Question about Blaupunkt RPD-555 CD Player
Sound cuts out at 45
I got it to work if the volume is not past 45 but as soon as it dose the sound cuts out
0 characters
1 Points
What would be wrong with my kenwood-krf-v5100d and the front right and left speaker out lets are not working propaly sound dose come out of them but it is real low and when you go to turn them up inde
There is a balance option. Find the manual for this player and look for balance. You are looking to change it to 0 so that it plays through all of your speakers at equL volumes
Jul 24, 2014 | Kenwood KRC-379R Cassette Player
Dualxdvd210 when volume is up it cuts out the bass. Can I stop this?
Most probably you need thicker wires for power supply to your amplifier.
Apr 10, 2014 | Dual Electronics Car Audio Receivers
Ive got a jvc kd g140 and it cuts out at high volume.
did you hook this head unit up or did you have some one hook it up for you? most of the time it is that factory amp that makes it cute in and out. take the head unit out of you car and hook it up with a 12 volt power in your house or on you battary with a speaker and if it still cuts out the amp chip need to be replaced. let me know if this helped. thanks.
Kim ( Owner )
Jan 15, 2010 | JVC KD-G140 Car CD Player
Sony cdx m610 resets itself at half volume
You have a shorted speaker or speaker wire. If a wire is touching metal lightly it may not have full continuity (short) and will work until more voltage (volume) is sent to the speaker and causes the short. Disconnect all speakers at the radio then turn the unit back on. Turn up the volume and see if it cuts out. If it stays on, re-connect speakers one at a time and test. Once you find the problem speaker, disconnect the wire at the speaker then test again. This will eliminate the speaker itself as the problem. Test again. If it still shorts, trace the wire from dash to speaker and look for a cut in the sheathing exposing the wire. Repair or replace the wire and you should be good to go. If the unit cuts out with all speakers disconnected, the problem is internal and will need to be serviced. Before you repair/ or replace the unit either check all the wiring and the speakers or have someone do it for you so it does not give you a repeat performance. Hope this helps.
Oct 01, 2009 | Sony CDX-M610 CD Player
Kenwood KDC-322 volume cutting out
there buggers rewire the earth/ground
Jun 19, 2008 | Kenwood KDC-322 CD Player
Durabrand DB1215 car radio
I have a db 1210 and i need the wireing plug for the speakers can you help
Jun 04, 2008 | Durabrand DB1200 CD Player
Blaupunkt RPD-555 CD Player Logo
21 people viewed this question
Top Blaupunkt Car Audio Receivers Experts
xxxxxx xxx
Are you a Blaupunkt Car Audio Receiver Expert? Answer questions, earn points and help others
