Question about Dremel 8000 01 Cordless Rotary Tool Kit Variable Speed 10.8 Volt Lithium Ion
Model 800 Dremel cordless won't work
After fully charging the battery of my model 800, 10.8 volt, variable speed Lithium ion battery Dremel, I can't get it to work more than a second or two at a time.
It dies and won't restart unless I wait, or disconnect the battery and put it back on. When this was new, it worked fine until the battery died, and has never worked since.
I thought the battery wasn't charging at first, but today it works for a second, then quits.
Any ideas?
  • 1 more comment
  • dianamca Nov 16, 2008
    I'll give it a shot starting tonight, thanks
  • pepperton Feb 23, 2009
    I have the same problem. I have two batteries and after charging them both, the same thing is happening. The tool starts OK but after 10 seconds or so, dies. Both batteries are doing this.
  • jtelswick Mar 08, 2009
    I got mine new as a gift, but didn't get around to using it for nearly a year. I charged it overnight, and when I went to use it, it would start and run, but would cut off if I put it under even the lightest of loads. I couldent even polish with it.
    Scholar:
  • 132 Answers
Try putting the battery in the charger with the power turned off (unplugged from wall socket ) leave over night then start recharging fresh and dont disturb for 10hours after 10 hours see if any better hope this helps glenn.........
Posted on Nov 16, 2008
Okay, I followed the advice by the one previous fix, and discharged the battery. I sat and switched it on and ran it until it died, and disconnected and reconnected the battery, and did it all over again and again (it took about an hour) until the battery was TOTALLY drained. The next day I put it on the charger for 10 hours. It works perfectly now. I can't believe how long it will run on a charge, and it is really powerful. Thanks for the advice.
Tom
Posted on Mar 09, 2009
Dremel charger model 856 won't charge. Charging light will not come on.
I had a similar problem. I was going to take the charger apart but I ran into triangular socket head screws so in desperation I gently bent the 5 contact wires out from the battery socket. After slipping in the battery and plugging the charger into the wall socket, the charging light returned. The charger contacts that come into contact with the battery are easily pushed back and after a few battery insertions fail to make contact with the battery.
Feb 10, 2013 | Dremel 10.8V Lithium-Ion Cordless Rotary...
Dremel 10.8V cordless model 800 (8000) The speed is stuck on the high setting (variable doesn't work now) and battery lights no longer work. I'm assuming its the switch and now needs expensive repair. Only...
You are right,it will need a slider switch replacement,But first-is it still under warranty?If it is call the costumer support on their 1-800 ...number.If not you could DIY it.Opening the drill is not that hard and as long as you observe the proper orientation and where every wire is connected to,you will be able to disassemble the unit.Inside you could see where the slider switch is connected and how it is positioned.Usually the surface of the switch is burned out and this you have to replace.The next problem is locate the part number it is usually found printed under the slider part.And the next big thing is to order the part and where to order it.Consult the user manual that came with Dremel unit and the ordering address is there.
Nov 06, 2010 | Dremel 8000 01 Cordless Rotary Tool Kit...
Dremel Model 800, 10.8v Lithium-Ion cordless Tool voltage reg.
Read off the identity on the regulator. That is the part number to order from an electronics outlet.
Feb 24, 2018 | Dremel Saws
Where can i find an instruction manual for the clarke ct4009 rotary tool
i have a dremel cordless rotary tool but have no manual,if anyone has one for the Dremel Lithium-ion cordless 10.8 variable 5,000-35,000 rpm model 800,can you kindly email it or tell me where to download it from at
rkellock@eastlink.ca
thanks "R"
Jul 08, 2009 | Tools & Hardware - Others
Battery on my cordless dremel will not charge.
Dremel Stylus AC/DC Adapter 230/240V Transformer primary is open circuit any idea what the AC output of the transformer is. I should be the same for 110V input transformer. If I can find the output voltage from the transformer I can probably get a replacement
Apr 01, 2009 | Dremel 8000 01 Cordless Rotary Tool Kit...
Cordless Dremel variable speed stuck on maximum
Hi, There are several dealers in London who can help you solve your problem. The following link is has a list of those dealers with addresses and phone numbers:
http://www.dremeleurope.com/dremel/dealerlocator/index.cfm?lang=en-GB
Good Luck to you, this should Fixya!
Mar 02, 2009 | Dremel 8000 01 Cordless Rotary Tool Kit...
New dremel
It was just retired there is nothing recalled its just an old model
Oct 17, 2008 | Dremel 8000 01 Cordless Rotary Tool Kit...
Cut out tool Comparison
Cut out tools are available in both cordless and corded versions. Cordless tools can be more convenient. The corded versions are slightly more powerful than cordless.
Aug 27, 2008 | Dremel 8000 01 Cordless Rotary Tool Kit...
Dremel 8000 01 Cordless Rotary Tool Kit Variable Speed 10.8 Volt Lithium Ion Logo
3,210 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
