Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Washer makes clunking noises.......
When the washer starts to go into the spin cycle it makes a loud clunking noises. It also does it when we tried it with no clothes in the washer. It doesn't seem to be off balance and we are wondering if the pump is the problem or could the brakes be pressing against the tub?
  • emyjoemaxx55 Nov 16, 2008
    Its more like a rubbing noise and now the drum won't turn. It starts at the beginning of the spin cycle and continues thru the spin cycle. Could the brakes be stuck? and if so, how do we check to see if this is the problem?
    So do we remove the panel in the front or the back and how to we get to the motor or remove it?
    New Friend:
Walt, mine is making the metal to metal noise, and it's on the 15 minute soak cycle. It is also when it is agitating
Posted on Jan 07, 2016
  • 3 Answers
You didn't give to much detail about the noise, other then clunking. Does it sound like it's metal against metal? Does it sound hollow? When does the noise take place before, during or after the spin cycle.
The easiest thing to do is check to see if the motor is loose, or if you might have too much slop or slake in the belt, if you do then replace and readjust the belt.
Posted on Nov 16, 2008
  • Walt Ehrhard
    Walt Ehrhard Nov 16, 2008
    Your brake is basically your motor, Go for the easy stuff first by checking your belt.
  • Walt Ehrhard
    The panel would have to be removed from the back, depending on the age will depend oh how many screws you will have. You can also get to it from the bottom but you then have to lay the unit down. If your able to remove the back you should be able to start the unit and watch how things work, this could also tell you more of whether it is a belt or brake problem, you don't want to try and start it if it's on the side. You would be asking for a whole lot of problems.
Whirlpool wtw5100sq0 clunks when put on spin cycle
Does the washer currently work fine aside from the loud clunking noise? Does the clunking noise continue or is it just one loud clunk when it starts to spin? If its just one loud clunk then that is not a problem just ignore it as that is the clutch spring releasing, it probably starting making noise from the grease getting washed off when the washer over filled.
However how did the washer overfill? That issue should be addressed too. Sometimes though, if the tub is not centered from a heavy load the water will spill over the back but its not really an overfill.
Mar 25, 2013 | Washing Machines
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Loud noise during spin cycle
what kinda noise, sqeeling, or clunking, mite be sumthing small that made its way behind ajatator an is causeing noise..or one of the springs that hold it broke..sorry i dont no what kind of noise.....
Jan 31, 2010 | Washing Machines
Makes loud noise when on spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jan 09, 2010 | Amana 3.2 cu. ft. Top-Load Washer
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
Rattling noise during spin cycle
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Loud cliunking noise in beginning of spin then won't spin
get a flashlight and see if a foreign object has fallen down through one of the tub holes and is jamming the tub you have to look real close
Jan 11, 2008 | GE WJSE3110A Top Load Washer
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
1,001 people viewed this question
Dan Webster
Dan Webster
Sal De
