Question about GE Spacemaker JVM1640SJ Microwave Oven
I need a smart board for my 1995 spacemaker microwave
The model number that is inside of the microwave on the nomenclature tag isn't found during search.G.E.Spacemaker Microwave.Model JVM231BV001.Number on board is JVM250BL.
  • 1 more comment
  • Anonymous Dec 25, 2008
    I also cannot find anything when I search my model number JVM231BV001 over the range microwave. It just stopped heating today.
  • jenifercros4
    jenifercros4 Mar 21, 2013
    I also cannot find anything when I search my model number BOV8OOXL over the range microwave. It just stopped heating today. Breville Smart Oven
  • jenifercros4
Tulip
SOURCE: GE SpaceMaker Microwave suddenly stops while heating
I had same problem last week. My GE JVM1650 Spacemaker stopped after a few seconds of heating. Owned 16 months, manufactured Jan 2005. It was the magnetron, which was replaced yesterday. The magnetron has a 10-year warranty, but I had to pay $161.00 for labor by a GE technician. The call-out fee was waived at my request. I don't know what that amount would have been, but I can't believe the $161.00 for what was about 1/2 hour labor once diagnosed. Good Luck!
Posted on Sep 21, 2006
  • 4 Answers
SOURCE: Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
Posted on Nov 29, 2007
  • 96 Answers
SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Posted on Jan 22, 2008
  • 3 Answers
My microwave was totally dead. Things I discovered: 1) There is an easily replacable fuse accessed by taking off the top front vent cover (two screws on top, gently massage off) and then the inside plastic grill. UNPLUG before doing this! 2) Pop off two wires on either end of fuse holder for safety. Then pop out fuse and replace. For more extensive help, there is an evelope with a wiring diagram inside the case on the inside wall! Very helpful when diagnosing the surface lamp problem (I forgot to plug the ballast back in when I closed up the bottom).
Posted on May 15, 2008
vitg55
  • 78 Answers
SOURCE: My Ge SpaceMaker XL1800 Microwave Oven won't power on any more.
1.Check power outlet for working.
2.If it is than you have broken fuse inside the m/w.
3. To change the fuse you have to disconnect the power to m/w, take the upper grill off, take the screw on top of control panel, lift the control panel up and removed. The 20 Am fuse located behind this panel.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Posted on Dec 15, 2008
Ge spacemaker xl1800 vent fan
I'm betting your base model number is JVM1860, JVM1861, JVM1870, JVM1871, JVM3660, or JVM3670.
That's the automatic louver you're having trouble with. There are micro switches in the louver assembly which tell the controller when the louver is open or closed.
If one of those switches or the louver motor fails, the louver will not work correctly.
Did your cooktop lights recently fail?
Sometimes the surge from them shorting will cause damage to the circuit board, which can be repaired.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 03, 2013 | GE Profile Spacemaker XL 1800 36"...
Relace bulbs ge spacemaker model JVM164OCj02 light that illuminates cooking surface of stove
That model would be JVM1640CJ02.
That is covered on page 33 of your owner's manual.
If for some reason you don't still have yours, you can download it here.
Always be sure you unplug power before you remove or install bulbs in a microwave.
Otherwise you may need circuit board repair.
Oct 06, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Ge keypad shorted
Sometimes it's a simple DIY job to fix this.
But we would need the full model number with any suffix in order to provide you with free assistance.
It is usually found on a tag located inside the cooking cavity or around the door frame or controller frame.
Since FixYa is still not notifying us when you respond to clarification requests, you will have to post a new help request with your model number and symptoms / questions.
Or feel free to contact us directly here for free help.
Sep 17, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I own a GE profile spacemaker jvm1490. When the door is closed there is a running noise. It stops if the door is pulled slightly. It also makes this noise when the microwave is in cook or reheat mode. ...
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
You may have a shorted cooling fan relay on the control circuit board.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid with a one-year guarantee.
Or you can order a whole new control circuit board (smart board) here.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
Aug 22, 2010 | GE JVM1490 Convection/Microwave Oven
Panel mulfunction , GE Microwave Oven Spacemaker XL1800 JVM1850WH
It sounds like a bad filter capacitor on the circuit board, which we repair often, and possibly a bad door switch.
We would need to know you full model number from the tag in or on the unit.
FixYa does not currently notify us experts when someone replies to help requests, so you would need to post a new help request with the same info you did, but include your full model number.
Apr 18, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Where can i buy a control panel for a ge profile microwave model hvm1540
If you have pads failing on the membrane keypad or an "F3" error, you can buy the control panel assembly with a new keypad already attached here.
(You will need to enter your full model number from the tag in or on the unit, such as HVM1540WW001, etc.)
If you have other trouble, and it is the control board ("smart board") that is at fault, you can buy a new one here or you can get it repaired here for only $39.95 in most cases.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jan 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
There is a 9 on the display and a constant buzzing
Chances are you have a bad electrolytic capacitor, crack, or defective regulator on the smart board (circuit board) of the control panel assembly.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
prototech@usa.net
Jan 08, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Need a light cover; can't get to model number
The model number should be on a tag inside the cooking cavity.
Once you find it, you can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jun 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Model of 1989 GE Spacemaker
The model number should be on a tag as shown in the drawing below.
Feb 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
383 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
