Question about HP Computers & Internet
Sometime I hear a buzzing sound in my computer
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    can you describe the buzzing sound please
  • David Preston
    David Preston May 11, 2010
    OK by IN your computer, do you mean from the speaker? Or from INSIDE the case?
    thanks
    Dave
  • 34 Answers
It may just be that your case is touching something solid like your desk. Make sure your case is clear of everything and that the rubber pads under it are still on.
Posted on Nov 16, 2008
Annoying sound
Hi Anita
Determine source of Buzz
Speaker --- Computers sound channel Amplifier
Left or Right channel
Can you hear buzz in earphones
Fan --- Speed changes with Temperature - insects or junk hitting on fan
CD --- Player mechanism - CD media left inside
Good Luck
Dec 06, 2013 | Toshiba Satellite Computers & Internet
Hearing a buzzing sound at start up.
I think that your PSU is dead and your motherboard must be dead too (not sure)
Dec 16, 2012 | Computers & Internet
I have a samsung side by side fridge and it is an RS285LA. For awhile now it has been making this buzzing sound from what sounds like to be coming from the back. This buzz sound is kinda loud cause I...
its the relay for the ice maker.. they are loud if the don't have water going threw them, you may want to shut off your ice maker. lift the arm to the up position. that turns off the ice maker.. if'n i was of hel vote YES .. jay the pool pump repair guy in longwood fl
Jul 05, 2011 | Refrigerators
My bmw x5 diesel 2002 not starting when engine has run for 30 or more minutes, and also sometime it does not start in the morning the battery is nearly dead. i have realised that even if i took the...
Hi , this sounds like you have a couple of problems , firstly with the non starting after the engine has been running ,,, this is normally fuel pressure retension or the pre supply pump under the vehicle is faulty , the easiest way to check the pump, is when your vehicle doesn't start with the ignition lights still on , see if you can hear a buzzing noise from under the vehicle just behind the left hand front wheel , this will only prime itself for approx 20 seconds so it may be easier to have the help of someone , if you dont hear the buzzing turn the ignition off for 1 minute and switch on again , if there is no buzzing noise , replace the pre supply pump , the seccond fault with the blower motor running with the ignition off is a simple fault , this will require a replacment heater resistor , the resistor fails and drains the battery so it will cure the blower fault and the flat battery, hope this helps , regards mark
Jan 31, 2011 | 2005 BMW X5
I have a 1993 dodge caravan and it wont start. the buzz sound that i use to hear when the car starts i dont hear any more. the sound came from the back of the car. when i turn the key it sound as if it...
Sound like your fuel pump quit working. That is what makes the buzzing sound from the back. Sometime if you have someone that can help you you can bang on the gas tank while turning it over to get it started to get it home.
Nov 08, 2010 | 1993 Dodge Caravan
I have a Flat screen PL913s monitor. I just replaces the 6 electrolytic caps on the power supply board and now the monitor that was totally blank before works, but only for about two minutes and then I...
The buzzing sound can be from arcing at the lamp connectors, please verify that all the lamp connectors are seated back into the socket securely. Try checking that first and post back. I have done that sometime myself. Hopefully it is not from lamp assemblies.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 16, 2010 | Proview PL913S 19" Flat Panel LCD Monitor
Sometime a sound come from my computer?
If the sound is happening right at power on, then it's coming from the motherboard's POST testing. Considering it stops, the most likely cause is a fan that is starting slower than normal (wearing out), and is falling below the speed threshold set in the BIOS configuration.
Oct 28, 2009 | Computers & Internet
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
