Question about Dell UltraSharp 1907FP 19" LCD Monitor
Small blue screen that says '' No composite input signal''
Running vista - Dell 19" monitor less than a yr. old - I think my cat walked on my keyboard and caused this, but not sure
  • Anonymous Dec 30, 2008
    My little brother was playing with the screen's buttons. Now you see two screens. The main window and a small blue one that says no signal. what do i do?
Go to menu on the monitor and choose setting then reset the default
Posted on Nov 17, 2008
Screen dead
connect a desktop monitor to VGA port from your laptop. if there will able to see the displays?.. you can go to control panel to reset the display settings and back that on to the normal screen settings.
Sep 05, 2014 | Dell Latitude D610 Laptop Computer -...
Monitor Compatibility with Vista
for your knowledge win xp or vista is not related to the moniter it will convert from its system compability so check out system configuration for vista and if it match with vista just load it and done.ok and if problem persist contact me
Dec 08, 2007 | Dell UltraSharp 1907FP 19" LCD Monitor
Pink Screen
Probably the color temperature setting or some other color settings - since you didn't specify your monitor's brand and model, it's hard to guess.
Anyway, most monitors have a "Reset to factory defaults" feature - you may want to make use of this...
Mar 10, 2010 | Dell Computers & Internet
Will not post at startup but then vista login pops up can not go into bios because the keyboard does not seem to work until vista kicks in. says it is in the powersave mode but I have disabled it in the...
is it a usb keyboard? usb keyboard support is probably off in the bios, so it will not recognise it untill windows loads driver for it. if you have an older keyboard around with the old purple PS2 plug on it, that should work for you to get into the bios. then turn on USB keyboard and mouse support.
Nov 18, 2009 | Dell Computers & Internet
After replugging lcd monitor and starting comp it was pink
Try disconnecting the VGA cable from the computer and checking that the pins in the connector are all straight
Mar 22, 2009 | Gateway 19" Flat Panel LCD Monitor
I have same problem despite truning off screen saver and setting power options to NEVER SLEEP! I have same dell monitor, running wondows vista basic in dell vostro! anyone with a solution. this PC is less...
If the problems happens on another computer then call dell to get the problem resolved. You could also go into the system setup by pressing F2 when the computer loads up and see if it happens in their, or you can also put the known good monitor in your system and it you get the same problem the problem is with the computer and the issue is either a hardware or software issue. If the problem happens in the system setup or during the diagnostics then the issue is hardware. Please call dell tech support if you find out the issue is points to the monitor and we would be glad to replace the monitor, if the monitor is not tied to the system(not in the order details or was purchased later) then the monitor has a 3 year warranty, if the monitor was purchased with the system , the warranty is the same as the system or if that warranty more than 3 years than the warranty for the monitor is still only 3 years. Thanks and please reply back if you still need assistance.
Mar 09, 2009 | Dell E228WFP LCD Monitor
Dsfsdfd dsf dsdsf d fdfdfdfdfd sdff fds?
i think something is stuck in your keyboard or your keys in the keyboard are stuck namely dsfsdfd dsf dsdsf d fdfdfdfdfd sdff fds try yanking it one by one or replace it with a new keyboard because your keyboard maybee having alot of dust stuck inside causing to stuck the keys,,, thank you and have a nice day.
Dec 11, 2008 | Dell E193FP 19" LCD Monitor
Poor screen quality
re install your dell video card driver
Oct 19, 2008 | Acer AL1916W 19" LCD Monitor
Yellow hue
My name is Todd and I'm with Dell's online outreach group.  Have you tried hooking that monitor up to another system to see whether it's the monitor itself or the system causing the problem?
Is the color distortion always there, or is it only happening at certain times or with certain applications or programs?
Let me know if you're able to try this monitor on another system, or another monitor with this system.  If not, we can try a few different things to test it.
Thank you,
Todd
Customer Advocate
Dell, Inc.
http://direct2dell.com/one2one/archive/2006/11/19/3648.aspx
Oct 08, 2007 | Balance CM2019 19" LCD Monitor
Dell UltraSharp 1907FP 19" LCD Monitor Logo
1,168 people viewed this question
Alun Cox
