Question about Brady ID PAL Thermal Label Printer
Printer does not work
Printer says "insert labels" when trying to print
MickDostie had the right idea, I used his method and added a piece of Aluminum Foil on the contacts of the ID Pal and BAM! it works. Thanks
Posted on Aug 15, 2009
Hi, I had the same problem with my Brady IDPAL... here's what I did to make it work again:
-I took a piece of cardboard and cut a square about an inch²
-I wedged it in the crack right under the BRADY sign between the frame of the IDPAL and the cartrige of vinyl so that the lower part of the cartridge in question is pressed firmly against the 3 metal ``cartridge detector``.
-The problem seems to be caused by these ``detectors``
It worked for me and I hope it works for you.
Good luck and good day
Posted on Jun 14, 2009
There are 3 electrical contact wires in the cartridge cavity above the POWER button. The cartridges have a conductive surface that "shorts" a pair of these contacts depending on the cartidge. Make sure the conductive surface on the cartridge is clean and is making good contact with the contacts.
Posted on Jan 28, 2009
While all those solutions work, I took mine apart. The three wires are soldered on one end to the circuit board, the other end, that you can't see has a 90 degree bend. Over time the part you can see, the three wires, there is also an bend on them. I found by pulling the wires up slightly with a small tool, like an Awl, you can restore the bend and thus the contact where the wires hit on the little metal piece on the bottom of the cartridge. Worked fine for me.
Posted on Mar 23, 2013
MickDostie has the right idea. I tried it and was still having problem so i added a small piece of foil on the contacts and BAM! it works.
Thanks!
My Brother P-Touch QL 500 stopped printing and keeps blinking
Either the wrong printer is selected or the wrong size label inserted. Another possibility could be the incorrect size label in the format.
Sep 15, 2017 | Brother P-Touch QL-500 Label Printer, 300...
Got to work this morning and the thermal printer had continuously printed the previous days manifest until it had run out of labels. I inserted new labels and it started to print the manifest again. I...
Uninstall the printer and restart the computer once installed reinstall the printer from the CD that came with the printer or get the latest software / pilots from the printer's web page
Jul 21, 2011 | Datamax E-CLASS DMX-E-4203 Label Printer
How do I make a CD label?
There is a user manual on the install disc, pdf-format. To get to the manual, insert the install disc and wait for the small window to appear. At the bottom are some options, one being "View User's Guide". Click that. Or you could access the pdf-file itself manually and copy it to your hard drive: After inserting the install disc, go to "My Computer", right-click on your writer drive, choose "Explore", double-click on the folder named "SE1", and look for a file called "SE1 Guide.pdf". Open it, or copy it and paste somewhere on your computer for future reference. Read Chapter 4 of the user guide - it is titled "CD&DVD LabelMaker". Here follows the chapter, illustrations excluded:
Chapter 4
Introduction
CD&DVD LabelMaker makes designing and printing disc labels
and CD/DVD inserts fast, simple, and fun. Customize labels with
your own photos, text, video stills, and music playlists. Hundreds of
professionally-designed themes are included inside. Supports
label paper templates by Avery®, Memorex®, Neato®, CD
Stomper®, and Direct to CD/DVD Printing with supported printers.
Getting Started
When you first start the program, you're prompted to select the type of
project you want to design and print: Disc Label, Jewel Case Insert,
and DVD Case Insert.
Once you've selected the type of project, you'll be prompted to select
the paper to which you'll be printing. Select your template from the list,
and then click OK. (You can also change your project type by selecting
a new one from the top pull-down.)
Designing your label
You can customize various sections of your label/insert depending
on the selected paper type/template. The main workspace in the
Design Label tab starts by focusing on one section of the label/
insert. For example, if you're using paper that has two disc labels, the
focus will be zoomed onto one of those labels.
Adjusting your view
Notice the two up/down arrows on the left side of the screen. When
applicable, you can click either arrow to shift the focus to the top/
bottom of the page. Click the Paper View button in the lower left
corner to see a small thumbnail of the page. Click the section that
you'd like to edit, and it will appear in the main workspace.
Changing the Background
The right side of the screen lets you change the paper background,
either by applying a color (Use Color) or graphic design (Use
Theme).
To change the background color, select Use Color. A color palette will
appear. Click the color you want. The color will then appear on the
label/insert in the main workspace. The palette is fairly robust. If you
select a new color that doesn't appear on the grid, you can add it to
your My Favorite Colors.
To delete a custom color, select the color, then click the - icon.
To add a design, select Use Theme. A pull-down at the top lets you
select from a variety of categories. Each category offers a variety of
designs. To select a design to apply to your project, simply click it.
Click the button to the right of the pull-down to search for additional
designs online.
Printing your project
A print preview displays your project.
If there are certain sections/components that you'd prefer to exclude
when printing, simply click that object (it will appear dulled in color).
If you change your mind and decide to print the object, simply click the
object again and it will become active for printing.
Print with Mask: This option is only applicable when printing disc
labels. If you notice that your prints aren't aligning properly with your
labels, uncheck this box. Instead of printing over the circular area of the
label only, a square version of each photo will print to cover more area
and fill the disc label.
Select Your Printer: From the Printer pull-down, choose your
printer.
Modify Your Printer Settings: Click the Printer Setup button to
view/modify your printer settings.
Set the Number of Copies: Use the arrow buttons to increase/
decrease the number of copies you'd like to print, or key in the value in
the available box.
(To be continued - ran out of space) From: 11407336
Dec 01, 2010 | Individual SlideShow Expressions
My Brady LabPal label printer seems to be printing labels that are not very bold and, in fact, the numbers are often only half printed. Do I need to change the ink cartridge within it, or what is the...
I have label cartridge in but it doesn't print, just says "insert labels". I have tried many times to take cartridge out, and reinsert, but it won't do anything.
Jul 01, 2010 | Brady LAB PAL Thermal Label Printer
Canon MP810-CD-R Tray loading-printing problem
I am trying to print on DVD with Canon MP810 but the image won't line up - seems to be taking the tray too far in and printing some of the image on the F tray! Help.... it's driving me nuts
Jun 02, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Printing Labels
Sorry loose plug. All fixed!
Jan 06, 2009 | HP LaserJet 1020 Printer
CD label (Neato) printing problem
Try to change your paper type to plain paper - it could be because it is a bit glossy that it thinks it's photo paper that is not inserted correctly.
Jan 04, 2009 | HP Photosmart C8180 All-in-One InkJet...
I am trying to print using Avery 8663 clear mailing labels using my HP Photosmart 3310 all in one. The printer keeps shooting out the paper with the message "please remove the paper and re-insert it with...
Does it still print on plain paper? Check to see if you are missing one or more labels as they may have come off and onto a roller or other part. I've found that label sheets with any labels removed prior to printing are always prone to loosing labels in the process of traveling through the printer.
Dec 07, 2008 | HP Photosmart 3310 Printer
HP laserJet 2100 prints blank from manual tray
I bet you have a bad USB wire.Change the wire and I suggest reinstalling the drivers.
Oct 31, 2008 | HP LaserJet 2100 Printer
Label Printing
I had the same issue when using Avery labels, here's what resolved it for me.
Go to Control Panel, Printers, go to the active default, right mouse click, click Printing Prefrences..., change the drop down "Type is:" to 'Other Photo Paper" and apply.
You should then be good to go!
Feb 10, 2008 | HP DeskJet F380 All-In-One Printer
Brady ID PAL Thermal Label Printer Logo
1,099 people viewed this question
Top Brady Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Bob Rambo
Level 1 Expert
NOEL
NOEL
Are you a Brady Office Equipment and Supply Expert? Answer questions, earn points and help others
