Question about Visioneer 4400 Flatbed Scanner
Replacement Motor for Scanner
Where can the actual motor (Mototech EMTRO 26600) be purchased? Mine is doing the same thing and I believe the electric motor is shot?
Thanks
  • Tropic125 Nov 25, 2008
    Please delete my problem, because no one can seem to help me.
    Thanks
    Martin
  • Tropic125 Dec 07, 2008
    Please delete this post, as it seems that no one can help me.
    Thanks
    Martin
2 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: Primax Colorado Step motor
See if this website can help you out
Posted on Jul 17, 2008
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    I have the Braun 9595 and believe my motor/drive unit need to be replaced. I have read that even if I purchased the part myself, I would not be able to remove the old motor and install the new one as the...
    DC motors usually do need to aligned to controllers however, with electric shavers they are usually sold together as a "drive unit." Now as far as your shaver goes, I could not find a replacement drive unit and what I did find showed that it was discontinued. Sorry. Braun 9595 5671 Pulsonic Parts
    Nov 28, 2017 | Braun Activator 8595 Electric Shaver
    I believe the fan just went out. how do you replace the fan or who would i call to service it...
    replacing a fan motor is not the easiest thing to do. Finding the replacement motor is sometimes even harder.
    I would suggest you check the phone book and find a good AC Tech and have him/her to trouble shoot the AC and determine your problem (it might not be the fan motor).
    Sometimes a good Tech will actually save you 'money and time.'
    Aug 05, 2011 | Heating & Cooling
    New Rainbow purchased 3 weeks ago. Went to a friends home which purchased one also and her's is very quite. Mine on Low setting to use as air clearner you can hear it in the next two rooms. Her's you had...
    Your new rainbow is still under warranty I believe so explain it to the company and ask for another. I too had a rainbow however I am like your friend in which mine worked very well. The noise is coming from the motor housing or the motor itself. Good Luck
    Jan 06, 2011 | Rainbow Vacuums
    2003 Hyundai Elantra Check Engine Light On
    Take the car to Autozone or purchase a scanner and scan it for codes. Then do the repair and use the scanner or return to Autozone and have them turn off the light.
    Apr 06, 2010 | Hyundai Motor 2003 Elantra
    Problems with exhaust fan NuTone Model LS 100SE
    The fan/motor part of the Broan fan is replaceable. They are actually very simple to take out and install a new part.
    The part can be easily purchase here...
    http://parts.broan-nutone.com/broan/Shop
    Heatman101
    Feb 27, 2010 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
    I have recently purchased used powermatic 66 Table
    That is the current setting for a motor-starter which is an overcurrent sensor. This is a circuit breaker like device that usually has a heater coil that opens a contact which cuts the power to the relay that powers the motor to prevent overload damage to the motor.
    The dial is in AMPS and should be set just slightly higher than the nameplate amp rating for the motor.
    Oct 24, 2009 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
    (I need a new electric motor for my air compressor. Where do I find one?
    I think I can help you guys needing a replacement CC-5440M12 120V/60Hz Ronning Motor. I have been cleaning out my shop and I have four (4) of these used electric motors. All work fine. They still have the plastic fan blade on one end and the metal gear on the other. I actually have electric cords wired up on each of them that I used to make sure they worked.
    Thought I would pass this information on to you. Thanks and have a great day.
    Oct 07, 2008 | Dewalt 2 Hp 4 GAL Air Compressor
    Replacement motor
    The manual only show one wire from the motor going to the switch, the other going to the cord, then the ground wire. I would wire it the way your old motor was, could be that some models maybe were 2 speed and the other wire would be used for that. Either that or the wrong motor was in the box, it is the right part number (43576197 is Hoover number)
    Nov 15, 2007 | Vacuums
    Visioneer 4400 Flatbed Scanner Logo
    55 people viewed this question
    Top Visioneer Office Equipment & Supplies Experts
    TomHighRidge
    Mark Gough
    Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
