar 30, 2011 | GE Washing Machines
My ge front end loader washer won`t spin water or pump water out
heatman101
Jan 29, 2011 | GE WSXH208A Front Load Washer
Our ge washer will not drain water out before it goes to spin cycle
heatman101
Jan 23, 2011 | GE Profile WPSR3120WWW
My top load ge washer wont spin out?
heatman101
Sep 23, 2010 | GE Washing Machines
GE top load Profile washer. Spin cycle not
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 11, 2010 | GE WVSR1060A Top Load Washer
GE WSXH208A Front Load Washer Logo
1,208 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
