Question about JVC TH-M505 System
System shuts down whenever there is a loud noise on a DVD
Everytime we watch DVDs with out system we have the problem of the sound cutting out whenever a loud noise occurs in the movie. Explosions, car crashes, dramatic soundtracks...it all causes the system to shut down and we get a blue screen that says No Signal. Then we have to start the DVD over and find our way to whatever scene we were at. Needless to say, action movies can be frustrating to watch. We called JVC and they were not at all helpful. We have a standard Adelphia cable box, TiVo and a Samsung HDTV....we'd appreciate any help we can get.
  • 203 Answers
If the system is shutting down there is a major drain going on with the speakers. The treble can cause this as well as shorted speakers or even a failing output.
Posted on Jun 15, 2007
I also was having the same problem... I had the mistake of having the treble all the way up along with all the other speakers except the subwoofer. I just put all the speakers back to 0 and the problem has been solved for months now
Posted on Feb 07, 2007
I had the same problem. Found out the wires were in contact with one another on one of the speakers.
Posted on Jan 14, 2007
SOURCE:
I have a Panasonic SA-PT960 surround sound/dvd player. Whenever I turn it on I get a chgr err flashing on the screen and a loud grinding noise
There is a fault with the DVD Changer and the noise is the gears grinding. This is a common fault with these units as a small arm within the unit breaks and blocks the mechanism.
You can either try and replace the complete DVD Changer or remove it and just us it as a surround sound system with your auxiliaries connected to it.
May 09, 2011 | Panasonic SC-PT960 Theater System with...
When i watch dvds,the background noise is loud
Go to your set up menu, navigate to speaker set up and check your sound levels to front, center, and rear channels. Adjust as needed to fit the room. My Sony has a test tone option which sends a signal (at levels selected) to each speaker to check sound level and if speaker is connected and in right place.
Dec 28, 2009 | Sony DAV-FX900W System
Loses sound during loud moment in movie or if sound is above 30.
Check the speaker maybe one are about to get fried
Jul 03, 2009 | JVC TH-C5 System
System shuts down when playing music dvds at 17 or 18
Check your speakers one by one, maybe one of them are about to burn that´s the reason your device turn on protection state,good luck
Mar 16, 2009 | Televison & Video
Shuts off after a loud sound
Hmmm...not sure but sounds like the vibration from the loud sound is causing the disk to jump. Not sure why that would power it off, but I think your thought to junk it sounds reasonable.
Dec 24, 2007 | Onkyo DV-CP704 DVD Player
Intermittent, random, loud popping noises.
you should check the outline ctrl..for a mic...it could produce a noise...if you have your speakers connected to pc...check the position of the plugs and the volumen of mic put in down...
Nov 24, 2007 | RCA RT2760 System
Crackling from surrond sound
I have a SONY home theater4.gif system, HT-C800DP, there is a crackling sound when playing DVDs - it is almost as if the unit overheats. Is there any solution to this? Sometimes I cannot even finish a DVD as the noise gets very loud.
Thanks,
Cindy
Aug 14, 2006 | Sony HTD-C800DP System
Sound cuts out
If you listen to cd's and the sound dos'ent cut out then it cant be the amp. It could be the audio cables are intermittant between the amp and the dvd playerr or they are loose or corroded a little. or ppossible the input your using is going bad on the stereo sytem but I wouldnt think that the whole system was blown if the radio and the cd plays normal.. check out the causes I listed and let us know if you need more assistance\..:)
Apr 19, 2006 | Technics SCEH790 CD Shelf System
JVC TH-M505 System Logo
148 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
