Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Furnace will not come on but thermostat is showing information
My thermostat is showing 63 inside. I have it set for "heat" at 70. The furnace will not come on. I changed the batteries and the furnace came on for about 30 seconds, then turned off.
  • 2 more comments
  • ssunderwood Nov 16, 2008
    It is a honeywell. I do not know about the pilot light, spark or glow ignition...how do I know? The fan will come on if I select fan. The A/C does come on if I turn the temp below the "inside" temperature.
  • Anonymous Nov 20, 2008
    The indusser moter would not work it was binding up, so I replaced it. Every thing worked fine. Today I came home and the flame would not work on the burners no gas would come out ( the pilot light was lit). That is were I'm at now.
  • holdridge414 Dec 14, 2008
    hi,
    I have a Reclaimer 80 furnace.It has been wokring ok until yesterday.The blower motor is the only thing is running.I have no spark and the hot surface igniter is not glowing.I do hear a clicking sound.Can you tell me what can be the problem and if so,where can I buy what I need.Please help me.Thanks Ray!!
  • Walt Ehrhard
    Walt Ehrhard May 11, 2010
    What brand furnace do you have? Do you have a pilot light, spark, or glow ignition system? Will your fan come on if you select fan? Will your A/C come on if you select cool?
  • 61 Answers
Turn off power to furnace and open the front panel and see if you can see burners and gas valve and Hot surface ignitor.
If you can. turn furnace on and watch to see if the ignitor glows.
Let me know what you find. If it doesn't glow you probably have a faulty Hot surface ignitor.
If I had make and model number I should be able to find the part
Posted on Nov 28, 2008
I have a carrier furnace and it seems to be only blowing out lukewarm or cold air and my house only gets up to 63 degrees
Make sure your filter is clean and that your heat registers are open and the cold air return is not blocked. So if you turn your thermostat up to 70 degrees is the burner shutting off before the house gets up to temp? If the thermostat has batteries are they new? Out side of that you may need a service tech.
Jan 01, 2018 | Carrier Heating & Cooling
Heat won't come on. My hvac system worked fine throughout the summer but now that it's getting cool the heat won't come on. I have a Hunter digital, programable thermostat. I reset and...
if you have an electrical meter this is how to test for bad t-stat heating relay. (this is for the most typical furnace setup in a typical home)
first you will need to find and do several things at the furnace.
find the MAIN furnace switch and turn off. switch should be mounted outside of furnace on either side of furnace cabinet. remove both furnace doors. find the electrical circuit board, it will be the square thing that almost all wires go to or come from. find the 24v (t-stat) connection screws on the circuit board. they should a row of small phillips screws, and there should be a minimum of 5 screws in a row. the screws will be labeled as follows (not in certain order) R W Y G C . The screws you will be concerned with are R, W, and C. If there is not a C screw you will substitute the C screw for a unpainted part of the furnace cabinet in your testing. The last thing to find is the door switch which should be mounted behind the lower door. It is mounted so when the door is attached the switch is depressed. Use some tape or something to depress the switch without the door on. you will not have enough hand to do it manually during testing. get your electrical meter and your ready to test. always remember that if the Main furnace switch is turned on any of the electrical connections, motors, etc. inside the furnace could be energized at any time.
step 1 : with main furnace switch on, both furnace doors removed, and door switch depressed go to your thermostat and turn a minimum of 5 degrees higher than ambient. if t-stat isnt on then something you did is wrong. check switches.
2: with newer t-stats there can be a delay. so wait 5 minutes then go to furnace.
3: put electrical meter in AC and in correct range if you have a cheapo meter. you will be reading 24v so correct range is the closest to 24v but must be above 24v. take your leads and put one on circuit board screw labeled R, other lead on C. you should read 24v or similar. minimum voltage should be about 22v. anything less than 20v there is a problem far before your thermostat. if you read 24v move on.
4: take your leads and put them on the W screw (heat) and C screw (common24v). You also should read 24v. If you get a reading less than 20v or no reading at all then you either have a bad thermostat or bad thermostat wire.
Oct 23, 2011 | Hunter Fan Company 5/1/1 Programmable...
I turned my thermostat down this morning to 68 degrees. I came back about 2 hours later to increase the temp to 70 degrees but when I push the ^ arrow instead of showing the increase to 70 it just flashes...
Since it's within 2 degrees of your setting it could be one of two things. Most furnaces run longer (pass your setting) to maintain the setting you made. Which really not a problem. However, your thermostat may need calibrating. To test this theory, place a regular wall thermometer next to your furnace's thermostat and see if the two temps match when the furnace cuts on and then when it cuts off.
If the temps are both the same, the furnace thermostat is fine.
If you're turning it down to 68, because no one will be at home during the day, just set it 2 degrees cooler than 68 degrees. You will then wind up with 68 degrees.
Feb 09, 2011 | Heating & Cooling
Starting this afternoon: Thermastat was set (Manual) to turn on at 68, display window showed 63 but the furnace was not running. I manually set the turn on temp below 63, then up to 67 and the systrm...
Definitely a thermostat.It has 2 sections.One is a temperature reference section(what temp you want).The other is the temp reading section.If either one is bad,it will do just like you said.Sounds like the reference section is probably bad because it comes on for a couple minutes then shuts down.Since it was fine earlier in the day,I doubt there is anything wrong with the furnace because as you can see,it is temperature related.A furnace problem would be more of no operation at all,even if just dirty or whatever.The thermostat also would be a more common 'fail component' than the board.A suggestion also,both for a car and a house.During the summer,run the heat for 2-3 minutes,just to cycle it occasionally.In winter,run the A/C for 2-3 minutes.Do both perhaps once or twice a month.It helps keep the components,somewhat fresh I guess you would say,because cycling it occasionally helps to keep it going good.Also,if you encounter a problem,you may be able to get it fixed before you really need it.In the meantime,feel free to come on down to FL until it's fixed,we have room,lol.Although it's chilly now,the weekend will be 70's.(sorry)Good luck,Greg
Dec 08, 2010 | Coleman Heating & Cooling
Furnace shuts off at 63 no matter where i set the thermostat
check the selector switch on the thermostat and if you have gas, it should be on HG. If you have electric, it should be on HE. If you have an amp meter(clamp on style), check the white wire for amperage with the heat on. What ever the reading(.7 for example) set the heat anticipator located on the subbase to that number. this is for efficiency and must be set to the proper setting or the heat will not cut in and out properly
Jan 02, 2010 | Honeywell Electronic Programmable...
Have gas furnace and this winter,began having
The Thermostat Wizard is an interactive tool that will guide you through wiring and troubleshooting your thermostat, as well as programming it to the most comfortable settings for you and your family. Simply answer the questions from the Thermostat Wizard to correctly connect, troubleshoot and/or program your Honeywell Thermostat. You can even print the instructions and bring them right to the thermostat to help make things easier.
Go to: http://yourhome.honeywell.com/Consumer/Cultures/en-US/Support/Thermostat+Wizard/
However - the problem is probably not with your thermostat but with your furnace. It is most likely a dirty flame sensor - a maintenance issue. If you have not had your furnace serviced recently (more than 1 year) that is where you should start. Modern furnaces require regular maintenance.
Please rate my answer!
Feb 28, 2009 | Honeywell Electronic Programmable...
Need help with rth230b
AFTER ST UP. HOW DO YOU PUT IT IN PROGRAM MODE?
Jan 23, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
865 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
