My universal remotes don't have a mode, input or tv/vcr option so I can switch to video 1 and use my vcr/dvd player. and the tv menu doesn't have an option either
SOURCE: philips universal remote - tv codes for Sylvania
This was a helpful hint. These codes worked where the other codes I got from the Philips and Sylvania websites did not. However, there is no need to put a zero in front of each code. Codes for universal remotes should only be four digits. - Thanks for the help!
SOURCE: No remote for small Orion TV - Input mode?
If u cant get to the aux screen try holding down or pressing one of the channel buttons very quickly.
Good Luck!
SOURCE: Can't find the input/video channel for my Emerson TV
universal remotes are tricky, if you have the pamphlet, often times there are several codes for each brand. you have to try all the emerson codes for your universal even tho the power, volume and channel functions may work with several emerson codes, some of these specialized buttons (like input) may only work on your TV with one specific code.
also, if there are any unlabeled buttons on the universal try them with each new emerson code.
SOURCE: I can't switch to aux/video without my remote.
not really sure about this but if you put a disk in then run auto scan for your channels,long shot but worth a try.
SOURCE: How can I input my sylvania 27"
Here are the instructions for the TV.
http://www.sylvaniaconsumerelectronics.com/pdf/om/6427TE.pdf
They do not say how to select Video or Game mode without the remote. Try connecting a vcr or game to the input and do the Channel Pre-Select process to see if that will pick up the input as part of the Channel Scan. If it does you will be able to get to Game or Video using the channel up/down buttons. Another option is to get a replacement universal remote that has a code for your TV and will assign a button for Game or Video.
