Question about Kenmore 46462 Front Load Washer
All cycle indicator lights blinking?
All of the cycle indicator lights are blinking and the "add a garment" light is on. there is nothing about this particular combination in the owners manual. I unplugged the machine and waited, powered it back on to "drain and spin" since I stopped the rinse and spin cycle before it was done. Still all lights are blinking. I have power, water is on, all hoses are clear. what can I do to reset this to avoid a service call? thank you
  • Janet Damian Jul 14, 2007
    you cannot avoid a service call, when all of the lights are blinking, it means you need a new computer! crazy as it sounds. we were under warranty and didn't have to pay for it.
    good luck
  • theroge Nov 02, 2008
    exact same problem. has anyone found how to fix it without a costly service call or a new computer?
  • 641 Answers
Thanks for the information.
Posted on Aug 17, 2007
SOURCE:
Kenmore h2 error code
April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
MODELS: See additional page for Kenmore model numbers
COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Kenmore 46462 Front Load Washer
I have a whirlpool ghw9100lw the light is flashing but it will not start
Aug 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Can't get washer to start again after pushing pause/cancel button
sounds like central control unit problem, you can check for diagnostic mode operation by setting (door closed) drain/spin, no spin, pressing prewash 4 times in 5 secs pressing prewash again will advance through diagnostic cycle. replacing user interface may also be necessary
Apr 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control Lock
Kenmore 46462 Front Load Washer Logo
303 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
