Question about Nuova Simonelli Oscar Coffee Maker, Espresso Machine
Pump keeps running and excess water goes into the cup tray
Nuova Simonelli Oscar: The pump that fills the boiler does not shut off when the boiler is full and the excess water goes into the over flow tray under the cup tray. This just started today when I was using the machine. I leave the machine on all the time and there has not been a problem until today.
  • 3 Answers
Check the level probe on side of boiler may not be facing down as it should or need to be replaced.
Posted on Jan 04, 2009
My tank on my nouva simonilli Program machine keeps filling even with no power to the machine. I thought it might be the valve just after the pump (looks like it needs a certin pressure to open the valve...
There are 2 1/4 turn valves under the black safety cover under the drain tray, make sure the one closest to the inlet solenoid is turned off. If that is off and water still flows into the boiler then one of the exchangers might be damaged.
Sep 20, 2011 | Nuova Simonelli Program VIP Coffee Maker,...
Nuova simonelli vip over pressure problem
Could be lack of water in the boiler, could be a faulty pressure stat or vent valve. Check the level probe first, then the vent valve and then the pressure stat. You can also use the manual fill to make sure water is getting to the boiler.
Jun 27, 2010 | Nuova Simonelli Microbar Espresso Machine
Mac cup V commercial Nuova Simonelli will not **** water and will not build pressure
First check the reset thermostat on the right side of the boiler below the level probe, make sure there is water in the boiler before resetting.
Sep 25, 2009 | Nuova Simonelli Oscar Coffee Maker,...
Heater problem with espresso machine
Make sure there is water in the boiler, unlug machine remove the top panel and on the side of the boiler is a reset thermostat.
Jun 03, 2009 | Nuova Simonelli Oscar Coffee Maker,...
Empty light on espresso machine won't turn off and tank is full
I have the same machine. I just went on the coffee geeks website and it is easily solved. Just add a few grains of salt to the reservoir - the sensor cant detect water that is purified - strange but true as four grains and it fired up just like that.
Apr 13, 2009 | Nuova Simonelli Oscar Coffee Maker,...
Nuova Simonelli Mac 2000 - Boiler continues to fill up
I had the same problem of the boiler filling up all the way with water and the water was coming out of every hole in the machine. Turn the machine off, drain the boiler completely,
MAKE SURE VALVE #2 is CLOSED, this is the one under the drip pan all the way to the left. Turn on the water supply to the system and turn the system ON. The cup warmer on top will come on and stay on for anywhere between 10 to 20 minutes..... let it be,,, do not turn it OFF,, it will go off automatically. That should do it!
Hratch
Jan 21, 2009 | Nuova Simonelli Mac 2000 Espresso Machine
OSCAR NUOVA SIMONELLI WONT" GO ABOVE 165F AT GROUPHEAD
Descale boiler and group then make sure steam gauge reads 1.2 bar. If not adjust p.stat.
Jun 08, 2007 | Nuova Simonelli Oscar Coffee Maker,...
Open Questions:
See all Nuova Simonelli Oscar Coffee Maker, Espresso Questions
Nuova Simonelli Oscar Coffee Maker, Espresso Machine Logo
366 people viewed this question
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
