Question about Casio Cameras
My battery has been charging for 6 hours and my camera still isn't turning on!
    Novelist:
  • 208 Answers
WAS THE BATTERY COMPLETELY DEAD? IF SO, IT PROBABLY ISN'T UNUSAL FOR IT TO REQUIRE MORE THAN 6 HOURS TO RECHARGE. IF NOT, DEPENDING HOW OLD THE BATTERY IS AND HOW MANY TIMES IT HAS BEEN RECHARGED CAN MEAN THE BATTERY HAS REACHED THE END OF IT'S LIFE. THERE IS THE POSSIBILITY THAT THE CHARGER ISN'T WORKING ALSO. MAN! SO MANY THINGS TO GO WRONG! YEP! IT'S ONE OF THOSE PROBLEMS THAT TAKES A LOT OF CHECKING TO FIND THE EXACT CAUSE. IF YOU HAVE A METER ,CHECK THE CHARGER. IF YOU DON'T, TAKE IT TO A RADIO SHACK OR LIKES AND SEE IF THEY CAN CHECK IT FOR YOU! MOST WILL. THEN CHECK THE BATTERY TO SEE IF IT HAS A CHARGE. IF THE CHARGER IS GOOD, AND THE BATTERY DOESN'T TAKE A CHARGE, GET A NEW BATTERY. MY GUESS IS THE BATTERY HAS GONE SOUTH! TRY THESE AND IF YOU NEED MORE HELP REPLY TO: ARCLIGHT1217
Posted on Nov 16, 2008
I cant charge the battery through computer
The C183 isn't a battery charger. If you use rechargeable AA batteries in it, you must charge the batteries outside the camera using a separate battery charger.
Aug 01, 2012 | Kodak C183 Digital Camera
Canon Elura 90 camcorder
If the battery do not have any current after removing it from the charger, you can use 6 volt adaptor bust the battery before charging
Nov 03, 2011 | Video Cameras
My camera has been plugged into the computer for 24 hours now and the battery still isn't charged. How long does it take to charge and how will i know when it is done charging? i have a Vivicam X029
The manual merely says "a few hours." The LED on the back of the camera lights up while charging and goes off when finished. Not all computer USB ports put out enough current to charge batteries. If you're using a hub, bypass it and connect the camera directly to the port. If that doesn't do it, try another port if available. If that doesn't do it, use the supplied AC adapter and plug it into a wall outlet.
Aug 05, 2011 | Vivitar Cameras
How many hours do i charge my battery dor dsc t20 camera?
You can charge the battery of the Camera for 4 to 6 hours when used initially. For normal full recharging, it takes, 330 minutes. The practical charge time of the battery is for 270 minutes.
Thanks for using FixYa.
Jul 17, 2011 | Sony Cyber-shot DSC-T20 Digital Camera
I recieved a brand new Canon Rebel XSi in the mail. I throughly read the manual & assembled it carefully by the book. Kept it in all the correct settings. Also kept it in a warm, dry area. I grabbed...
Hi
You can try doing the steps below
1. Remove the battery from the camera
2. Remove the Memory chip
3. leave the camera for an Hour
4. After which you can install the battery only first
5. Recharge the camera first
6. Later when the camera is charged the battery
7. Install the chip if available
HOPE THIS WILL SOLVE THE PROBLEM
RATE MY SOLUTION
Jul 02, 2011 | Canon EOS Rebel XSi Digital Camera
How do you tell when the battery is fully charged. It continues to show that it is still charging when it would have to be fully charged. The battery is a 3.8V which isn't mentioned on the charger...
The light usually changes colors or goes from flashing to solid even from a light being on it going off when charged. Every camera is different. Normally a good hour will fully charge most camera batteries.
May 13, 2011 | Cameras
I have sony cybershot dsc 10 digital camera but it dsn't power on batery charge is full
Please make sure that the Battery in the Camera is fully charged.
Please check if the issue is with the battery charger. Make sure that the Charge Lamp in the Battery Charger is lit when connected to the Wall outlet.
You can try recharging the battery pack for almost 6 hours as initial charging.
If you've another battery pack, try using the same to check if the issue is with the Camera or with the battery.
You can also try turning on the Camera by connecting the optional ACL-S5K AC Adapter. This Adapter can be used for turning on the Camera, it cannot be used to charge the battery pack. For charging the battery in the Camera, the supplied battery charged needs to be used.
If the Camera is not turning on using both the AC Adapter and new battery, then the Camera may require service.
Jan 10, 2011 | Sony Cyber-shot DSC-H10 Digital Camera
I have sony digital camara but it dsn't power on batery charge is full
Jan 10, 2011 | Sony Cyber-shot DSC-H10/B Digital Camera
I have sony digital camara its not power on plz help me
Jan 10, 2011 | Sony Cameras
When I change batteries I loose date/time etc.
There isn't another battery built into it. From what I undersatnd once you have placed batteries into the camera or connected the AC adaptor into the camera for 2 hours the camera will retain the date/time settings for 6 hours.
If they haven't been in the camera for two hours and you remove them the camera will loose the settings. If they have been in the camera for over two hours the camera will keep the settings for 6 hours. This leads me to think that a capacitor on the board inside the camera charges up for two hours and then slowly discharges over 6. Hope this helps.
Jan 16, 2010 | Fuji FinePix S5000 Digital Camera
Cameras Logo
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
