Question about Kenmore Elite HE4 Electric Dryer
Burning smell Kenmore HE dryer is 6 years old. I have been doing laundry all day with no problems...tonight the dryer started smelling like something was burning inside. I removed all the clothes, checked the lint screen and the exhaust tubing - all is fine. The smoke smell seems like it is coming from the heater vent inside the dryer drum. It does not smell electrical, more like paper, cloth or lint burning...
  • 2 more comments
  • tracy_newqui Nov 16, 2008
    Thank you. This worked!!...no more burning smell! We found an abundance of lint. However, not my dryer will not blow hot air??
  • tracy_newqui Nov 17, 2008
    You have been most helpful. Thank you for your assistance - I think we will be calling a repair man to fix it at this point. Have a nice evening.
  • Traci Bruner
    Traci Bruner Oct 06, 2013
    OMG! This saved us $$ thank you!!! Our dryer was literally full of lint at the bottom of it. We keep the hose clean, but never thought to open up bottom and back of unit to clean it out. Thank you!
  • Anonymous Mar 30, 2014
    Our 1 year old LG dryer smells terrible suddenly. We have searched under and around it - looking for a dead mouse or something - but it seems to come from inside.
    President:
  • Kenmore Master
  • 2,651 Answers
You can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Posted on Nov 16, 2008
  • Ron Coons
    Ron Coons Nov 17, 2008
    chances are youve blown a thermostat. if you have a powermeter you will need to check for continuity in all of your thermostats, located by the heater assembly. im sure if ther was any "flame" they got to hot and did what they are there to do, shut down the heat source. saftey reasons
  • Mike Breidenstein
    Mike Breidenstein Apr 27, 2014
    This solved my problem! I had no idea there could be so much lint in and around the burner!
This was the fix for my burning smell- Thanks!
Posted on Apr 01, 2009
Burning plastic smell from washer dryer combo
You have something between inner and outer tub remove top cover smell coming from air vents of outer tub then that is were it is
fun job its has to come all apart
Jun 28, 2016 | LG WM3987HW Front Load Washer / Dryer
Kenmore model 105.53534300 side by side refridgerator not cooling
Relays are located on the left side of the compressor. How long ago did you smell the burning smell? Are you 100% sure the compressor is running? If it is, nothing is wrong with the relays. Although sometimes it is hard to tell if the compressor is running. By morning temps will be higher than tonight if compressor isnt running. If it isnt running, relays must be changed. I will post shortly on how to change the relays.
Dec 23, 2007 | Kenmore 53542 / 53544 Side by Side...
Kenmore elite front load dryer squeaking and burning smell
you have a bearing in the drum support that has frozen and now the rubber wheel is burning up. The bearing needs to be replaced ASAP. You could damage the dryer if you continue to use it.
Feb 16, 2014 | Dryers
Kenmore 80 series electric dryer. metalic sound/burning smell
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
Dryer smells when on.
WELL DONE FOR HAVING A DRYER SO OLD AND STILL WORKING, THE PROBLEM COULD BE YOUR DRIVE BELT COULD BE TIGHT AND AND BURNING RUBBER .
Oct 21, 2009 | Dryers
Burning smell at end of wash
could be the belts but it could also be the motor depending on the smell
Jun 04, 2009 | Kenmore 22622 Top Load Washer
Kenmore 80 series quit heating after burning smell..
Any kind of lint or cobwebs on the element would cause a hot spot and fry the element or pop the limit that is mounted on top of the chamber. What your hubby soulda done is take the machine down and vacuum it out after sitting up so long. The fuse is not blown because it still runs so it must be the small guy pictured. It mount up top of the heat element chamber.ff8b5e7.jpg
Dec 22, 2008 | Dryers
Dryer drum wont turn- burning rubber smell
could be a stuck gear box. burning rubber smell is coming from the belt sliding .
or the belt is just loose and can not turn the drum to spin it.
tnx 4 using fixya,
drcool
Oct 11, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Elite HE4 Electric Dryer Logo
2,126 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
