Question about Eclipse (XA1000) Car Audio Amplifier
L or r speakers will not play when the volume is low
Speakers are cuting( left, right, front, and back) off when the volume is low or when the system is cold. have changed everything except the amp. somtimes even if i turn the volume up the speakers will fade in and out. then no sound at all.
    Problem Solver:
  • 12 Answers
Sounds like you have a wiring problem or the amp is bad. take it to a stereo shop.
Posted on Dec 10, 2008
What would be wrong with my kenwood-krf-v5100d and the front right and left speaker out lets are not working propaly sound dose come out of them but it is real low and when you go to turn them up inde
There is a balance option. Find the manual for this player and look for balance. You are looking to change it to 0 so that it plays through all of your speakers at equL volumes
Jul 24, 2014 | Kenwood KRC-379R Cassette Player
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Car stereo speaker only works with volume turned way up
try the fade button, if its a 4 speaker system you have balance left and right, and fade front and rear.
Dec 21, 2011 | Clarion Car Audio & Video
Very low volume output even with the volume turn all the way up. I connected the system to different computers and came up with the same problem. The volume on the computer is also turn all the way up and...
I had the same problem and found the root cause to be the RF speaker connector at the back of the subwoofer. The male and female connectors are OK. It is the 5 male pins inside the connector and the way they connect to the female holes that is the problem. Wiggle the RF speker connector as you move it in and out until you get 100% of audio voilume back. Once you get it back, do not move the connector. Have not found a permanent solution to date beyond this.
Jan 08, 2010 | Dell ADA745 Computer Speakers
JBL Creature Speakers have very low volume
I had the same problem. Then I read about the volume controls on the right speaker. They are silver buttons for me on the front bottom left and right of the speaker. Now they play really loud!
May 30, 2009 | JBL CREATURE II Computer Speakers
Low sound coming from soundsticks II
On the right stick, there are two metal pieces at the bottom of the stick. The right one is + for volume up, and the left is - for volume down.
Press the + one a few times with your finger as they are touch activated. Be careful though, as it can get loud very quickly. Play some music and set the computer volume to about half way. Then press the + speaker on the right hand side until you are happy with the volume.
Hope this helps,
Nathan.
Apr 08, 2009 | Harman Kardon Harmon Kardon SoundStick II...
Volume fade
Check to be sure there are no speaker wires touching ground, and that the wires are connected in phase to the head unit.
Front Speakers 5 1/4" Doors Left Front (+) Green Left Front (-) Black/White Right Front (+) White/Red Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Red Left Rear (-) Pink/Blue Right Rear (+) Pink/Light Blue Right Rear (-) Green/Red
The symptoms you are relaying definately sound like an internal amplifier problem. It is fading in and out for a reason - usually due to heat.
Have you had the radio bench tested (seperate from the car) to eliminate the car as being the culprit?
Since the radio was run with damaged speakers originally, the output or amplifier power supply on the amplifier may be bad.
As an alternative to repairing, I would suggest investing in a small 2 channel amplifier to power the speakers.
The radios claim 50W per channel, but in reality give 12-15W RMS power.
A dedicated amplifier with built in crossovers and gain adjustments will prolong the life of your speakers and add to the tonal qualities of your new speakers. Instead of turning up the volume on the head Unit, and sending out a distorted signal that will blow your speakers, an amplifier will give more CLEAN power to them, so it will be louder at a lower volume setting.
This will bypass the internal amplifier on the radio, and send a Low Level signal ONLY thru a set of RCA cables.
Good Luck!!
Jan 10, 2009 | Car Audio & Video
Speaker problems
You've probably tried this, but when you do the channel test you can turn the volume up or down on whichever speaker is currently being tested (the static). Maybe your speakers have been adjusted somehow.
Jun 08, 2008 | RCA RT2300 System
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
Eclipse (XA1000) Car Audio Amplifier Logo
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
