My drain hose is clogged. It is the large drain hose on the back of the machine that allows the water to go into my household drain. I dont know how to detach it from the washer to clean it.
SOURCE: lg wm1814cw model front load,
What you can do is go into the test mode, and see if the drain pump is operating, if not you will need a need drain pump. Do not put it into spin in test mode if you have clothes in there
Sgt 48
SOURCE: LG WM2233H* Clogged drain
After draining and cleaning filter, reset washer--Unplug unit and hold Start (selector) button for 10 seconds. Plug unit in and restart.
SOURCE: water pours from drain hose overflow in front of washer
That drain hose in front has a stopper, to prevent discharge. Either it is not there or not tight or something. You can always clog it shut with a round wood bit inserted or something........I don't think it is too difficult.
SOURCE: LG WM2487 front load washer spews suds out of port on rear.
You are likely using too much detergent or the detergent is not high-efficiency detergent. Change detergents and/or lower amount and this problem should go away.
The water port on the back allows air inside the tub to escape. However, if the wrong type or quantity of detergent are used, excess suds will flow from this port.
SOURCE: wm2688h will not drain anymore.
You need to take a flashlight and look into the suction port on the pump. Make sure the pump is not clogged and check the pump impeller. Make sure that no blades are broken or missing and the impeller should spin freely. If any blades are missing or broken on the impeller or if it will not turn freely, the pump will have to be replaced. Hopefully, it is just a clogged pump. Hope this helps and best wishes.
