Question about Dryers
Fridgidare dryer problem
Dryer drum is sitting low and clothes get stuck in the gap. A squeeling noise is heard after item gets stuck. Seal is bad??? i have clothes getting stuck in the front top of the drum. i also had a bad squeek, so i replaced the drum bearing but the clothes are still getting stuck. is there a spacer that holds the drum up that i am missing? please help, my wife is getting very aggrivated.
    President:
  • Dryers Master
  • 2,651 Answers
There is a front glide assembly, depending on model will have 3 teflon/plastic glides attached t o the felt, this may be your grinding and gap issue
Posted on Nov 16, 2008
Stackable dryer. clothes gettin stuck in dyer causing holes in clothing
well depending on the brand some brands use a felt seal in the rear and front of drum to seal against the door shroud overtime the felt wears down and clothing get snagged in the gap as the drum turns and tears clothing....
Jan 26, 2011 | Washing Machines
Maytag dryer is leaving black marks or rings on clothes
If your clothes get marked or torn in your dryer, check these: Rollers Rear seal Front glides Front seal Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Aug 01, 2010 | Maytag Dryers
Grease type substance inside
Hello. I know exactly what is wrong with your dryer.
Rollers
Rear seal
Front glides
Front seal
Jun 07, 2009 | Dryers
Frigidaire Dryer. Clothes are damaged by either being ripped when caught on dryer drum. Clothes also are marked with hard to remove rub marks.
Open the dryer door. Reach in just inside and feel for the felt seal that goes all of the way around the drum. The culprit is usually the top portion of the seal which supports the end of the drum near the door is worn out. This allows the drum to tip down and leaves a gap at the bottom. Clothes get caught in this gap and get rubbed and marked or rubbed clear through. Remove the front of the dryer and replace the seal. On some models the top 1/3 is replaceable. This portion carries the weight of the drum and is what wears out.
Jun 06, 2009 | Frigidaire FEQ1442ES Electric Dryer
Clothes get stuck between dryer and barrel
If your clothes get stuck, marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
May 31, 2009 | Electrolux Kenmore 5.8 cu. ft. Super...
Drum spins off center and clothes get stuck between drum and casing
Rollers
Rear seal
Front glides
Front seal
May 28, 2009 | Kenmore Dryers
Narrow streak of what looks like grease on clothes from dryer
hi anne-
May 09, 2009 | Dryers
Burn marks on clothing
The front felt drum seal may be bad. It is attached to the front panel, around the door.
Check and or replace the rear drum support it has worn down the ball and cup support. It will soon begin making a grinding/squealing noise.
When it wears and drops down the gap is greater at the front around the felt seal. Laundry gets caught in the gap and scorches.
Apr 20, 2009 | Dryers
Frigidaire dryers use a post and bearing support system. The noise you hear is the post grinding away on the support.00069740.jpg This is the kit to fix that dryer and a link to the kit
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1851&PPStack=1
It cost 24 bucks and ships overnight.
Now to fix it requires a phillip screw driver to undo all those screws, I would start with unplugging the unit, removing the two screws in back for the top panel, two screws for the bottom kick panel, located all the way down, hard to see so tilt unit back to access. Next is four screws at the front corners above the user panel and two inside at front left and right sides about nine inches down, now there are two more at the bottom of this door panel where you pulled the kick panel off. After this there is two wire harness clips, squeeze and pull they come off and gently pull at the top sides as there is retainer clips which secure the panel. Ok? Alright now you see the drum with belt attached, get a flashlight at memorize how the belt loops on the tensioner to the motor pulley and take a photo if needed:) Remove the belt and one more screw top middle in front holding a yellow bumper for the drum. The drum while come off by lifting the back of the drum firmly as it clips in place on the bearing support. Now pull the drum out and if I didnt warn you watch out for sharp edges. You will see the flange with shaft on the drum to replace and the bearing support on the back. The back portion screws together with two screws through a retainer to hold a small ball bearing in, I suggest getting a buddy to hold the back clip when replacing as it is a stretch. In the photo above you will see all the pieces on right go in this order metal clip, plastic cup, ball bearing onto panel and hold clip on back and insert two screws, with a buddy and some grease to hold the ball bearing this is the easy part. The flange has three screws and you must thread them with out stripping the heads off. A buddy again to share the moment is best to hold the drum while you insert the screws. The last part is putting a 1/2 tsp of grease in the plastic cup and following the instructions in reverse. Dont forget the wire harness as you reassemble or the belt looping on the tensioner.
Searstechtoo
Sep 13, 2008 | Frigidaire FGR341AC Electric Dryer
Frigidaire electric dryer; model # FDEB34RGS1
front drum seal needs replacing pop clips at front of dryer top ..lift top remove 1 secrew each side of front from the inside..remove wires lift panel off clips ckd front panel around door area for felt seal may also have embedded plastic drum glides a felt seal also goes around bottom half
May 05, 2008 | Frigidaire FGR341AC Electric Dryer
Dryers Logo
248 people viewed this question
Top Dryers Experts
