Question about Bose Lifestyle 48 System
Lifestyle 48 Acoustic module doesn't work
My recently purchased Lifetsyle 48 Series III currently is not producing any sound. I don't think it has anything to do with the media centre as this seems to respond as expected using the remote. I even tested the speakers, making a direct connection to the media centre and they worked fine. I have re-checked all the connections and wiring about 1 hundred times. I also turned the acoustimass off several times @ 10 minutes intervals. I just can't figure it. All the connections are correct. They are all positioned firmly. All my powerpoints are fine. I have done all the usual tests i.e. mute on/off, CD on, checked the CD, checked volume etc. The digital display on the media centre is OK but no response from the acoustimass. Any ideas on this delema? PS: I am not sure what the audio drivers are or device manager is.
    New Friend:
There is a power fault in the acoustimass module but this can only be fixed by a qualified Bose Technician.Bad varistors should be replaced before the fuse.If this doesn't solve it,then the complete power board should be replaced.
Posted on May 26, 2017
    New Friend:
Call Bose tech support. They fix or replace these under warranty. I have a lifestyle 12, original model, after two repairs in. Ore than 10 years, I was allowed to upgrade to top of the line for the price difference.
Posted on Apr 24, 2017
Bose lifestyle 5 keeps shutting off sound
KEEPS SHUTTING OFF SOUND AFTER ABOUT 1 TO 2 HOURS OF PLAYING. HAS POWER, EVERYTHING LIGHTS. I THINK THE PROBLEM IS SOMEWHERE INSIDE THE ACCOUSTIMAS MODULE OR THE SUBWOOFER.
Dec 13, 2010 | Bose LifeStyle 5 Series-III CD Shelf...
Connecting optical cabel to ps3 and no sound
go to the setting on the ps3 and go to audi select the audio to play through optical
if this does not fix it then
make sure that the bose is in the correct mode to play through optical
Jan 14, 2010 | Bose Lifestyle 48 Series III System
Our Bose lifestyle 5 has no sound does the Bose CD disk restore the sound card. Mfg.1997 too old to do this must we buy a new one or does this cost a lot for repair ?
This can be repaired of it's later than a series 1. (not sure if the 1997 model was a series 1) Repair cost will be $225 plus tax (flat rate). Shipping is split between you and Bose. They give you a new 1 year warranty.
Otherwise, Bose can have you trade this in for about 25% off a new, current system.
-If this still powers up, make sure the small 1/8" portion of the input cable (plugged into "system control 1") is in good condition, because you may just need to replace that input cable for a no audio situation. If it's a different series, it will say "zone 1" I think.
In either case, you should call Bose tech support about this. (800-367-4008) Make sure you're with your system so they know what series of LS5 this is.
Jul 17, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Audio problems connecting ps3 to bose lifestyle 48 system
audio has to connected seperatly.vs 2 is for video connection only..Bose is a ripoff.... u pay all that money and you need a seperate audio connection plus all those wires..it isn't worth it and regret i bought it.
Jun 14, 2009 | Bose Lifestyle 48 Series III System
Display not working
I think there are some solutions available from www.AnyoneCanFixIt.com for the Bose Lifestyle 20 series with the display issue.
May 26, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Remote control program codes
want to know the code for bose lifestyle5.
Jun 17, 2008 | Bose LifeStyle 5 Series-III CD Shelf...
No sound Lifestyle 5
Hi the problem could be a burnt out R428 resistor replace with a 330 ohm
Dave
May 12, 2008 | Bose LifeStyle 5 Series-III CD Shelf...
Only sound for cd/dvd
Could be damaged cable between the media centre and bass module (check along cable length for damage, kinks or at DIN plug ends for bent/damaged pins), faulty media centre (unlikely) or fault in the bass module....
Jan 13, 2008 | Bose Lifestyle 48 System
Bose Lifestyle 48 System Logo
161 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
