Question about Car Audio & Video
IWDVD-100 does not play my HD DVDs.
The IWDVD-100 DVD player (12 vdc) in my travel trailer does not play HD DVDs of Planet Earth. Is there a firmware upgrade available to resolve this so the DVD player will play high definition DVDs?
  • chuck c Aug 03, 2012
    have the same Iwdvd-100. My problem is that the tv screen goes blank when i play a dvd. any thoughts
SOURCE: DVDPLAYER WILL NOT PLAY DVDS
i've heard similar complaints before. usually if you reset the head unit it starts to work.
Posted on Jun 14, 2009
SOURCE: Pioneer DV-260 DVD player cannot play HD DVD
thats like trying to play a dvd ina cd player. cant be done.
Posted on Nov 17, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Can not play BBC Video Planet Earth
Unfortunately, Samsung does not currently have a firmware update available for that model, but you can check the Samsung Download Center periodically to see if they eventually have one (I'm a little skeptical, b/c this is an analog player).
There are several possibilities:
1) You said it was a "BBC" movie - if the movie was designed for play in the UK, and you live in the US, then the disc might not be a Region 1 disc. If this is the case, you will not be able to play that particular disc in the player. To be sure, check the back of the DVD - it should have a globe that either says "ALL" or is numbered 1 through 6. Region 1 is United States.
2) Is this the only disc that is having the problem? If so, what type of disc is it? If it is a burned disc, try finalizing the disc. If the disc type is variable, then it won't work in that player.
3) Are there any scratches on the disc? If so, there is a product that is alternately called Disc Skip Fixer or Disk Scratch Fixer. They are easy to find in a video game shop, although many stores will have them. Very nifty.
-Tha Mp3 Doctor
Posted on Jan 03, 2009
SOURCE: AVR 2807 shuts off at high volumes
I had the same problem. Rebooting did the trick. Reboot the unit per the instructions provided by another user on the main page. Here they are:
To reboot, turn receiver off by the small on/off button, not the big standby button. While off press the night and pure direct button at the same time and keep holding them with your right hand while pressing the small on/off button with your left. You will see your receiver menu flash. When you see it flash let go of the night and pure direct button and the receiver will reset it self to the radio station 87.50. The receiver's microprocessor has now been set back to factory.
Posted on Jan 17, 2009
herzon29
SOURCE: Sony SLV-D350P dvd/vhs player won't play most DVDs
hold the ejct bottom when is unplug and plug it bacck while u r holding the eject bottom for 10 seconds at least this will re set the dvd vcr
or stick ur fingers in the door conpartment of the vcr while ejecting helping the vhs to get out......last resourse unplug it take apart careful the vcr and put it back carefully
Posted on Mar 21, 2012
- All my DVD Blu-ray Discs became suddenly unreadable, ("planet earth" BBC DVD, "HD Sampler" Blu-ray, "Cars" from Disney Pixar) Non Blu-ray DVD are readable. Blu-ray Disc...
There are two different lasers on the drive.. Red for DVD and CD.. Blue for Blu Ray..
The Blue Laser may have failed.
Of course it always helps to check drivers and firmware updates for the drive itself. There was one firmware update 12/2010 for this player at the Panasonic USA website (support) Version 1.43
Finally Check your BD Ratings settings. There is a setting that could prevent all Blue Ray Discs from being played. It should be set to NO LIMIT which allows any rating. Page 24 of your manual.
Best of luck!
May 12, 2011 | Panasonic Dmp-b100 8.9 in. DVD Player
How do you bypass the parking brake installation to play dvds without being in park
Well you get a resistor, 100 OHMS - 1000 OHMS or even, maybe a 12v light bulb, and connect it to either + 12 volts, or - Negative Earth, depending on how it is wired, and this will allow you to operate it...
Mar 06, 2010 | Pioneer AVH-5700DVD Car DVD Player
I am in need to unlock my TOSHIBA HD-A35 HD DVD player so it can play region 4 dvds. Can u help?
There is no region free firmware available for your player at the moment. There is a guy in australia who has created one but will not release it. HD DVD's dont have region coding. I assume its for regular dvds?
Jun 16, 2009 | Toshiba HD-A30 HD-DVD Player
Zenith DVD Player--DVB410/ZND400
I got two new disks to-day with pictures taken from 35mm slides. They will not play on my zenith znd400 dvd player. I wonder why??????
May 10, 2008 | Zenith DVB412 DVD Player
Thompson DVD DTH271E refuses to play HD DVDs but fine normal DVDS, cant seem to get any help via Thompson, & think may need "firmfare" update? New machine but in Spain & language...
Hello there.
Push "Play/Pause" and "DVD Rec" on the dvd recorder a few seconds to see the service menu. There you can find your firmware version.
Post back the version for us.
Hope this helps.
May 06, 2008 | Televison & Video
Toshiba HD-A3 won't load HD-DVD
It should recognise the discs. If you just bought it new, it's under warranty. Take it back and exchange it.
Geno
Mar 05, 2008 | Televison & Video
Feb 16, 2008 | Pioneer DV-260 DVD Player
Unlock to use Region 2 dvds
No region hack for this player.
Jan 29, 2008 | Toshiba HD-A30 HD-DVD Player
HDMI quit working with store bought DVDs
so you have to update a new firmware and then it will be ok
Dec 20, 2007 | Toshiba 52HMX84 52" Rear Projection...
No sound
try changing the cable, or use a different source.  It may just be the optics aren't functioning correctly.
Oct 19, 2007 | Toshiba HD-A20
Car Audio & Video Logo
335 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
