Question about Samsung HLR5067WX 50" Rear Projection HDTV
Samsung 52'' DLP rear projection -- green tint after moving unit
Unit has been performing perfectly. We moved it upstairs earlier today and after re-attaching it to the Cable box (HD), the color calibration is way off, especially the greens. However, the settings have not been changed on the control menu. How do I get the color calibrations back to normal????
  • Anonymous Jan 27, 2009
    After being moved the color seems to run
  • rellis344 May 01, 2009
    I have the same problem; the picture is plenty bright and sharp but the color has a green tint and lack of red. when we go into the menu to adjust the color the still picture that they show to make adjustments on looks perfect.
Http://web1.toshiba.ca/support//ceg/techsupport/tsbs/viewtsb.asp?docid=TSB000064
Posted on Dec 04, 2008
Load valid paper for color calibration
When you perform a color calibration on an HP designjet you must use a certain paper. HP bond plotter paper should be one of them. If you are not concerned about perfect color calibration you can lie to the printer and tell it you installed the paper it wants. If it cannot detect that this paper is not exactly what it is looking for it will perform the color calibration. Just keep in mind that it might not be exact or may fail.
Oct 16, 2013 | HP DesignJet Z2100 InkJet Photo Printer
Color mixing is not proper
Start, programme,hp cp1525,tool box.. in tool box perform color calibration once its completed check for the print quality.. if its rectified.. end process.. if its not rectified only experts can perform do the calibration through aligning the scanner assembly..
Feb 01, 2012 | HP Laser Jet Pro CP1525N
Only black white
Thanks for questioning, pl don't post shot cut questions,your inputs are more valuable for us to give straight away trouble shooting..>Check all cartridges are fully loaded?>Before any body attempted for trouble shoot?>Are you checked for supply status?> Are you performed color calibration?**** Do color calibration (go to menu,system set up,quality,color calibration,calibrate now)Take supply status print out(go to menu,scroll to reports,scroll to supply status, enter in to for print)check all colors are printed are not? If printer take print out from system or print demo page from printer menu.. check print quality...and color calibration..****Remove supplies.. observe while closing the door right side in the supply bank supply contacts engaging or not.(while closing the front door the 'bios voltage contact leavers' engages with the cartridge contacts for passing the voltage in to the cartridge for charging,see the attached snap shot)if these are broken,no contacts or not properly driving by the mechanism, results no print.. check for these contacts...*** alignment disturbed, its major issue users cannot perform this activity..submit in service center for this major issue.
Jan 08, 2012 | HP Color LaserJet 2600n Printer
I baught this tv 3 years ago and today for no reason there was a constant buzzing sound over the sound itself. I have checked all the cables and they are in fine and I have retuned and set the tv back to...
I am curious, do you have a cable box attached to this tv and do you use channel 3 to play the set ? If so your cable box voulme setting is set on variable, and you cable box volume setting is way to low. If this is a HD TV and box use the Component cables or an HDMI cable to connect. Makes a world of difference. Hope this helps. PS if colors look bad when using 5 wire componenet cable, be certain not to have mxed your audio red connector with the video red connector.
Joe
Jul 11, 2011 | Televison & Video
I'm tring to hook up a DVD player, cable wire, cable HD box to my TV. I put the color coded cable into the TV and HD box but what do I need to connect the DVD player?
rene just installed hd cable box to hd tv. But there is not color except for blue and gold. Unplugged tv and the color is there as always, plugged tv back to cable box, no color
Feb 11, 2010 | Curtis CMMT20 20 in. LCD TV
Can you lay a Samsung 2000 model # PCJ522R on its back to transport/move it from one location to another in a vehicle?
Yes,but put alot of bubbles wraps to protect the DLP screen.Ties it tight to the car, to make sure the tv not move around in the car while in motion.
Feb 06, 2010 | Samsung PCJ522R 52" Rear Projection...
After having my dish network upgraded to HD and installed, i notice on my tv now that the green and red colors are not there, predominant on channels like ESPN that use these colors most. I._E.: football...
Sounds like one of the cables got plugged in wrong.
Look at the back of the HD box and there should be a cable with 5 ends on it (Green,Blue,Red, White and Red).
Often times a flashlight can help make sure you see the colors clearly.
The Green,Blue and one of the Reds is for video. The White and other red are for Audio.
When you unplug the connector the connection it is attached to is also colored. Check to make sure the colors on the cord match the color they are connected to at the box.
The most common mistakes connecting these cables are:
1) Crossing the Green and the Blue cables.
2) Connecting the Red Audio cable to the Red Video connection.
If all of the connections match the correct colors find the same cable where it plugs into the back of the TV and check these connections that they are correct.
When you find and move the cable to the correct connection this should clear up your color and you can begin to enjoy your new toys....
Good Luck....
Jan 15, 2010 | Panasonic CT-34WX54 34" TV
Computer suddenly slow!
There could be a number of things that is slowing your computer down and it depends upon what is running on the computer and in the background.
For example. Someone could have hack into your computer, assuming you are on an unsecured wireless conection. A virus program is using or accessing data on your computer. Your virus program is running a scan on the computer. If you are on the Internet and the service is slow because of the amount of traffic through your ISP's connection.
The way to monitor what is going on is to run Windows Task Manager.
Press Ctrl-Alt-Del keys together to open Windows Task Manager.
There are 5 Tabs that view various functions. The Processes and the Performance tab give you details of what is going on.
In the Performance tab if the CPU is running nearly 100% that is why your computer appears slow.
In the Application tab, this shows which programs are opened and running, the more applications that are opened can make the computer slower.
In the Processes tab this shows exactly which process is running and who or what is using that process and the CPU usage. Click on the CPU label twice and it will sort the CPU usage from the highest to the lowest. You maybe able to determine the process which is causing the problem and work out if you can shut down this process/program or it is a problem that needs to be resolved.
I suggest that if you are using a wireless connection that it should be secured to prevent unauthorized access. Install a firewall and anti-virus program. Scan the computer for viruses and trojan horse programs etc.
Aug 19, 2009 | Dell Computers & Internet
I have an Hitachi 43FDX15B. The tv worked perfect
sounds like the convergence is out of whack. you will need to call a local repair shop and see if they can realign the color guns inside the unit. this is actually a really common problem with moving a rear projection screen.
Jul 11, 2009 | Televison & Video
Samsung HLR5067WX 50" Rear Projection HDTV Logo
315 people viewed this question
Henry  Thomas
Henry Thomas
