Question about IBM ThinkPad T40 2373 Notebook
T42p will not start up
You talk about mother board flexing and the processor beineg separated from its mount. You said there are some solutions on U tube but I couldn't find them. Please Help
The graphics chip can come loose. It's located under the keyboard, about where the space bar is. You can try pressing down firmly, but gently, on that area and see if it pops it back into place. You can also remove the keyboard and press directly down on the loose corner, very very carefully. If it starts, you may have to repair that solder point, or use a wedge of some sort to hold the chip down.
Posted on Nov 24, 2008
Cpu upgrade
Talk to an IT teckie but there are some many up grades for processors that they do not always fit older mother boards. You may have to up grade the mother board to achieve what you want.
May 05, 2013 | Computers & Internet
Asus Mother Board(P5GV-MX) display off, Boot time sound also off, The ram is OK. Processor can't check. Please give me solution.
Oct 18, 2010 | ASUS P5GV-MX Motherboard
Hi,i have a acer laptop,model no travelmate4150nlci.Problem is that it is not getting started.When it was working properly it's key board was not working properly.Then i went to acer service center to...
Funny, but I own a Acer laptop and I am quite happy with it. I had a bad CD/DVD drive go bad and promptly replaced, but other then that I never had any problems whatsoever. The key for this situation is the "processor". First of all there are more than one "processor" on a mother board. Usually, people refer to the CPU as the "processor". To check the condition described that the processor came out of the MB, it seems highly unlikely, because the CPU is greatly supported with the heat sink and the blower (if any) and usually, no one would ever think of dismantling the CPU assembly, which was assembled by the manufacturer of the CPU assembly. If indeed the CPU was off the mother board and if it survived, to re-install it would be a job less than ten minutes, unless there are mechanical problems. Another processor could be the BIOS processor, but that also is mounted on a socket and it cannot generate hardly any heat, because by the time it got that hot it would have tunred to ashes internally. Please, go to TV repair technician (bench man, not board changer) and ask him to check the Mounting of the CPU. Remember to tell him that if the CPU is out of place, then it will require some special heat conducting grease (the kind that they use for power transistors)during the re-mounting. If it is the BIOS processor, as I said, it is in a socket and you or your computer lover son can change it in a giffy. I cannot make sense out of the information fed to you, unless you did not understand them... or someone was not very honest with you...
My name is Constantin
May 29, 2009 | Acer Computers & Internet
No display
check if all cables are connected.
turn on pc...observe all lights
test the monitor to other pc...
if monitor is good
check if everything inside the CPU are connected.
Mar 13, 2009 | Mercury P4VM800M7 Motherboard
UPGRADING P 3 PC
THE SE440BX2 MOTHER BOARD CAN SUPPORT P3,P2 PROCESSORS(P3 850 MHZ)....,BUT NOT P4 AND HIGHER VERSIONS...THIS MOTHER BOARD SUPPORTS UPTO 768 MB OF RAM,NOT MORE THAN THIS...
Aug 19, 2008 | Intel Pentium 3 , 450 MHz Pentium III...
Which mother board to go with
any that has 2 separate pci-e, last board ive looked at was an asus crossfire board, looked sweet, would accomodate 2 vid cards nicely. went to new egg and was there
Jul 25, 2008 | Computers & Internet
IBM ThinkPad T42 notebook
Does it happen at a consistant time? Then check the power settings for the computer (screen saver and time to blank the screen.
Also, usually have a little latch of some kind that operate a tiny switch that turns off the backlight when you close the cover. Perhaps this switch is stuck on yours and the laptop may think you have close it. To find it, you must look for either a little spring loaded plunger on the keyboard side, or an opening on the keyboard side that something on the cover inserts into. All laptops have it, but they are all different. When you find it, push on it to verify it works.
Apr 23, 2008 | IBM ThinkPad T42p Notebook
try reseating the memory and replacing with spare if u have any uses ddr
Apr 08, 2008 | IBM ThinkPad T42p Notebook
Sata dvd drived can i insert into pvcle266m-l mother board?
Hi arijilla1, sorry no this board does not support any serial ATA SATA drives. Here is the specifactions for this Mercury board. Click the link below.
http://www.dealtime.com/xPF-VIA-Mercury-PVCLE266-Via-Socket-370-Flex-ATX-Motherboard-Via-C3-Samual-2-Processor-Audio-64MB-Shar
If I can be of more service, just ask.
Mike
Mar 28, 2008 | Mercury PVCLE266 Motherboard
Any touch will freeze my laptop IBM Thinkpad T42
There is a common problem with this machine; the mother board flexes and the processor mount partly separates from the motherboad. You tube posts a couple of solutions but they involve taking the laptop apart and applying heat from a heat gun to resolder the mount; it is not a solution for the faint hearted. Thinkpad/Lenovo might consider reparing the unit as it is basically a desgn/production defect but don't hold your breath.
Feb 25, 2008 | IBM ThinkPad T42p Notebook
IBM ThinkPad T40 2373 Notebook Logo
94 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
