Question about Asrock P4V88 (P4V88 RAID) Motherboard
ASROCK P4V88 motherboard freezes after completing the boot up.
120 GIG Hard Drive WD - SATA
3.0 GHz intel processor
1 GB PC3200-400 Memory - Corsair VS512MB400
BIOS upgrade from 1.5 to 1.8
ATI - AGP 32MB video card
This board ran really good for about 9 months. And then it just started having problems. All recommendations were meet that were suggested by ASROCK when the system was built. I have got absolutely no good support from ASROCK.
  • Asrock Master
  • 4,806 Answers
A bios flash might sot the problem
Posted on Nov 16, 2008
What would be the best compatible 512 MB GPU(with shader 3 or 4) working with P4I45GV 3.00 /P4 2.4 GHZ/1 Gb ram ?
http://www.asrock.com/MB/overview.asp?Model=P4i45GV%20R5.0
Any of them Shubham.
If we are to discern by a few known statements;
1) It is believed in some 'geek communities', that using the same manufacturer of motherboard chipset, and graphics chipset; to be a good thing.
For example an AMD motherboard chipset 'plays well' with an AMD ATI graphics chipset;
Nvidia motherboard chipset 'plays well' with Nvidia graphics chipset.
Intel motherboard chipset with Intel graphics..............no wait,....... there is no Intel graphics chipset, unless it is -> Integrated Graphics.
[ Intel GMA ]
(Integrated Graphics is also said as OnBoard graphics. ON the motherBOARD)
2) DOES NOT MATTER what graphics memory type is used.
Motherboard can use DDR Sdram ram memory, and graphics card can use GDDR5.
Why?
Because the graphics card has it's own Processor, and Ram Memory.
Graphics Processing Unit, or GPU; is the Processor,
http://en.wikipedia.org/wiki/GPU
Graphics memory is the ram memory.
Operates independent of the system resources.
The graphics expansion slot on the P4I45GV (P4 i 45GV), is an AGP slot.
Accelerated Graphics Port,
http://en.wikipedia.org/wiki/AGP
It will use an AGP 4X, or AGP 8X graphics card.
Use an AGP 8X.
http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=agp+graphics+card+512mb
REMEMBER;
1) ALWAYS follow Anti-Static Precautions.
2) INSTALL the software for the graphics card F-I-R-S-T,
(Drivers and 'control panel')
THEN unplug the computer from power, follow Anti-Static Precautions, and Physically plug the graphics card into the motherboard, and install.
3) L@@k at the system requirements (Minimum) for the graphics card.
Specifically the Power Supply requirements. You need a Power Supply with enough Wattage, to handle the graphics card.
[ Handles the graphics card, and -> Motherboard, Processor, Ram Memory, and peripherals; Internal and External.
{Harddrive/s, optical drive/s; Internal
Mouse, Keyboard, external harddrive, etc; External ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 17, 2012 | Computers & Internet
2 beeps, no post on my Asrock Extreme3 970
two things:
your RAM's its not fitted right or in right spot.
too small power supply, its to narrow in watts, should have 750 Watts at least.
Mar 22, 2012 | Computers & Internet
I have an asrock p4v88 mb with 2gb mem and am trying to install seagate baracuda 1 tb hd bios says drive not detected any answers vern
Try to upgrade your drivers for the mainboard
from here:
http://www.asrock.com/mb/download.asp?Model=P4V88
Remember to select the windows you are running.
Upgrade the 4 in 1 driver first, and the SATA RAID Driver.
Hope this solves your problem.
Mar 21, 2011 | Asrock P4V88 (P4V88 RAID) Motherboard
I am having hp 530 laptop with intel core duo inside,512mb RAM,80 gb hard disk.I want to upgrade my processor,ramand hard disk. can i do it ? upto what limit ?
Unfortunately I would have to say no, you won't be able to upgrade the processor. I located a user manual at
http://h18000.www1.hp.com/products/quickspecs/12722_na/12722_na.PDF
According to specifications you can increase the Ram to 2 MB and the hard drive should be a 120GB hard driver Sata
System Memory 1024-MB 533/667-MHz DDR2 SDRAM in one slot
Two SODIMM slots; supported memory 2048 MB2
Operates at a maximum of 533-MHz with 667-MHz memory
Hard Drive 120-GB3 5400 rpm SMART SATA
The processor will be limited to what the motherboard can support and it was designed for that 1.6 Ghz processor. Unfortunately it is very difficult to upgrade processors in laptop machines. I do have to ask how old this machine is. The specification indicates MegaBytes of ram and this is actually very little Ram in today's computing world. Most machines support at least 2 gigaBytes of Ram to start with.
Nov 20, 2010 | HP 530 Notebook PC
Hi I'm having problems installing windows 7 on my computer I think it may have something dealing with my motherboard I m running a MSI P55M-GD41 mother board with intel i5-661 processor and 4GB of 2 2GB...
One bad lead will cause your computer to shut down or continue in a cycle
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to your hard drive
hope this helps
Oct 24, 2010 | MSI P55MGD41 Motherboard
Dual channel Mode willnot work over 2 gb's of
Hi, please read page 12, section 2.3 in your manual. Dual channel memory must be connected per manual specs.
(Correct colored DIMM slots)
Link to Asrock manual; ftp://174.142.97.10/manual/P4V88.pdf
Main web site provided by Asrock; http://www.asrock.com/mb/overview.asp?Model=p4v88
Once the memory is installed into the correct colored DIMM slots your system should see up to just under 4GB if 4GB is installed while using windows XP. (Refer to Asrock's web site).
Hope you find this helpful and working.
Mike
Aug 01, 2010 | Asrock P4V88 (P4V88 RAID) Motherboard
I have a abit 1c7g motherboard intel 3.2ghz processor twin western digital raptors sata raid 0 config ... 1 sony dru 710a on ide 1 (slave) trying to install plextor 880sa dvd burner having conflict with...
Suggest you connect the plextor to the SATA port 3 and set it's jumper to Master. All SATA drives are seen as Master drives. (Check the serial number on your WD SATA drive "Primary".
Enter the bios menu. Within page 3-7 section 3-3 Advanced bios features. Check, 1st, 2nd and third boot devices.
Floppy disk drive as, 1st boot device. 2nd boot device, "Primary WD SATA port 1". 3rd boot device, CD-ROM drive SATA port 2, Plextor 880sa drive". Save and exit the bios. If you no longer have you're manual you can download it from the link provided below;
http://ftp.abit.com.tw/pub/download/fae/ic7-g_eng_v101.pdf
Check page 3-13. See OnChip serial ATA Mode. As noted, the RAID option is available when the item "OnChip serial ATA" is set as [Enhanced Mode].
Cheers'
Mike
Jun 27, 2010 | Abit IC7-G Motherboard
Finding Intel 845GVSR & 915GLVG Compatible Motherboard & Proc
you can use intel dg41 mbd , dualcore processor,1 gb ram,160 gb hdd or use intel atom for support contact 91-9645071021
Aug 11, 2009 | Intel D845GVSR Motherboard
SATA drive not detected
If you will be loading xp on the new drive,You will just need to press F6 during the setup when ask if you want to install 3rd party driver,and follow the instruction and put the SATA driver disk in when ask.(Even during xp setup It will say SCSI device until all the drivers for it are loaded)
May 20, 2009 | Asrock P4V88 (P4V88 RAID) Motherboard
Asrock P4V88 (P4V88 RAID) Motherboard Logo
491 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
