Question about Motorola Talkabout T5100 (14 Channels) 2-Way Radio
Sub channels and how to turn them on
When i turn on the radio i notice that up in the top right hand corner there are lttle numbers so i asked a freind and they said that they were sub channels how do i turn them on
    Brigadier General:
  • 6,966 Answers
Beg to differ with your friend. Those small numbers are not sub-channels but rather are Interference Eliminator Codes. The represent what code is being used by the radio to eliminate other incoming transmission not with the same code (number). There could be similar radios working on the same channel/frequency, but if they do not have the same code then neither one would hear each other. This does not make a channel "private", rather it limits what one can hear on that channel to another radio with an identical setting of the code. In some Motorola models, pressing the Menu button until the small numbers/code flashes would enable them to be changed. To change, press the+ or - keys. Pressing the MON key or setting the code to Zero would enable the radio to receive and sound off all incoming signals with or without the code.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 16, 2008
My 54cm RC-A07 Logik Tv is not tuning and displays a red asterisk next to channel number in top right hand corner of screen
Hi. This might indicate that your TV is eiter in "channel " mode or in "number" mode. Channel is rhe real channel from the transmitter, (being 2-62, S channel) while the number is the one you change by your remote. There must be a way in the menu/tuning where you choose between both.
Oct 06, 2014 | Televison & Video
I have two T5510 Motorola. Walkie talkies and when
Good job describing. The channel is the channel number, the upper right is the "tone". If everything matches, they should talk to each other. Try pressing the squelch button on each to make certain the speakers work. It is also possible the mic openings are clogged with debris or the audio jacks have something in them. If the audio jack has a broken pin or even debris in it, it is possible the speaker will remain muted. If you are using audio accessories, unplug them and turn the radio off/on. Do you have a tone on power up? Other than that, how old are they? Do you know the history? If they got wet, corrosion likely set in and you need new radios. Yes, I know some say waterproof, they mean resistant.
Sep 04, 2014 | Radio Communications
Give me ebays phone no. jooanleahy@verizon.net
i need toto speak to an ebay rep
Jul 09, 2011 | eBay Auctions
I can't get them to connect to each other
If the unit you are using is an FRS/GMRS radio then this might fix your issue.
  1. Make sure both radios are on the same channel, ie Channel 2.
  2. Now look at the screen on both radios...below the "2" is a smaller digit... this is a sub-channel.
  3. Are the sub-channels for both radios the same? If not they need to be matching. The easiest way is to set them to "0". (You can read more about the sub-channels in your Motoral owners manual if you have one.).
Here is how to change the sub-channel.
  1. Press the MENU button once and release it. You will notice that the main channel is now blinking.
  2. Now press the MENU button a 2nd time within 4 seconds to make the smaller sub-channel number begin blinking.
  3. Now use the "+" sign on he right (or up arrow), OR the "-" sign on the left (or down arrow) to adjust the sub-channel to the number of your choosing.
  4. Let's say you wan to set the sub-channel to "0". Using the above instruction in #3, do this and then immediately press the PTT (Push To Talk) button once to lock in your selection.
Both radios are now programmed to speak with each other on the same frequencies.
Your question did not have much detail, so I am assuming this is the issue. I hope this helps!
May 05, 2011 | Motorola Walkie Talkie 2-Way Radio
When I hooked my subs up to my KVT-512, the subs only turn on when the Radio is on, but whenever I put in a CD or plug my iPod in, the subs do not work. Can anyone explain why this is happening? Thanks!
you are so close your gonna hate youreself a lttle your connected to the blue power antenna wire connect it to the blue white remote turn on and your all done
Aug 21, 2010 | Kenwood KVT-512 Car DVD Player
I dont know how to program frequiences on the scanner
1. Press Menu (Bottom left hand side of the scanner) You should see "Program System"
Press E You should see "Select System"
2. Turn VFO knob (Top outside right knob on the scanner as it faces you.) until "New System is displayed.
3. Press E
4. Using the VFO knob, select "Conventional then press E three times
5. Press the decimal key until all the letters under "Edit Name’ disappears
6. Now you’re ready to name your system. Turn the VFO to the to select a letter or number. Once the letter or number is selected, hold the Function key (Top left hand side of the scanner) while turning the VFO knob to the right to add another letter or number. When you finish, press E
7. Turn VFO to Edit Group then press E
8. Use VFO to select New Group then press E twice
9. Press the decimal key until all the letters under "Edit Name’ disappears
10. Now you’re ready to name your group. Turn the VFO to the to select a letter or number. Once the letter or number is selected, hold the Function key (Top left hand side of the scanner) while turning the VFO knob to the right to add another letter or number. When you finish, press E
11. Turn the VFO to Edit Channel then press E. (You should now see "New Channel")
12. Press E then enter a frequency
13. Press E twice
14. Press the decimal key until all the letters under "Edit Name’ disappears
15. Now you’re ready to name your "Subgroup" i.e. " Dispatch" Turn the VFO to the to select a letter or number. Once the letter or number is selected, hold the Function key (Top left hand side of the scanner) while turning the VFO knob to the right to add another letter or number. When you finish, press E then menu
16. Use VFO to select New Channel
17. Repeat steps 12 through 16
Mar 27, 2009 | Uniden BC246T Handheld Scanner
Number won't erase
Press the "DISPLAY" button. This may cycle through a couple of other displays but will finally clear the channel number. (That's how it gets turned on, too, by pressing that button.)
If this solution is what you needed, please take a moment to rate it. Thanks for asking here!
Feb 20, 2009 | JVC AV-27530 27" TV
I need help, amp OVER heating too much (i think)... Please help
i think your load is too low... each sub when wired in parallel can potentially be 2 ohm or 1 ohm depending on if each voice coil is 2 ohm to begin with,,,,this will cause a clipping situation as described and the over heating problem as described,,,,my email is troublerst@hotmail.com if you have a digital camera send me some pics including speaker model numbers...I await your information so I can help you... good luck
Nov 03, 2006 | JBL BP150.1 Car Audio Amplifier
Motorola Talkabout T5100 (14 Channels) 2-Way Radio Logo
180 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
