My poloroid tv with dvd player dvd player put dvd in makes noise
Dvd player does not work put dvd in makes noise then screen says loading but does not work . only used this once.
This is a very common problem with the 32" TDA-03211C TV/DVD combo unit. Poloroid sent me three replacement DVD units in the first year and each began doing this same thing after a few months (chunking noise and could not load disks). Finally my warranty expired and it failed again. I ended up with two units left after all those exchanges, so I took one apart to see if I could figure out what was going wrong.
In switching the units out one day, I noticed that the forward facing side of the DVD box was getting very warm even when it is not being used. Also, the dvd's felt very warm when ejected from the unit. I also noticed that the metal plate which is behind the picture screen and only about 1/4" from the forward facing side of the DVD box was even warmer (about 110 to 120 degrees F). This heat is distorting the thin metal and plastic parts in the DVD unit, causing the parts not to be in correct contact and alignment (disk won't play and sometimes won't eject).
With the front and top covers removed from the DVD box and the box laying flat on a table (and no dvd in unit of coarse), I pushed downward firmly on the black plastic disk at the top of the drive, and also on the lever arm that is accessible through a hole near the left front of the unit until they bottomed out to bend them down some (the lever arm was warped upwards where it was actually rubbing the top of the case - that was the chunking sound I heard).
I then went to O'Rielly auto parts and bought a 1'x2' sheet of exhaust manifold gasket material for $8. This material is not flamable and will withstand temperatures that would melt this TV into a puddle. I cut the gasket material so that it would fit neatly inside the top cover of the DVD box (metalic side up), then put the top cover and front cover back on the unit. I cut another piece of the gasket material to fit snugly in the space between the forward facing side of the DVD box and the metal plate that is behind the picture screen (metalic side facing picture screen). I then reinstalled the DVD box into the TV. It was a little tighter fit than before, but went in OK and is still removable with some effort.
Both of the previously non-functioning DVD units I have play fine now in the TV. The disks eject perfectly every time now and I notice a significant difference in the temperature of the disks when I eject them. No more strange noises either.
These DVD units are fine and are actually quite well built, but they are just mounted too close to a heat source. A little insulation is all it needs. I cant believe Poloroid's design people can't figure this out.
Posted on Jan 06, 2009
DVD player model D200B
either a mechanism issue or possible bad optical unit (pickup) in the player.
Jun 14, 2012 | GPX Televison & Video
When i put a dvd in the player makes noise and screen says no disk or unable to read
Sounds like the mounting spindle is out of alignment, meaning the disks you load into the player are not spinning in a balanced, stable position. Without this being the case the laser pickup will not be able to read the disk and the unbalanced disk will cause a noisy hum and you may even be able to feel vibration in the player itself to confirm this. Sometimes the noise and vibration is a disks fault but if it occurs on any disk you insert (and can confirm the same disks work ok with no noise in other DVD players) it will be the players mounting mechanisim that is not playing the game properly I suspect.
Aug 18, 2009 | Polaroid DPA08055S Portable DVD Player
When you put a dvd in it tries to load but makes a funny noise then either says wrong disc or no disc
toooldie have you ever dropped your dvd player have you checked that your cd/dvds are clean if thif doesnt work go to a electronics centre they may be able to check it out for you i hope this helps
May 04, 2009 | Televison & Video
My dvd player is making a loud humming sound when i load up a dvd. it is the phillips dvp5960
Does the DVD player still work, even though it's making the humming noise?
The humming noise may just be normal for that machine. Turn your TV up louder .
If the player doesn't work, the drive is broken, and you would have to send it to Phillips if your warranty is still working. If the Player still works, check to see if the disc is warped or cracked, this'll make the drive unstable, and make the noise.
Hope my answer helped :)
Nov 16, 2008 | Philips Televison & Video
After i put the dvd the movie does not see anything only the black screen and i let it load for a long time
>Do you hear Sound
>Yes-
>make sure all the connection on the TV and DVD player are secure.
>is your DVD players Menu on screen/visible before U insert a dvd
>check the players menu and the settings
>unplugged the DVD player from the power cord wait and the try it
>plug the dvd into a different tv if possible if that works then your tv was the problem just locate the tv settings to fix that
>still no luck than maybe you DVD players laser just needs to be cleaned
>use a self-cleaning DVD clean kit (really cheap too) and they work great it is just a cd that has a tiny brush on the disk as it spins a passes over the EYE to clean it .
Good Luck
Aug 28, 2008 | Insignia Televison & Video
Flashing Screen says loading?
We had the same problem with a DVD player so we took it to be looked at and they said it could not be fixed and to throw it out.
Apr 28, 2008 | JVC DR-MV1S DVD Recorder/VCR
Poloroid PDM 8551
The Poloroid PDM 8551 is notoriously prone to failure.
the current top of the heap of portable DVD players is a company called Venturer
The Venturer Portable HD home theater complete with wireless headphones sells for around 100$
The solution here is clear , ditch that ****** and hunt down new one.
Shalom :-)
Apr 16, 2008 | Polaroid PDM-0723 Portable DVD Player
Poloroid 32 in HD LCD with DVD player
check for shorted diodes in the power supply. the power supply is located in the modual.
Feb 29, 2008 | Polaroid 4226TLMB 42 in. LCD TV
DVD not working!
sound like the lazer drive unit is faulty.
Expensive to fix.
My suggestin is by a new one.
Dec 13, 2007 | RCA 20F610TD TruFlat TV/DVD
Televison & Video Logo
157 people viewed this question
Top Televison & Video Experts
