Question about Video Game Consoles & Games
I need a driver for my game elements gge909 gamepad for vista os
See above
  • 2 more comments
  • hydra4200 Dec 07, 2008
    my gge909 pad works kindof but i need to download the driver to get it to work right can any one tell me were to find it for free??
  • justinandkri Dec 08, 2008
    need to re-install software for gamepad controller
  • paul159 Feb 01, 2009
    it does not work all buttons do not work why .
  • Anonymous Apr 07, 2009
    gge909 wont work vista
GGE909 can work under Vista and 7 without driver. hoever the "ESC" and "ENTER" key doesn't work. I wondered that the manufacture havn't write driver for Vista and 7.
Posted on Jul 12, 2010
I need software & manual for GGE909 rumble pad
Hi.
GGE909 rumble pad software (xp/vista/win7/win8/mac) can be found at driverupdate us
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Mar 25, 2010 | Game Elements GGE900 (51691)
Can I get a driver for the nazar gamepad GPC-V47? OS is Vista.
may be the driver can not work with vista or that editiom\n of printer
Oct 16, 2009 | Video Game Consoles & Games
The USB part has broken off my GGE909 Game Elements Recoil PC controller. I want to know if I can use a different USB cord to attach to make the GGE909 usable again. Is it possible to fix?
The GGE909 uses a flat ribbon cable with eight wires, and has a spring loaded spool to store the cable.
Using a standard cable might work, but the new cable probably won't retract in the spool.
Sep 05, 2009 | Video Game Consoles & Games
Gigaware controller on vista
You don't (and can't) disable DEP for the controller (a gamepad controller isn't an application, it's a device which uses a driver, Data Execution Protection applies to applications ie .exe files), it's the game or emulator you disable DEP for, so that you the game can run, completely free of security bindings, and then you would be able to go into the game configuration menu and select your gamepad, and calibrate it. Calibrating means the game detects you gamepad and applies the specific functions to each button.
One way to be sure is to disable DEP for everything, then install a game, and THEN plug in your gamepad. Then start the game/emulator and go to the configuration menu within the game/emulator and set up the gamepad calibration in there.
If it doesn't work, then you haven't installed the drivers for the gamepad properly, or haven't installed the correct driver.
Before doing any of that, you would have checked in Control Panel and Gamepad Controllers, double clicked the Gamepad in the list and pressed Calibrate, to enable generic gamepad functionality.
If you hadn't done that, do so now.
If it still doesn't work, then NOW disable the DEP (either all DEP or for the game/emulator you want to play). Unplug the Gamepad and load up a game. Then plug the game pad in. Set up the gamepad from within the game/emulator config menu, which differs from game to game, of course, but is more or less the same.
If it doesn't work.. re-install the correct driver for the gamepad.
Also make sure your operating system is fully updated and you're plugging the gamepad into a usb2.0 port. and have rebooted after installing the gamepad usb driver.
That's everything you need to know..
Good Luck!
Chris (ziraffa)
Dec 27, 2008 | Video Game Consoles & Games
Problem with gamepad
Unfortunately, I am unable to find any Vista drivers for this gamepad. However, it should be supported natively. Try going into 'game controllers' in the control panel and see if you can set it up from there.
May 22, 2008 | Video Game Consoles & Games
Gamepad drivers
In this case you can istall the drivers as the vista os is having some trouble in detecting the hardware.
Its always better to go in & install the drivers.
This is the best way to download the drivers of all your devices which are connected to the system for free.
But you have to be patient.
First, i want you to download a free program called "Orbit download manager" from the link below,
http://dl.orbitdownloader.com/dl/OrbitDownloaderSetup.exe
And then you can download a program called "Driver genius" from link
http://www.qwerks.com/download/6776/drvgenpro.exe
it is a trial program for 15 days
dont worry we only need it for 5 minutes
Install & run the program & in the windows click on the update the drivers
It will check & it will give the window with the drives that needs to be updated & it will not update a it is a trial one.
So you just right click on the driver name, you will get a message called 'copy url address 1' copy that & open the orbit downloader & click on the create new download & paste the link the drivers will be downloaded for free.
Some sites give these drivers only for the money & we cannot be able to find them from the free sites, so i think this would be a nice trick.
Good Luck.
Live, Love, Laugh.
May 14, 2008 | Microsoft Windows Vista Ultimate Edition
Not compatible with windows vista
Hey Guyz Just Go 2 Google And Search for lgs501.exe or LGS501.exe to Download, and then download and install the application on your Vista PC .Plug in the Gamepad(Rumblepad2 or 1) In ur USB Wen ur Installing it.
THEN UR RUMBLEPAD 2 OR 1 SHOULD WORK 100% PERFECLTY + BIT MORE EFFECTS AS YOU HAVE DX10.
If youll have any problems\Errors in installing or playing or if you need any original softwares,Games,Cracks,Patches,Drivers,Help,Gamepad Drivers or Help JUsT EMAIL TO --- arjunmanoj23@hotmail.com
Nov 01, 2007 | Logitech Rumblepad 2 Vibration Feedback...
Can't use game pad on new game
It may not be compadible with bioshock. I had the same experience had to return the game pad. I only paid 10 dollars for my game pad, goes to show you get what you pay for. Invest in something more expensive, it will pay out in the long run.
Sep 26, 2007 | Computers & Internet
Video Game Consoles & Games Logo
2,378 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
